Question about MSI K8MM-V Motherboard
MSI-Board K8MM-V starts immediatly after turning on power
I've bought a used MSI K8MM-V board and I've tried to get it running. The board has started immediatly after I've plugged in the mains plug (no need to press the power switch). The CPU fan has been running, but I ahvn't got any video signal on the sreen, nor a error signal from the board. I checked the power supply with my old board and it worked fine. What can I do to fix the problem? How can I find out, if the motherboard is ok? Could it be problem caused by transport (the board came to me with the mounted CPU + fan and the mounted memory - it was wrapped up in a kind of a foam foil) Thanx in and advance for any helping answers.
  • Roland Dietz Jul 04, 2007
    I had no user manual and I didn't know that the ATX specification has changed. My power supply is too old and doesn't support the ATX 2.x specification.
    It seems that I have to buy a new power supply.
  • 432 Answers
Unless the on-board video is bad. I found this website from MSI Corporation. It explains in detail (with pictures) troubleshooting techniques you can try. I hope this helps. Please write me back and let me now if this helps. http://www.msicomputer.com/support/sup_tshoot.asp
Posted on Jul 01, 2007
SOURCE:
I want to msi 7142 mother board drivers pls send it
try this one :
http://www.driverstock.com/download-MSI-K8MM-V-driver/14-9-11420/index.html
Apr 10, 2010 | MSI K8MM-V Motherboard
HOW TO INSTALL WIN XP ON SATA HDD ON MSI K8MM -V M/B
If your copy of Win XP does not recognize the SATA drive (i.e. Early copy of XP) you will need to use the F6 option and load the SATA driver that came with the MSI mother board.
Mar 24, 2010 | MSI K8MM-V Motherboard
Ms 7142 Msi board, cant install xp with sata hdd
I think this is your board, K8MM-V. The following is the link to all drivers and info regarding said mobo:
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=173
Dec 30, 2009 | MSI K8MM-V Motherboard
How do you download free drivers for msi 7142 board
http://www.msi.com/index.php?func=prodpage1&maincat_no=1
go to that site and browse for your needed drivers
Nov 18, 2009 | MSI K8MM-V Motherboard
Need of motherboard driver ms-7142
Your board is actaully listed as a model K8mm-V on the MSI website. Here is a link to the MSI page with the correct drivers for your board. These will work for Version 1 or 2 boards:
Hope this helps...
Sep 19, 2009 | MSI K8MM-V Motherboard
No Display
hi, when you start your computer its giving a beep if not check your memory(Ram) remove it and check it your motherboard giving a continous beep, if yes replace your ram
Sep 26, 2008 | MSI K8MM-V Motherboard
MSI 7142 and via vt 6237r audio driver problem
You need to confirm the board model number before I can find drivers.
Is your board a K8MM-V ? This was the only board that came up when I did a search with 7142 on the MSI website.
Did you load the VIA Smart5.1CH Sound Drivers for K8MM3-V/K8MM-V/P4MAM2-V ?
Also please refrain from rating solutions after 1 reply. Sometime it take more than 1 attempt to solve your problem. The aim is to get dialogue between us to understand the issue, clarify the need and find a resolution.
I look forward to your reply so I may continue to assist you.
Jul 07, 2008 | MSI K8MM-V Motherboard
How to connect ATX PWRSW to K8MM-V (MS-7142) board
You have a MSI mobo - goto the URL listed below, you will find everything there is to know about it there. Best.... PCrx4u
http://www.msicomputer.com/product/p_spec.asp?model=K8MM-V
Dec 29, 2007 | Computers & Internet
MSI K8MM-V Motherboard Logo
94 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
