Question about Patton PUH680-U Utility Heater
Patton puh680 owner manual - Patton PUH680-U Utility Heater
5 Suggested Answers
  • 1015 Answers
SOURCE: CAN THIS HEATER CAUSE AFIRE AND IS THIS HEATER ON
I do not know if this heater is on any product recall but we have used patton heaters for years and pretty much have had good luck with them. However there is a fire hazard present if you set or store combustibles to close to the front.Tip over switches don't always work and I would never recommend using a heater of this type in a unsupervised area.I hope this is of some help to you. Thank you and happy holidays.
Posted on Dec 20, 2010
heatman101
  • 43501 Answers
SOURCE: my Patton PUH680 space heater is not working. Do
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Posted on Jan 16, 2011
  • 4736 Answers
SOURCE: We are having a discussion at our Plant on the
Must be an older model heater. All the recent ones have a 3 prong plug. Especially, since the recall a couple of years ago on the PUH680-U Heater.
Posted on Jun 21, 2011
SOURCE: I need the lighted switch on front of Patton
MILKHOUSE HEATER "CAUTION LIGHT" SOLUTION: Before I explain, let me clear this myth up: this is NOT an issue with the pendulum safety switch (some mistake that for a "mercury" switch). To begin, unplug the heater. Open it up and clean it out. I mean, buy a can of non-chlorinated brake cleaner and squirt all of the contacts good. Below the fan there is a sensor mounted on the heater element box on the bottom. That goes bad and causes it to trip. While you are there, squirt the motor bushings good with the brake cleaner and dab a drop of synthetic motor oil (just a drop) on EACH of the two motor bushings. Personally, I rewired this and bypassed all of the safety features. You can bypass that sensor without soldering or cutting any wires. All you have to do is unscrew the wires from the holder and then unscrew the tiny nuts and tiny bolts. Then bolt the together at one end (note the position) and put it back in the holder and tighten the screw to hold it in. This method fixes the issue completely as it removes the sensor from the equation. In fact, I just did that on my third milkhouse heater and it has been running solid for the last 15 minutes. Use your modified heater with caution! Let the brake cleaner dry before you energize this device!
Posted on Dec 11, 2012
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
Jan 19, 2016 | Patton PQH307UM Electric Utility Heater
I need two more rubber pegs for the base of my Patton heater. It only came with two. How can I get 2 more?
Almost every manufacturer will supply free parts for new equipment that is missing them.
Call them and let them know and I'm sure they will mail them to you.
Gary
Jan 23, 2011 | Patton Electric Patton PUH680-U Electric...
CAN THIS HEATER CAUSE AFIRE AND IS THIS HEATER ON RECALL PATTON PUH680-U
Dec 20, 2010 | Patton PUH680-U Utility Heater
My Patton PUH680 space heater is not working. Do you offer replacement coils?
heatman101
Dec 06, 2010 | Patton PUH680-U Utility Heater
I have a patton puh682 1500 watt heater and after a while it just seems to turn off is there some kind of timer or heat control?
Under the main black knob is a bi-metal switch which shuts down the heat at various temps depending on your setting. Their is no timer.
Sep 21, 2010 | Patton Electric Patton PUH680-U Electric...
A small, white, plastic or ceramic part which
TRY AN APPLIANCE STORE THAT DOES REPAIRS. OR CHECK ONLINE WITH MANUFACTURER OR IF SOMEONE CARRIES PARTS FOR IT ONLINE
Feb 26, 2010 | Patton Electric Patton PUH680-U Electric...
Looking for a phone number to contact PATTON SPACE HEATER COMPANY
Patton at l-800-528-6600 ext. 1722 (Arizona: l-800-352-0458 ext. 1722; Alaska l-800-528-0470 ext. 1722)
Apr 01, 2009 | Patton Electric Patton PUH680-U Electric...
Patton PUH680-U Utility Heater Logo
129 people viewed this question
Top Patton Heating & Cooling Experts
Mack Baxter
Jay Finke
Jay Finke
jeff5may32
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
