Question about Dell XPS Computers & Internet
XPS 410 won't boot but CPU fan spins
I recently wiped the system clean and did a fresh install of XP Home Edition. I was recently having some Blue Screen of Death (BSOD) problems so that is why I did the clean install. Everything seemed much better but I got a few more BSODs. Usually it rebooted just fine but this morning it just stopped booting up with the CPU fan spinning very loudly. Does anyone have any ideas as to where to start trouble shooting or has this 6 year old machine just seen its last day.
    Sergeant:
  • 214 Answers
A loud CPU fan will also equate with overheating and imminent failure. Can you reliably access your system BIOS? Can you run a memory test there? If so your CPU is functional (and your memory which is also subject to overheating and BSOD under XP. If those are good your prime suspect is your HDD. If you can afford it, now would be a good time to replace your system.
Posted on Jan 09, 2013
3 Suggested Answers
  • 82 Answers
SOURCE: Gx270 dell During istall of OEM XP I get blue screen codes 24,8,&
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 41f927c.jpgd3990ed.jpgALL these systems suffered from defective capacitors caused by bad manufacturing at the component factory. I have put here a pic or two for you to see what defective caps look like. Call Dell and ask them. I some case a while back they were doing a free motherboard replacement. The problem causes a whole raft of errors to occur from blue screens to "thermal event error" and the only thing that fixes it is to have the motherboard replaced. Hope this helps you
Kind regards from London
Mark
Posted on Aug 25, 2009
Testimonial: "the poor gal paid twice the value for it already .... Since this is a favor I will tell her the bad news and have geek squad confirm it .... "
  • 142 Answers
SOURCE: i have an hp pavilion a1410y. the computers
The reason it wont boot from your other hard drive is because windows is expecting some different hardware on *********** bored, gets stumped and falls down.
On your computer there should be a license sticker. This will be rectangular with a green pattern on it. It will have your product key for what ever version of XP you are licensed for. You can place the drive which matches your version in your computer. Then, in order to get that install running on the new board, you will need an OEM copy of the appropriate windows disk. you may have received one with your HP, or talk to your geek friends who may have one.
to repair the load, boot off the cd. You will come to a window where you can press R (dont press R) for recovery console, F3 to quit, and Enter to continue. Then you will see a license. Press F8 to accept it. Then you will see a thingy that says "serching for previous versions of microsoft windows". Then it will show you the partions on the drive. select the OS one, usually marked "C". And there should be an option to press R for repair. Now you can press R. It will ask you for a product key. That is the one on the license on the side of the computer, also known as a COA (Certificate of Authenticicty). It will ask you for some other things too, like user names etc. Then you get to go hunt for drivers on the HP website. Lots of fun.
Posted on Sep 01, 2009
XPS-410 needs to have MCE 2005 Rollup two SP3 replaced by Windows 7 64 bit. Too many problems to list currently but will work limited programs
Not sure what you are trying to do. If you are trying to convert 32 bit to 64 bit Apps, try going to manufacturers website to look for drivers.
Win 7 will actually find the best drivers for your devices.
May 06, 2014 | Dell XPS 410 PC Desktop
I have a Dell XPS M1710 laptop that was originally Windows XP (maybe Media Center Edition, I'm not sure) and had Windows 7 Ultimate on it. I had to wipe the hard drive and I downgraded to Windows
Hello the driver can be downloaded here:
http://www.dell.com/support/drivers/us/en/04/Product/xps-m1710
Or here at nvidia:
http://www.nvidia.com/object/geforce_notebook_winxp_179.48_beta.html
Please check for other drivers missing in the device manager.
Check also for the right driver, because here is 2 different ones.
Try the nvidia page first, this should work for you.
Good luck
Mar 09, 2013 | Computers & Internet
My dell xps won`t stay on
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Apr 15, 2012 | Dell XPS 410 PC Desktop
My pc says"boot failure,insert boot diskette in A"
If XP was not installed on the HD from your computer then the computer won't boot from it. Reinstall it.
The system may not see your HD. As you boot, go to the boot menu and see if the HD is listed. - If it's not, see if the HD is well connected to the motherboard. - If it is then re install XP.
Sep 16, 2011 | Microsoft Windows XP Home Edition
Yes expert ntldr missing
It means that your computer is missing a file that windows xp needs to run boot properly or is missing a program that your home edition xp needs. Repairing the OS or windows xp home edition by means of your xp instalation cd will do the job. Just insert your xp installation disk to your cd/dvd rom and select install windows xp home edition. Then select ( repair ), and so on let it finish repairing . Once your system rebooted, let it run without pressing enter or space bar. Just watch and let your computer do the job. This will probably solve your boot problem. But before doing all of this, please check your IDE or SATA cable and also the power cable that is connected to your hard drive. Try to unplug and plug again to ensure a good connection. If this won't work, you can proceed repairing Your windows xp installation or reinstalling a new xp operating system. Have a nice day and i hope i was in any help to you friend.
Aug 18, 2011 | Microsoft Windows XP Home Edition
I recently aquired an eMachine 566i2 with Windows ME. I upgraded to Windows XP Home Edition. The computer was running very slowly. I ran anti-malware and various utility programs, but there was no change....
The 566i2 has a Celeron 566MHz. That is very slow system compared to today's
standard. I'd suggest doing a fresh Windows XP Installation with the Hard Drive
formatted as NTFS. You need to be sure that the HD is completely wiped out
and clean. Also, download all the drivers necessary for Windows XP beforehand
and put them on a CD. That will save you lot of time after the installation.
Jul 19, 2011 | Microsoft Computers & Internet
It is not starting up
Good day. I suggest for you to reinstall windows and use the repair options. Usually software encounter errors or some files might get corrupted causing your computer not to boot up properly. The repair option in Windows XP will help you to fix those issue. here are the steps to follow:
1. Rule out hardware issues. Windows Repair will only fix software problems. Hardware issues can also cause boot problems (i.e. bad hard drive, memory, CPU, or power supply).
2. Backup. It's always a good idea to backup your important data before making changes to Windows XP. Relax, if you follow these instructions your data will be perfectly safe.
3. Boot from your Windows XP CD. Insert the Windows XP CD into your computer's CD-ROM or DVD-ROM drive, and then restart your computer. When the "Press any key to boot from CD" message appears on the screen, press a key to start your computer from the Windows XP CD.
4. A blue screen will appear and begin loading Windows XP Setup from the CD.
5. When completed loading files, you will be presented with the following "Windows Setup" screen, and your first option. Select "To set up Windows XP now, press ENTER". DO NOT select Recovery Console.
6. Then press F8 to continue
7. Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation, or install a fresh copy of Windows XP.
8. Then just choose repair option to repair your Windows Xp
9 Then it should work. If iin any case that will not solve the issue, you might try to install fresh copy on Windows Xp
Hope this information will help you resolve your issue. Have a great day.
May 24, 2011 | Microsoft Windows XP Home Edition
PC shuts down without warning and then re-boots automatically about every 20 minutes or so .
you have an internal error in system files. technicaly the only solution is to restore win xp using cd provide by manufacturer and install a good antivirus, (i will recommend avast home edition works great and free)
Oct 10, 2009 | Microsoft Windows XP Home Edition
Laptop won' boot up.
The blue screen means the system is experiencing a fatal error... a error from which it cant recover.... so while booting press f8 and boot using safe mode... then analyse the startup programs of your system using Start->Run and then typing msconfig in the window that appears and then going to the startup tab... one of your latest installed program might be misfunctioning....
Nov 19, 2008 | Compaq Presario Notebook
Computers & Internet Logo
91 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
