Question about Fuji FinePix S7000 Digital Camera
Won't stay turned on
I just purchased this camera today. It's been fine and I was pretty happy until now. I have fully charged batteries in it. I was exploring the evf/lcd button to check out the viewfinder. The camera shut off. After a minute or so, I tried to turn it on. I had a brief blip like it wanted to turn on and then nothing. For a bit, I was able to turn on the playback screen with that button. Then, I tried the evf/lcd button again and the same thing happened. I can't get it do anything. Can someone help, I'm pretty bummed out right about now.
  • Dar Cole Oct 16, 2007
    Thanks for the suggestion. I did take the camera back and got another the next day. But, I will remember that about the batteries though. I use rechargeable ones but do know that the AA e lithium from Energizer lasted a long time.
  • 3 Answers
Ok well the camera has a power down setting from 2 min to 5 min if you leave it on by mistake to save your battery life.
so turn to set and go down the list to power save. R click to 2 min 5 min or off. Now if you turn it off it will not shut down till you turn it off. But its kind of not easy to forget to turn off as the lense stays extended. if your batteries are low in power it will shut off after a very short time.
so my advice turn the power save off nd stack up on batteries. they are cheep as ships and the turning off to save the power can be the loss of a great pic
happy snapping to you
Posted on Dec 07, 2007
You have to use an e AA battery.  The regular AA batteries do not work in this camera
Posted on Oct 15, 2007
Since mine was only a day or two old, I took it back to the store and got it replaced. Since then, it's been fine. Hope you have the same option.
Posted on Sep 01, 2007
My Olympus Stylus 7030 won't focus and shuts off when I try to zoom.
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jul 29, 2012 | Olympus Stylus 7030 Digital Camera
Battery won't stay charged
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jan 16, 2012 | Kodak EasyShare Z740 Digital Camera
I have a Sony AX Digital 100 Camera. I used it yesterday and everything worked fine. Battery is fully charged. Tried to use it today and it won't start. I have taken the battery in and out and even...
Does there is something happened when you turn on the camera? If you can heard sound made by the len or the camera try to open but turn off in a second? If so, there is something wrong with the lens, and this how to fix camera lens error will be helpful. Else, if the camera are without any reaction you can check it the joint of the camera to battery is well.
May 20, 2011 | Cameras
My camera wont stay on it bleeps once then turns off
That sounds like your battery could be dead/not hold a charge. If you've charged your battery already and your camera still won't stay off and turns off right away, it's time to purchase a new battery for your Samsung TL105.
You can purchase replacement batteries quite cheap here:
http://www.amazon.com/Samsung-Digital-Camera-BP70A-Battery/dp/B003OEDQBE
May 07, 2011 | Samsung TL 105 Digital Camera
Hello, I have had my NIKON D3000 with a 18-55 mm VR lens since Christmas. However, today when I turned it on, nothing would happen and the screen would stay black. I charged the battery until fully...
Hmmm, this may sound silly, but make sure the lenses is up :) This may help hopefully :) Make sure the battery is inserted properly......
Jan 08, 2011 | Cameras
Canon EOS Rebel problem
This is usually caused by a defective shutter release switch - it'll have to go into a repair shop - independent shops will charge about $110 USD - Canon charges about $180
Nov 26, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Help
Wow, this is trully amazing. I went to do a search on why my camera wouldnt turn on the past couple of days, even after i charged all THREE of my batteries and found similar complaints within the same time frame!! WOW. We need to get together and fight this, cause its suspect!!! I bought mine in Mass, anyone else?
Jun 30, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Motorzor
you simply fried your battery by overcharging it. Just get a new one, let it fully charge and fully die twice before you start normal charging. Then you will want to only charge it for about 2 to 3 hours or find a charger that has a smart chip that tells it when to stop charging once the battery is full.
May 13, 2007 | Motorola Mobility RAZR V3
Fuji FinePix S7000 Digital Camera Logo
215 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
