Question about Acer AL1711 17" LCD Monitor
Acer flatscreen monitor flashes on then shuts down to sleep mode
4 Suggested Answers
SOURCE: Acer AL1714
OK I have the same monitor, I was given it by a client when I couldnt fix it, I DO have the 19V supply and still getting the same problem.
If you open it and reseat all connections you can reach, I find it starts to work. Unfortunately after less than a few days use it goes off again.
Hopefully this can help someone get further
Posted on Nov 03, 2007
  • 905 Answers
SOURCE: I have my acer p205h
This is normal.
Posted on Mar 01, 2011
  • 6771 Answers
SOURCE: my acer x203h monitor will not come out of sleep mode.
Hook a spare monitor to the computer, if okay! the problem is the power supply board, one or capacitors are open leaving in some cases a slight puff at the top. If symptoms are the same for both displays, it means the Video Graphics Card in the computer is defective.
Posted on Mar 18, 2012
No sleep mode on acer monitor
This is annoying, but try to go back on factory default setup.
Apr 15, 2014 | Acer Computers & Internet
Acer one with windows 7 ultimate fall into sleep mode
A laptop computer is typically set to conserve battery power. One of the common settings called standby, sleep mode or hibernation turns off power to the screen and the laptop itself after a preset time limit passes without any mouse or keyboard activity. It can be inconvenient for the computer to shut down while you're working on an open page or during a download. Change the setting if you don't want your laptop to going into automatic shutdowns
Turn the laptop computer on with the power button if it's not set to turn on upon opening. Allow the system to boot up. Open the panel for adjusting the sleep settings. This varies among the popular versions of Windows operating systems. To change the sleep mode setting on a laptop running Windows XP, click the "Start" button, and click the "Control Panel" selection. Choose the "Performance and Maintenance" selection, and click on "Power Options." Click the "Power Schemes" tab, and click the drop downs next to "Turn Off Monitor," "Turn Off Hard Disk," "System Standby" and "System Hibernates." Select "Never" for each drop down in both the "Plugged in" and "Running on Battery Power" columns. Click the "Hibernate" tab and click to remove the check mark in the box next to "Enable Hibernation." To change the sleep settings on a Windows Vista laptop, click "Start," "Control Panel," "Systems and Maintenance" and "Power Options." Then click "Change Plan Settings" under the currently established plan. Click on the "Advanced Settings" tab and select the "Never" option on the "Sleep," "Sleep After," "Hibernate After," "Display" and "Turn off Display After" drop downs. Click the "OK" and "Save Changes" buttons to confirm the settings. To change the sleep settings on a laptop running Windows 7, click the "Start" button, choose "All Control Panel Items," select "Power Options" and click "Edit Plan Settings." Click the drop downs for "Turn off the Display" and "Put the Computer to Sleep." Choose "Never" for both and click the "Save Changes" button.
Feb 06, 2013 | Acer Aspire One PC Notebook
I have my acer p205h 20 inch monitor hooked up to my tobshiba laptop and it works great except it will not go into sleep mode when laptop goes into sleep mode the monitor goes to there is not signal check...
Unfortunately, this is a standard problem, as when your laptop goes into sleep mode, it shuts off power to the secondary monitor, without giving it the signal to go into sleep mode. You could try digging around your settings, but most likely you'll just need to turn off the monitor when you're not using it.
Mar 01, 2011 | Acer P205H Widescreen LCD Monitor
Hi I might have downloaded something wrong on my PC, or did something wrong to my flatscreen since every time I shut down for my PC and turn it on again it shows Auto Config in red letters. I didn't do...
Boot up your computer and once it is loaded to your windows desktop, using the image below press and hold the #1 key for about 3 seconds and it will auto adjust the monitor for you. I hope this helps.
Jun 24, 2010 | Acer AL707 17" LCD Monitor
My HP 2009m goes into sleep mode & shuts down
hmmm is it your monitor going to sleep..or the machine? might the computer still be running?
if it's the computer go to power setting and change to your pref
Feb 15, 2010 | Computers & Internet
My hp2009m monitor goes into sleep mode
Monitors are programmed to go to sleep when there is no input. If you shut it down on the other "tower" also it will do the same. You need to physically hit the power button on the monitor to actually shut it off.
Feb 15, 2010 | HP Computers & Internet
Monitor going right to sleep mode on start up
Sounds like a bad graphics card. Try using monitor wit another computer and see if the problem still exists. This rules out the display.
Jul 25, 2009 | HP w1907 LCD Monitor
Hp flatscreen monitor won't come on when i boot my computer
it sounds like your graphics card is conflicting weith your flatscreen , i had a sony desktop do the same thing only on a TFT or LCD monitor , you may want to get a better graphics card , my bet is its probly an intergrated one .
Apr 12, 2009 | Famous Brand F1703 Monitor
Monitor goes to sleep and won't wake up
Yeah, im not sure about how to fix the problem with it shutting down like that, but one option is to go under your control panel and taking off the sleep function, or putting it on a 4 hour timer so that doesnt go into sleep mode anymore. However, the problem is not your monitor but your computer. Id just take the sleep mode off, there is no need to have it on.
Dec 24, 2007 | Computers & Internet
Acer AL1711 17" LCD Monitor Logo
50 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
