Question about Dell Inspiron Computers & Internet
My Dell Inspiron 1564 pc is slowing down. What should i do?
I bought it around 2 years ago it was very fast in first 1 year. but from some moths I am watching it is not working so fast it is slowing down. and i cannot play games smoothly even when their graphics requirements. its booting speed has also slowed up.
SOURCE: Copies super slow (as in best mode) even when i set it to "fast"
you may need a fresh set of drivers on this..
www.hp.com
Posted on Aug 20, 2008
ziraffa
  • 827 Answers
SOURCE: my dell inspiron 1505, has very slow start ups, use to be fast
download ncleaner
http://www.nkprods.com/ncleaner/
i use it for cleaning up my computer but after you install it you can click on the far right button concerning 'startup items'
uncheck boxes for programs such as messenger, skype, 4od, iplayer, limewire, utorrent etc but do not uncheck any programs that you are not sure of what they do. most slow boots are to do with people installing programs and not unchecking the box that says 'run when windows starts'.
there is a method for deleting 'prefetch' in startup too, but i would suggest you try the first method i mentioned first, as the 'prefetch' option can cause all sorts of problems if you are not 100% sure what you are doing..
ncleaner is a great program anyway, you should definitely use it to clean up your computer, although when i first ran it, it deleted everything in My Received Files, so copy everything out of there to somewhere else first. :)
good luck
chris
Posted on Dec 13, 2008
  • 479 Answers
SOURCE: Dell inspiron 6400-runs slow on AC power but not on battery
uninstall any energy management software provided by dell and then check.if the issue is not resolved then the issue is with the converter board as it is heating up.
Posted on Jan 29, 2009
SOURCE: Laptop Mousepad and Keyboard stuttering, slow
This may be a battery power monitor issue. Try disabling the "Mircosoft ACPI- Compliant Control Method Battery" device. This is located in Control Panel-->System-->Hardware Tab-->Device Manager-->Batteries. Had similar problem with 2 Acer Aspire series laptops (diff models). 2 and 3 year old. Original batteries (both still hold charges for 1.5 hrs of normal usage). Running WinXP, one with SP2 and other had SP3. Both came in the last month with slow jerky TPAD function and nearly non responsive keyboard access. Checked the usual; virus, spyware, hijacking, driver conflict etc. Cloned drive and factory installed..still same problem with kb & mouse. However an external USB keyboard and mouse functioned normally (no lag). Noticed with Battery removed kb & mouse was normal. Finally found disabling ACPI control battery device resolved this issue while allowing laptop to run on either battery or AC.
Posted on Feb 05, 2009
  • 3940 Answers
SOURCE: Dell Inspiron 9400 display goes blank after a few minutes
If the issue occurs in the safe mode, then I'm suspecting a failure of the LCD backlight. (It warms up and quits) Also see if video stays on using an external monitor. If it does, then the LCD is most likely failing.
If video goes out on an external monitor as well, then the Video card is failing due to overheating. Make sure all vents are free of dust (Clean with canned compressed air) and the all fans are functional (Run the fan test in diagnostics) If fans check up, then video card is failure point. If fans fail diags, replace affected fan 1st
Posted on May 22, 2009
My Dell Inspiron 1564 beeps 5 times (1-2-2) and will not star
In Dell computer, 5 beeps usually means there is some issue with the CMOS battery. Still, you are advised to contact nearest service center to confirm if this is the issue. The following link can be useful to know more about Dell beep codes and for Dell contact information:
http://www.dell.com/support/Article/us/en/19/SLN293445/EN
GuruAid.com
Mar 29, 2015 | Dell Inspiron i15648634OBK 1564 Laptop...
I bought this DELL D600 about 3 years ago for my fiancee, now my wife of 1 year, and have had a lot of problems with it
it is HIGHLY doubtful that your internet speed is faster than 54Mbps, and would be little difference in performance.....
Especially given that most webmasters throttle their websites to around 3Mbps. If the website your're trying to load is only sending it @ 3Mbps, then both cards should load it similarly.
Your difference is FAR more likely in the DRIVER(s) being used, (or attempted, but not properly removed.)
Tallon41
Sep 07, 2012 | Dell Latitude D600 Notebook
I bought a Dell Inspiron 1318 about 3 years ago, new. About a year ago my battery stopped taking a charge. I just decided I needed to buy another battery online from BattPros.com. I followed the...
Hi
Check this
When your shut down your computer and plug your the charger in your laptop that time Orange lite is showing on. if no showing then its problem to your laptop
Jun 05, 2011 | Dell Inspiron 1318 Laptop Computer PC...
I have Dell inspiron 1564 (windows 7 64 bit). The monitor goes blank with a screeching noise. I have run the PSA diagnostics but it showed no problem. The laptop runs normally otherwise but this problems...
I now have the same problem with the same Dell model (1564) for the second time in less than a year from purchase. The last time it happened I called the service technician who fixed it. That makes me wonder if this may be a common defect in this dell model, which requires a technician visit every 4 months. I advise you to apply to the company and ask for solution such as providing you a different model as a substitute for the defective one.
Sep 23, 2010 | Dell Inspiron i15648634OBK 1564 Laptop...
My laptop is dell inspiron 1501 but no work keybord and battery charging but supply line(AC adaptor) is ok.
Hello there. The Inspiron 1510 was released almost 5 years ago. If your system is more than 2 years old, then perhaps you will have to replace the battery. Battery for the most part, will only last 1 to 2 years. As for the battery, try connecting an external USB keyboard. If its working, then you need to replace the laptop's keyboard. Hope this will help.
Mel
Feb 13, 2010 | Dell Inspiron 1501 Notebook
Dell inspiron 1564 xp problem
There is a firmware update listed for January 10, 2010 on the Dell website. I would recommend punching your Dell Service tag into the driver and support section of the website and downloading/installing the bios update. If this does not resolve your issue comment back and we will move further.
Good Luck,
NOLA Tech
Jan 28, 2010 | Computers & Internet
Fast overheating inspiron 9400
This sounds like the system has glitched. Do a system repair with your recovery or operating system disc. This should clear the glitch, get it back up and running, and cure the overheating problem. Try this and get back to me if there are any issues.
Aug 07, 2008 | Dell Inspiron 9400 Notebook
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
