SOURCE: RCA universal remote
This is the eastest way to program your remote.
To program a component using the Automatic Code Search method, perform the following steps:
1.
Turn on the component you want the remote control to operate.
2.
Press and release the component button that corresponds to the component you want the remote control to operate.
The illuminated ON-OFF button turns on and remains on.
3.
Press and hold both the component and ON-OFF buttons.
The illuminated ON-OFF button turns off.
4.
After the illuminated ON-OFF button turns back on, release both buttons.
The illuminated ON-OFF button remains on. If you press an invalid button during Auto Code Search, the illuminated ON-OFF button blinks four times and turns off. The last programmed code under that component button is retained.
5.
Press and release the PLAY button.
6.
If, after five seconds, the component does not respond, continue to press the PLAY button every five seconds until the component turns off.
Each time the PLAY button is pressed, the illuminated ON-OFF button blinks ten times while a block of 10 codes is sent to your component. This process continues until all of the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited.
7.
When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
If the component does not respond, continue to press the REVERSE button every two seconds until the component turns on again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks.
If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again.
8.
To save the new code, when the illuminated ON-OFF button turns off, press and release the STOP button.
If some of the features of your component do not work, different codes in the list can be tried until you find the code that allows the remote to control the majority of your component’s
SOURCE: RCA RCR 451 universal remote codes
www.rca.com/customerservice... click the find codes link.. then select your clicker's model number from the drop down box.
The problem is that it does not list the steps to program the remote after you have the correct code. Does anybody have this information?
SOURCE: memorex television, and an rca universal remote, need code
If you are talking about a rca universal remote control, for a memorex tv here are your options 1004, 1006, 1013, 1019, 1047, 1054, 1163, 1167, 1205, 1207, 1213, 1230
SOURCE: rca big button universal remote
Go to: www.rca.com then .... accessories..... (On the left of the page) go to owners manual ..... also check for your code under .... code look up.... if your TV is not listed, use the search feature outlined in the owners manual
SOURCE: RCA universal remote code
i have universal remote rcu704 and i need the code for changhong tv
