Question about RIM BlackBerry Curve 8310 Smartphone
Speakerphone when answering blackberry pearl 8100
When my blackberry is on a profile that is not vibrate or silent, when I answer an incoming call it is automatically on speakerphone. The person on the other end always tells me that they echo...but after about five seconds it switches back to a normal volume setting. How do I fix it to where when I answer an incoming call no matter what profile it's on a regular, not speakerphone, volume? I've tried changing all of my default call volumes on my profile to low but nothing works! Help! I have the same problem on a couple of 8310's and i m pretty sure it started happening right after i updated them to the new os 4.2.2 i think.
  • 10 more comments
  • rheroux Jan 20, 2009
    Now that i think of it also happend on one of my bold's too. How can no one not have a solution to this seems to be a bug or something. I'm calling my phone provider tommrow if i find a solution i'll post it here.
  • Anonymous Jan 26, 2009
    is anyone finding a cure? it happens to me too.
  • Anonymous Feb 03, 2009
    I'm on my 4th phone and I can't get it to stop.
  • britishh__ Feb 16, 2009
    Yea i Have this problem too it drives me crazy, ive had 4 blackberrys 2 pearls and 2 curves, and this problem keeps haunting me, someone must know what the solution is....
  • ricvantri Feb 17, 2009
    I have the same problem.I tried everything I could know. So being outside US and seeming that it is not a hardware problem the only way i see is installing the OS again. I have one from a torrent and maybe it is corrupt so i downloaded another from a phone provider in Spain. In my case it is almost incredible because everything with the sound of my BB Curve almost new works great except that i can´t hear who calls me. Only through the speakerphone or headphone.Depending on what happened i write my prompt after.
  • jckbquck Feb 23, 2009
    Incoming calls goes to speakerphone for a few seconds. It's bugging the heck out of me!
  • Anonymous Mar 09, 2009
    I have the samne problem on my curve 8310
  • Anonymous Mar 10, 2009
    I have a brand new curve and I have the same problem
  • Anonymous Apr 01, 2009
    exactly the same - speaker is on when a call comes in. i HATE it!
  • Anonymous Apr 24, 2009
    when my phone is on the "normal" profile, i answer calls and they are automatically answered through speakerphone for 5 seconds, and then switches. i find this disturbing since this phone is a warranty replacement that i just got less than three days ago...
  • euros Apr 28, 2009
    Same as main post. One of our users Blackberry 8310 Curve's answers on speakerphone for 5 seconds, during this time the caller gets bad feedback from an echo. The call then reverts to normal
  • ricvantri May 11, 2010
    Thanks !. But it is not so easy.I let the phone without battery for many times and I upgrade the OS and nothing happened. I think that it must be a hardware problem. What else?. Unfortunately i´m not in US and i can´t use the waranty in other words i have to keep the phone and i have to fix it. Thanks !
I had the same problem. When I answered a call, it was on speakerphone for about 4-5 seconds and the caller heard an echo. I did two things and between the two, the problem went away. First, I enabled and then disabled bluetooth (Options -- Bluetooth). It was already disabled, but thought maybe bluetooth was acting up. Last, I took out my battery while the phone was on, the reconnected the battery and turned on my phone. It echo/speakerphone issue went away....we'll see how long this lasts.
Posted on Nov 17, 2009
After taking out the battery for a couple of minutes, fixed this on my Pearl
Posted on Feb 25, 2009
Press the button on top of the phone which is used for Mute. Screen would display " phone is entering standby mode". That fixed the problem for me
Posted on Feb 17, 2010
2 Suggested Answers
SOURCE: Speakerphone when answering blackberry pearl 8100
I had the same problem. I called T-mobil, my carrier, and they had me take the battery out while the phone was 'on' and put it back in. After the security scan was done, the tech called me back on my cell - problem fixed. (I'm not sure if he did something on his end too, but at least try it your self first!)
Posted on Sep 26, 2009
Ringer Not Working Properly
i would check your profiles. usually the default setting for the load profile is for it to vibrate twice and then ring, so that usually only gave you two rings to answer the phone after it vibrated twice. make sure that within your profile setting that you have it to ring with a tone, and make sure you have a volume selected. i would also use blackberry desktop manager and perform a back up or sync of your blackberry, and then perform a wipe handheld. the wipe hand held feature is in your options---security---general settings---and then press your options button (right of the trackball) and select wipe hand held. you will type the word blackberry and then it will wipe the handset. after it resets try the volume before you restore it, if you still don't have volume your speaker is bad.
Nov 05, 2009 | RIM BlackBerry Pearl 8100
Well i have a blackberry pearl 8100 and i set it so that it rings and it does ring but it vibrates twice before that and i dont want it to do that. How do i make it just ring and not vibrate ?
Go to profile, select advance, you will get all the profiles highlight any one of the profile,then press Menu key, select Edit, then select Phone, you will get an option called Out of holster, press Menu key, select Change option under this select Tone, Now you're will only ring.
Nov 01, 2009 | RIM BlackBerry Pearl 8100
My BB pearl 8100 doesn't ring for incoming calls/messages/emails, but if i go to listen my ringtones or music they all sound fine, i think it got corrupted or something because no matter how i change the...
Not sure if the pearl interface is the same as mine, a Storm - I have an option on my main screen to fast-select ring volume (called Notification), which affects both calls and messages, and I can choose loud, soft, vibrate, silent, and also go into options for more detailed settings. You may have such an option that is easy to find, and maybe easy to set by mistake, without realising it.
Pearl manual at this location:
http://docs.blackberry.com/en/smartphone_users/deliverables/1217/userguide_bb8100_gprs.pdf
see p193, Notification Profiles.
There are other keys, eg # that affect notification sounds/vibrate. Download and search in the manual for 'Notification" to find all the places mentioned.
Even if you have a paper manual, I recommend keeping the electronic one since you can easily search for keywords and find all the places they are mentioned quickly.
Sep 11, 2009 | RIM BlackBerry Pearl 8100
I have never a newer blackberry but on the ones, I had this worked for me. When you go into your profile to change them if you hit the menu button while you one of the profiles highlighted there should be a way to edit the profile, it could under advanced options. i hope this helps.
Apr 19, 2009 | RIM BlackBerry Bold 9000 Smartphone
Oct 16, 2008 | RIM BlackBerry Pearl 8100
Auto Speakerphone
Remove the battery, hold the power key for 10 seconds. Re-install the battery, power up, issue should be resolved.
Jul 01, 2008 | RIM BlackBerry Pearl 8100
BB Pearl 8100 - can't hear incoming calls
Probably need a new ear piece speaker they are 26.95 at celldr
Feb 21, 2008 | RIM BlackBerry Pearl 8100
Bb pearl won't ring
Have you checked the "profiles" (click the icon on the desktop). Make sure it is not in silent or vibrate mode.
Hope that helps... :)
Feb 07, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry Curve 8310 Smartphone Logo
2,358 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
