Question about Pioneer Audio Players & Recorders
Pioneer sc-1227 firmware update stuck at 55% for the last hour while updating firmware via usb - what to do?
Trying to update firmware via usb - progress stuck at 55% for the last hour
SOURCE: update problems
put the two files "ypp2.rom, ypp2.rsc" both in the root and the folder "datecasts" before you upgrade
Posted on May 10, 2008
  • 4 Answers
SOURCE: firmware problem for zen vision M
I had the same issue with my zen vision m. It was not recognized on any computer (although it would charge) and I noticed that when I turned it on after having it off for any amount of time, the zen would rebuild half way before turning on.
If this is what is happening with you, then this one solution I found to fix it:
Download the MP3 Recovery Tool from Creative Support website. Make sure that your Zen is charged at least half.   Turn on your Zen, Holding the power switch in the on position (Very Important!). While holding the Power switch on, Reset the Zen by inserting a small object in the Reset hole on the bottom of the Zen (small objects can include thumbtack, wire, earring, etc...). You will see a menu: Clean Up, Format, Reload OS/Firmware, Reboot. (It is now safe to stop holding the Power switch) I decided to go down the list until something worked.  I ran Clean Up first and that didn't work for me, so I tried Format.  It will remove all of your data. Once Format runs, Reboot the MP3 player and plug it up to the computer. Run MP3 Recovery Tool. The firmware should should install itself on your MP3. Once installed, your computer should recognize the Zen.
I hope this helps!
Posted on Nov 29, 2008
eclark317
  • 159 Answers
SOURCE: my opal 4208 rd won't play audible files
Some players need license to play. One way if you can use a program such as nero, super sound recorder, media coder to name a few and record the songs again and then just copy and paste the song into the player. There are alot of free programs that do that. you can email and I will send you a list of free programs that do that. mrbruc3l33@yahoo.com
Posted on Jan 08, 2009
SOURCE: firmware update went wrong
What operating system are you using? The Zen Touch firmware update will fail in Vista or 7 -- you need to run the update from an XP install. Once you successfully get the 2.11 firmware on the Touch, it will then interface with those later OS's without difficulty. Also, what version of Windows Media Player are you running? Believe it or not, this makes a BIG difference. The latest Media Player 11 will cause the firmware flash to fail, as will WMP <= 9. I have three separate players that have experienced this problem, including one that had been disassembled THREE YEARS AGO after a failed flash, and was able to resurrect all utilizing this method:
(1) Uninstall everything Creative: the driver, Jukebox, etc. Delete the Creative folder from Program Files. (Some amendment to these instructions may be in order if you have a Creative sound card -- I have built-in Realtek sound so it didn't apply in my case). A restart may or may not be required: go ahead and do so to be safe.
(2) Plug the device in after restart. Windows will want to find drivers for it -- cancel that process. Open the Device Manager. The Touch should come up with an exclamation point next to it (since the drivers were not uninstalled): right-click and select "Uninstall." I have seen instructions on the Web to also uninstall all USB root hubs, but I have found that unnecessary and a pain if you have a USB keyboard and/or mouse. Unplug the device. Restart.
(2) If you are running a version of Windows Media Player not equal to 10, either install 10 (if you have 9 or below) or roll back from 11 if you have that. Restart.
(3) Plug the device back in. My supposition is that this is particular to WMP 10, hence the problems with other versions. The device should pop up as "Creative Zen Touch:" if Windows asks to find drivers, cancel that process, and the device should now come up as an "MTP device."
(4) Since the firmware flash failed, the Zen is probably in recovery mode. Launch the firmware updater software on the computer, and stay at the language selection screen. Choose option 3, "reload firmware," from the recovery menu. It will inform you that it is "deleting old firmware" and then will give you a short period of time with a dialog saying "start firmware update" on the Zen screen. During this time period (about 2 secs), press the language selection of your choice on the computer in order to start the update. It should go through successfully this time.
Posted on Jun 10, 2009
wiqi546
  • 1511 Answers
SOURCE: i have a sony lcd and i want to update it
No, Brother.
Sony LCD will only accept "Sony Micro Vault"
So try using sony Data Treveller.
KIndly Do Rate, If helpful.
Posted on Jul 17, 2009
Ue 22 error on pioneer sc57
This means that the firmware update has failed, see page 82 of the manual, http://www.pioneerelectronics.com/StaticFiles/Manuals/Home/SC-57_OperatingInstructions060711.pdf . You should try updating the firmware again. If you used a USB drive to move the update to the receiver from your computer, make sure that the file was unzipped and that there were no other updates on the drive.
If the update fails again, the chip that stores the firmware is damaged. The chip would need to be replaced. This has to be handled via Pioneer repair. The chip is not sold to the general public, to the best of my knowledge.
I hope this helps.
Dec 24, 2014 | Pioneer Elite Sc-57 Receiver 9.1 Class D3...
Why is the vsx-50 flashing ue22
Guys, all you need to do is download the "firmware" file from pioneer website and upload it to a usb, stick it in the USB port of your amp, then "update via USB" -voila. Good luck all! God Bless
Dec 14, 2014 | Pioneer Audio Players & Recorders
Mitsubishi WD-60638 firmware
Make sure software was in top menu in USB stick. Not ib a folder. Try reset buttons on front of TV. Could be bad e2p module. (boot firmware.)
Mar 30, 2014 | Mitsubishi WD-60638 DLP TV
Update wont complete firmwate update
Try holding down MAIN ZONE on the front panel for more than 10 seconds to initialize and reboot the unit . :)
Jan 26, 2014 | Yamaha RXV773WABL
I updated my PS3 to OFW 3.55 (via USB), now i want to update the Kmeaw CFW3.55 (via USB) and get the error code 8002F997 (after 78% of PS3 copying the update). It does not work if i try the update in...
8002F997
- This error is caused by an issue with updating the PlayStation 3 firmware by USB drive. Ensure there are no problems with the USB drive. Download the firmware update to the USB drive again to ensure the firmware file is not corrupt. Try the installation of the firmware again. If all else fails, update firmware over the network.
Sep 14, 2011 | Sony Playstation 3 (PS3) Console
After I apply the last firmware update in my Brother FAX-2820 the USB stops working. I have connected the machine in many PCs via USB and nothing. I need your help to solve the issue.
first you dont need to update the firmweare of this machine just only apply this update if you change for a new one main Pcb. If you try to update this machine you make damage your main pcb.
Oct 01, 2009 | Brother IntelliFax-2820 Laser Fax
N95 startup problem
do not consult a technicition i have had this problem and solved it for my friend, you were trying to update your n95 firmware using nokia software updater then it said please unplug and remove battery you should never touch a mobile during an update... anyway to fix it your n95 thinks its still in a middle of the update so charge your phone for 10 minutes (DONT TURN ON) then connect up to the computer via usb to your n95 then open up software updater and press start update it it says could not find deivce keep retrying it took me 20 minutes but could last up to 1 hour then it willl recognise the phone and continue update and turn itself back on only problem is that your phone will be reset but you still keep your memory card data
post back asap dale goodwin
Jul 22, 2008 | Nokia N95 Cellular Phone
Battery life
I know exactly what your talking about, I phoned the company and got the run around, somebody, anybody please help if they can!
Feb 20, 2007 | Pioneer XM2go Inno Satellite Radio...
64 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
