Question about Roxio Easy CD & DVD Creator 6 (cdrvlpe6101250) for PC
Error when attempting to write disk
When I attempt to write a CD-Audio disk through Roxio Creator 6, the disc ejects and this error message appears:
"E80041845: Command Error - Invalid field in parameter list - [05/26/00]"
I've tried toggling all settings in the program, and cannot find much help via Roxio's site. I am having difficulty finding the original disk, but if needed could dig it up...somewhere...
Thank you for reading my problem!
-Nate
  • Nathan Morrissey
    Nathan Morrissey Jan 26, 2009
    Well, "repairing" the program did nothing at all. So I finally hunted down the original CD with the software and un-installed and then re-installed the program and viola! it works perfectly.
    I need to break my addiction to Roxio products...
  • notme1 May 03, 2009
    A "cannot access drive" when trying to backup dats to CD or DVD
    Scholar:
  • 54 Answers
Sometimes the driver that is used to burn CD's gets corrupted, you should try removing and re-installing roxio. The only other possibility is a bad CD burner drive, but these are dirt cheap to replace these days, you should easily be able to find one under 40$.
Posted on Jan 20, 2009
I have roxio Creator 2011 PRO. When attempting to install, error message says this product will not be installed .
is this an upgrade? if so and you don't have the origianl on your computer, it may not install
Mar 19, 2011 | Roxio Creator 2011
In Roxio Creator 10, I attempt to burn a disk of a slide show. I receive an error message 8004520C When I check production it reports no problem. This is repeatable.
Generally, defragmenting your hard disk will resolve this issue. To defragment your computer:
  1. Go to Start--> Programs --> Accessories --> System Tools --> Disk Defragmenter.
  2. When the Disk Defragmenter window opens, choose Defragment.
If defragmentation doesn't resolve the issue, burn your project as a data file, and then burn your project as a data disc using Disc Copier or Creator Classic. To create a disc image/data file:
  1. After clicking the Burn button, the Burn Project window opens.
  2. You have two data burning options:
    • Image file - this option will save your project as an .ISO file. To burn this file you will need to use the Burn Image option in Creator's Copy section.
    • Folder Set - burning a folder set will create a Video_TS folder that you can burn using Creator Classic. Burning a folder set to DVD will create a fully functional DVD. Do NOT rename the Video_TS folder other wise it will not play! Simply place it in a folder that is the name of your project if you need to keep track.
May 25, 2010 | Roxio Easy Media Creator 10 Suite
Cannot burn AVCHD disk. Get this error
The problem with creator 2009 has been fixed by the roxio people.
Instead of burning directly to the DVD disk as roxio software states,
one needs to first save this to be AVCHD movie as a file and then burn directly from the file. This works OK, but as stated this is different
from what the software claims. I'm happy. Thanks
Aug 01, 2009 | Roxio Creator 2009 Ultimate for PC
Cannot make mp3 files from cds
Don't bother using Roxio for this - use Windows Media Player 11.
1. Open Windows Media Player
2. Run the mouse over the "Rip" tab - a small aroow should appear underneath the word "Rip" - click on the arrow and a drop-down should appear.
3. Select - "Format" - change to "mp3"
4. Now insert your CD and press the Rip button - by default, Windows Media Player will store the mp3 files in the My Documents --> My Music folder
Now use Roxio to make a CD out of the Mp3 files
-Tha Mp3 Doctor
Mar 20, 2009 | Roxio Easy CD & DVD Creator 6...
Lost product key code
i have roxio in my pc,  when i click the icon, i get a message saying your last command could not be completed, an unknown error.
how to solve this problem
please help me
yogaraja62@yahoo.co.in
Nov 17, 2008 | Roxio Easy CD & DVD Creator 6...
DVD recording freezes up
Freezing like this is usually a sign of lack of memory.
Ensure all other programs are shut down.
Burn fewer files at a time
Aug 30, 2008 | Roxio Easy CD & DVD Burning
Error
The manual states
1. " An (ERR_) message will appear, then change to a flashing (DISC), then the CD will be ejected."
You will have 5 uninterrupted attempts to insert the correct CD.
2. After the 5th incorrect attempt, the display reads (HELP)
3. If (HELP) appears on the display, press button (6), then the (FUNC) button, and hold them for 5 seconds.
4. Press the (FUNC) button. You will have 5 more attempts to insert the correct disc.
IF AFTER 10 TRIES, AND IF THE CORRECT KEY CD HAS NOT BEEN INSERTED, THE DISPLAY READS (CALL 800); THE UNIT MUST THEN BE RETURNED TO ECLIPSE TO BE RESET. CONTACT ECLIPSE DEALER OR CALL (800) 233-2216.
Jul 19, 2008 | Eclipse CD3422 CD Player
Cannot Initialize API
1. Try to launch Creator Classic to see if it can repair the engine files. a. Double click on the "Roxio Easy Media Creator Home" icon. b. Click "Creator Classic" under the "Applications" section. c. The Windows installer should launch and ask you to insert your installation disc
Try this and see how it works, if it does not, contact me and give me more details
Mar 25, 2008 | Roxio Easy CD & DVD Creator 6...
Message of an Error
error 6 means that a disc is loaded upside down.
eject the disk and reload it properly
if that isnt working, your CD player is mal-functioning and you should consult Clarion for help
J
Mar 12, 2008 | Clarion DXZ845MC CD Player
Roxio Easy CD & DVD Creator 6 (cdrvlpe6101250) for PC Logo
204 people viewed this question
Top Roxio Computers & Internet Experts
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
