Question about byD sign 3032 30 in. HD-Ready LCD Television
Bydsign d:3032 TV broken
The TV turns on, says the brand then searching for signal logo comes in the right lower corner of the screen and the rest of the screen is black. Then the picture flashes through the screen periodically, alternating with the black searching for signal screen. Audio and cable work fine. The TV just never gets the "signal" that it is searching for. TV brand is Byd:sign, model d:3032. I believe that the power adapter is accounting for the problem, but I am not sure. I have dusted everything, un plugged and replugged everything, but nothing works. Any advice will be greatly appreciated! Thank you!
  • 3 more comments
  • crober03 Jan 21, 2009
    Is there a universal power adapter that will work for my TV, because Radio shack does not have the one that is broken.
    I cannot find the power supply anywhere online. Where can I buy an AD-13D-2 power supply?
    How do I rule out a Hardware problem?
    I cannot even get the source menu to appear to use it. I see it flashing by. Is there a hardware problem?
    Yes, thank you!
  • 11,896 Answers
Data.ul.com and amazon.com both carry your power supply. Also make sure your tuner card is not loose or have broken pieces or any loose solder. Also make sure your cables are the good stiff kind. The flexible ones are cheap and cause a lot of interfearence.
Make sure all connectins are tight.
A cable signal booster box is available for purchase at many local hardware stores. I don't believe it is necessary unless you have many televisions hooked up to the cable.
Is your cable hooked up directly to the tv or are you using a vcr?
Posted on Jan 21, 2009
    Scholar:
  • 58 Answers
It sounds like it's not getting a signal. If it's not getting a signal then there is a problem between where the tv is listening for the signal and the antenna. That could be a whole lot of things. It could be as small as an error in the circuit board to a bad cord. It sounds like you ruled out the cords or obvious problems so maybe it has something to do with what's going on inside the television. I'm not sure if the power would make the signal go out unless your talking about power to an antenna. Basically, there is a break in the line between where the tv hears and the antenna recieves.
  • 744 Answers
Hi some of the capacitor circuits inside ur tv would have been disturbed or got damaged. so its better to look out for a tv mechanic who could replace the capacitors and ur problem might get solved. rate me
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
It would seem that you have 2 concerns:
  • signal source - refers to the incoming, be it cable TV, a DVD, home theater receivers, satellite/decoder or even a game console. If none ios found and they are connected, then probable fault would be with the input module/processor. This is the part that accepts all of these inputs and selects which to switch to display as per your choice;
  • power adapter - determine the requirements, voltage (VDC) and current (ampere). Any adapter with identical specs/ratings would serve the purpose as long as the connector/plug and its polarity matches that of the TV.
Good luck and thank you for using FixYa.
  • 296 Answers
Move the cables that the signal is sent by. Ex. 75 Ohm. coaxial cable, hd cord A/V cord. If sceen does this on command then the cord needs replacement. Also check to see if there and any loose connections.
Posted on Jan 20, 2009
    Sergeant:
  • 378 Answers
Yes.u can get the power adapter at.radioshack websites.get it replaced.
thanks.
  • 716 Answers
Check To Make Sure You Have Cable To The House Which Im Sure you Have.
Then Unplug The T.v And Hold On/Off For 30 Seconds Then Release And Plug Back In. When Turning It On Hold The Power Button For 10 Seconds Or Until It Beeps.
Check To See If Problem Persists.
  • Michael Fisher
    Michael Fisher Jan 20, 2009
    Please Determine Its Not A Hardware Setting Before You Start Replacing Parts.
How do I fix Samsung TV
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Aug 24, 2015 | Samsung Televison & Video
My LG TV does not turn on. It shows LG logo for few seconds then the screen flickers and gets back to LG logo again.
Corrupted firmware. An update is necessary. If you wish to get some details; check the site linked here. Pull up older posts.
Firmware (Software) update procedure of many popular brand TVs and other devices are given in detail.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Dec 26, 2014 | LG 65LW6500 65 inch Class 3D LED LCD TV,...
When I turn TV on there is no picture....It has a small black square with a number in top right corner and rest of screen is blue and say No signal ...I tried factory reset and scan channels and nothi
Sounds like there's no signal from the aerial.
Do you know if the aerial actually works i.e. was there a TV in place before this one that picked up Freeview from the same aerial point?
Have you tried your TV on another aerial feed (another room in your house or someone else's house) or with an external source such as a DVD player or Blu-ray player?
Sep 09, 2014 | Televison & Video
I have several large water spots on the lower right corner of the tv from overspray with windex. Can this be fixed?
Not a good idea to clean tv with windex. Try wet towel dipped in mild soap solution. Make sure all water has been removed and towel is only wet. When tv off, try removing the spots. Turn tv on only after tv dry.
Dec 22, 2013 | Apex Digital LD4088 LCD TV
The upper left quadrant of my Sharp Aquos LC-65D64U does not display.
Check the connections of the flat cables that connects the T'Con board to LCD pane for any loose contact. Re-seat them. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or make a search by type in the brand name of the device in the "Search Box", at the top right of the display window.
Dec 05, 2012 | Sharp Aquos 65" LC-65D64U LCD TV
I have a Polaroid TLX-04240B It comes on and Displays the Polaroid logo, then it goes to a black screen with the HDMI1 input box on the top right hand corner. THis box eventually disappears, leaving me...
Buy another HDMI cable.Try another HDMI cable with another HDMI hub on the tv port.If u still have the same problems,mean the whole main tv Tuner signal board have problems and the caused.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv Tuner signal board for the replacement.
May 19, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
Screen Repair
Try searching SAMSUNG TV through Google search. You will find the servce center to your nearest location.
Apr 22, 2010 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Peascorn
I have a New OEM power supply for a byDesign 3032 TV.
If interested, please email me your contact info.
Thanks,
Art
Jul 17, 2008 | byD sign 3032 30 in. HD-Ready LCD...
Trying to find a power adapter for a bydsign d4032 40" LCD-TV the model # on the part is AD-12C-1. I tried Bydsign's website and all phones have been disconnected. We have a lot of these LCD panels and...
Thank you for the info.
That adapter may not be easy to find with all those specs. It looks like these adapters are only customized to use on this brand of TVs.
My suggestion will be to try to fix them to the component level or if you can find a tech to do it for you.
Good Luck.
Call this guys:
bydsign worldwide
105 SE Executive Dr.
Suite 11
Bentonville, AR, 72712
United States
479-845-0680
Customer Service:
800-770-3771
Mar 14, 2008 | byD sign d:2232 22 in. HD-Ready LCD...
byD sign 3032 30 in. HD-Ready LCD Television Logo
87 people viewed this question
Top byD sign Televison & Video Experts
ray gallant
Are you a byD sign Televison and Video Expert? Answer questions, earn points and help others
