My sharp copier AR-5516 is fainting if i'm copying. and i try to chenge the toner and developer but still faint. Pls what can i do again to solve that problem?
2 Suggested Answers
SOURCE: SHARP AR 5012 developer reset
i have a sharp sf 1025 , and i want to reset developer conter? can u help me pls
Posted on Jul 17, 2010
How do i solve an erro f2
F2-02 Toner supply abnormality
The maximum toner supply time is greatly exceeded. CRUM chip trouble Improper developing unit
Jan 12, 2015 | Sharp Office Equipment & Supplies
Sharp AL-2020 - Copier Producing Copies with Faint portions at Top Middle and Bottom of Page
This if often a faulty toner issue. If you are refilling it might be time for a replacement carrier. Alternatively have you checked your transfer belt for areas of damage
Jun 30, 2014 | Sharp SF 2020 Copier
Sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
Sep 02, 2012 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5516 F2 displayed. go to the service mode (C-interrupt- # - interrupt) and enter 14 but not solved please tell me
Hello Sir,
More exactly what is your error? F2-02 or F2-04?
For F2-04 try to change toner cartridge or verify if the chip on the toner cartridge is correct positioned.
For F2-02 you must verify if toner sensor is not dirt, the toner sensor is positioned on back of developer unit, clean very well.
Best Regards,
Dec 09, 2011 | Sharp AR-5516s
My sharp xerox machine AR-5516 is bleaking a man near toner signal point. why is this bleking? Kindly solve my problem.
The blinking man who we refer to as Mr Bill is a "time for maintenance light". Just ignore it, the machine will keep working.
Aug 21, 2011 | Sharp AR-5320 Black and White Copier
I' ve a problem with copier ar 5516. i need information about using of developer. where i must to put the developer? the toner AR-021FT IS COMPATIBLE WITH THIS COPIER?
yes ar021FT toner compatible for your 5516. when replacing the developer:1) pull out the toner cartridge,2) pull out developing unit with 1 screw (blue),3) in developing unit remove 2 screws (blue) to open its top cover,4) drain d unit and replesnish with new developer. do procedure 4 to 1 to return. Good luck.
May 22, 2011 | Sharp AR-5320 Black and White Copier
My machine model is SHARP AR 5520,the problem is that the machine is returning all the toner into the waste bin,all the toner will be sent into waste within an hour or two.this happened when i refilled the...
hello,
problem is your toner cartridge. inside of the toner cartridge have a toner roller it's didn't circling.or you are using duplicate toner powder.it's doesn't match with sharp ar 5520 developer. or your developer was expired.
first use original toner and try to make copies .i think your problem is solved.
Feb 05, 2011 | Sharp AR-5316 Advanced Digital Imager...
AR 5516S SHARP COPIER IS SHOWING F2 4O FAULT CODE DURRING INSTALATION. WHAT COULD BE THE CAUSE. PLEASE.
During installation , use sharp ar205 developer and sharp ar021 toner cartridge. This shows you did not use developer or used the wrong ones, good luck.
Mar 12, 2010 | Sharp AR-5320 Black and White Copier
Sharp digital 5516 drum life indicator along with a man flashing. Also any compatible toner available for sharp 5516.
Try a reset first (Press #, interupt,c,interupt, then 14 start), If it pesist, Check the drum for injury lines, the developer for inpurity and clean the toner catradge proper, the close all machine doors. Good luck.
Apr 02, 2009 | Sharp AR-5316 Advanced Digital Imager...
49 people viewed this question
k24674
jasbo
jasbo
