Question about Whirlpool Microwave Ovens
I have a Whirlpool oven made for ikea Snabb MW3 A8OS and would like a replacement turntable 25cm where can I get one
I would like to purchase a replacement turntable for the said oven I live in Brisbane Australia. Where can I get one
3 Suggested Answers
  • 78 Answers
SOURCE: The turntable on our Whirlpool VT256 oven has
it could be 1 of 3 things here 1 the coupling under the plate mat be warn or broken inside so the shaft of the motor maybe turning but not turning the plate take the plate out and put a cup of water in the unit and see if coupling moves without the plate if not thn see if you can remove the coupling and repeat the test if you can see the motor shaft moving thn u need a new coupling, if not thn you may need a new motor to test th motor you will need to turn the unit on it side remove the plate first on the underside on the unit round where motor is you will see a plate this will round or square you need to cut this away to expose the motor dont throw it away as you need to refit if after, it turns round and you screw it back on, when you have found the motor remove and replace it albeit the motor is powered by the pcb it is unlikely to be the pcb as the motor runs all the time so they do ware out also do look to see if your unit has a turn table switch off button on the controls or in the manual hope this helps and dont forget to unplug ur unit from the mains.
Posted on Oct 19, 2009
  • 949 Answers
SOURCE: MANUAL FOR A WHIRLPOOL MICROWAVE OVEN SOLD BY
Here is a link to the manual on line.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10259811A.pdf
Posted on Apr 25, 2010
Manual for a whirlpool microwave oven model wmh31017aw-1
There is no turntable control. It is always on. The turntable should change direction each time the unit is used. If the turntable is not operating, it has malfunctioned. Newer microwaves for the most part all have full-time turntables to promote even heating, thus reducing customer complaints about ovens that don't heat right.
Dec 30, 2015 | Whirlpool Microwave Ovens
The start button on my Ikea Whirlpool microwave won't depress. Any ideas?
Switch has broken internally and it needs to be replaced. OR if you are handy, often the switches can be removed, taken apart and fixed! Takes a little patience and moxie but dooable.
Nov 07, 2015 | Whirlpool Microwave Ovens
Settings rubbed off oven
Maybe you can take a good picture of it and contact whirlpool??
Or IKEA?? Maybe they'll have records of the previous owner or the address of the installation ??
Nov 02, 2013 | Whirlpool Microwave Ovens
The turntable wlll not turn.
The only way to fix this problem is to replace the turntable motor in the microwave oven, a common issue with most brands.
Jul 10, 2011 | Whirlpool WMH2175XVQ Microwave Oven
While changing the light bulb on the bottom of Whirlpool MH1140XM, the bulb popped. I replaced it but now all I get is a hum whether I push timer, light or oven settings. The oven appears to be heating...
Hello, Thank You for using FixYa. I will be helping you today.Make sure no wires were pinched in the process. The turntable motor runs off the board that's why im thinking you have a grounded wire somewhere.
Thank You and please rate my answer if it was helpful..
Jun 19, 2011 | Whirlpool MH1140XM Microwave Oven
Whirlpool MH1150XMB
Driver turntable or turntable motor needs to be replace
Aug 24, 2008 | Whirlpool MH7135XE Microwave Oven
Ikea micro wave whirlpool
F3 usually means a keypad or temperature sensor / thermistor problem.
The fact that you can't use the microwave leads me to believe it's a keypad or control circuit board problem.
If you have the owner's manual that came with the unit, I would suggest you look there for a contact numer to call for service.
Otherwise I would suggest calling the store from which you purchased it.
Please write back with more details if you need further help.
Nov 20, 2007 | Microwave Ovens
Microwave Ovens Logo
214 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Jaime Hernandez
Gerry Harvey
Gerry Harvey
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
