Computers & Internet Logo
Posted on Jan 20, 2009
I'm looking for jumper settings for a maxtor hard drive model # 91531U3 , 14 gigs
  • Anonymous May 11, 2010
    are you trying to use it as a secondary drive or a stand alone drive?
Anonymous
Level 1:
Problem Solver:
  • Contributor 35 Answers
  • Posted on Jan 20, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
35
Questions
Helped
4137
Points
76
Have you tried
http://www.seagate.com/ww/v/index.jsp?vgnextoid=68156caa4dc8f010VgnVCM100000dd04090aRCRD&locale=en-US&reqPage=Model&modelReqTab=TechSpecs
for the DiamondMax 20VL Ultra ATA 66 Manual PDF on the right side after you open it says on page 4-5 for the master and slave settings. try page 4-10 also.
1helpful
Maxtor hard drive jumper settings for model 7245At maxtor hard drive jumper settings for model 52049h3
1. Jumper settings for model 7245At refer to LINK
2. jumper settings for model 52049h3 refer to LINK
Hope it helps.
10helpful
3answers
Jumper settings
25870e5.jpgCheck this diagram. it shows all configuration in detail..
good luck!!
1helpful
I have an old maxtor hard drive 40 gig, nad my PC couldn't recogn
just need to set the jumper so this will work as the slave
2helpful
Maxtor hardrive
If one of the jumpers shorts two pins and the other jumper is a single pin short, remove the two pin jumper. The single pin jumper should be located on the pin at the far upper right corner. should be set as a slave at that point.
2answers
Maxtor 500 gig internal diamondmax 21
external USB hard drives do not need to be jumpered, if your computer does not recognize the ext. drive probably it is because the enclosure is defective, when you connect the USB cable you should get the "ding-dong" connection sound.
If you think that your computer recognizes the hard drive then jumper it as "secondary" or "cable select" and install it INTERNALLY, then transfer your data, that will prove that there's a problem with the ext. enclosure.
One more thing, maybe the USB port you use is malfunctioning, try one that you know that works (assuming that you have other USB devices that work).
1helpful
2answers
Jumper settings for a Maxtor hard drive, Model 87000D8
This looks like documentation from the time but it is not from a manufacturer's site.
http://stason.org/TULARC/pc/hard-drives-hdd/maxtor/87000D8-DIAMOND-MAX-7000MB-3-5-SL-ATA3.html
near bottom of page.
Grand Canyon Tech
Grand Canyon Tech
