Question about GE Cooktops
F112 error code
Code F112 appeared The cooktop kept beeping, The light stayed on showing that the left front burner was hot but it wasn't. Tried turning circuit breaker off for a few minutes. It cleared everything except the light came back on for hot burner.
fridgetech
  • 473 Answers
SOURCE: ge profile ceramic electric cooktop
No recalls that I know of.  The switch for that burner has shorted and will need to be replaced.  It will be fine once it is repaired.
Posted on Oct 26, 2007
SOURCE: Right front (large) burner indicates hot, won't work, flashes F153
I hade a code 153 also. Changed the element(costly-$200) and had to recalibrate the pan sensors(in the manual). All works fine now.
Posted on May 29, 2009
  • 116 Answers
SOURCE: Jenn Air Gas cooktop burner ignition
Hi JHMcdona
Most likely the electrode for the right burner is defective. As well as the switch may also be defective (is shorted because of pressing hard on it trying to make it work!!). Change the electrode and igniter switch of the right front burner.
Regards
Posted on Aug 26, 2009
SOURCE: Amana gas cooktop clicks when not in use
Take a look at the solutions that have been posted regarding igniters. i suspect a dirty or wet push-down knob. you will see that others have had water/moisture causing problems. drying mights solve it, but it may need a a bit of a clean. keep trying. it must have taken me a couple of hours to solve.
Posted on May 08, 2010
SOURCE: f113
I have the same problem. I had a repair man here and he said the main powder logic board ( WB23T10014) was the problem, it would cost $757 to fix. I ordered the board for $230 and installed it myself but still have the F113 problem.
Posted on Feb 06, 2011
E039
Usually E0 39 or E 39 or 3 039 is mismatch between your new board and current boards. Do a reconfig: install new board. Plug in. If you get the 39 code push one of the burner on/off buttons to make the beeping stop and blank display. Then, push and hold right front and right rear UP buttons simultaneously until 88 appears in display. Then press and hold left rear and left front UP buttons until beep sounds and configuration starts. A few seconds later it should clear and be all set! Hope this helps.
/uploads/images/9_6_2014_11_25_49_pm.jpg
May 07, 2014 | Cooktops
GE profile JP969 fault code F113
I took the cooktop apart I removed the terminal from the main electronic board . The left front burner has 2 white wires and 2 yellow (my case). The 2 white wires lead to the RTD sensor.With an electric meter set on OHMS check continuity between the two wires leading to the RTD sensor .If the reading is more than 1030 ohms is good if not than you need to replace the whole burner that comes as a complete unit with sensor and ribbon heating element.I found it on line for $114.00 +shipping.I wish they sold only the sensor but it would've been too cheap and not worth it for the makers . All connections to that burner are very easy put back together . Some suppliers may ask for as much as $175-$195 for the complete unit .
Apr 11, 2012 | GE 36 in. Profile JP969 Electric Cooktop
Burner light stays on
This is caused by a faulty sensor that is located between the burner element and the top. To replace the faulty part you will need to uninstall the cooktop and remove the glass top. The sensor is a rod a little smaller than a pencil that you will see right on top of that burner.
If you choose not to replace the sensor it will not cause any issues other than you will have to live with that light constantly on and you will know when the top is hot for that element.
Jun 19, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
F113
Jan 21, 2010 | GE 30 in. Profile JP938 Electric Cooktop
Hi JHMcdona
Regards
Aug 26, 2009 | Miele 35 in. KM326G Gas Cooktop
May 21, 2009 | GE Cooktops
Whirlpool Flat cooktop burner not heating up
Try cleaning the knobs. I did the same thing you did (turning the circuit breaker off but that did not solve the problem.
My wife just tried turning the knobs and that seemed to work. It appears that one of the knobs may have been so sticky that the though it's in the OFF position it thinks it's still ON.
Jan 12, 2009 | Whirlpool RCC3024 Electric Cooktop
Cooktop light stays on when cool
the "hot top" indicator lamp is switched by a contact on the plate cut-out. sometimes this cut-out is available as a separate part but often must fit complete plate. by plate i mean the bit that gets hot!
Mar 28, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Cooktops Logo
21 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
