Question about Vacuums
How to replace rechargeable batteries
Electrox battery is labled 1.2 v NI-MH H-SC1300P 0834
2 Suggested Answers
  • 61 Answers
SOURCE: After charging overnight, Roomba only runs about
Reset the Roomba by removing it from the charger, then holding "spot" and "dock" for about twelve seconds. When you let go, the unit will play an ascending series of notes. Then recharge it overnight. If the run time is still short, give Customer Support a call-- be sure to have the Roomba with you when you do.
Posted on Jun 09, 2009
My vacuum runs down quickly. What is the best way to charge it up. I plug it in after using it every time ?
Hello, Janrt -
Depending upon how old the vacuum cleaner is, the rechargeable battery may need to be replaced so that the battery will hold a charge longer than it does now.
Rechargeable batteries do not last forever.
You will need to find the right replacement rechargeable battery for your vacuum cleaner. The web site for the maker of your vacuum may offer the right replacement batteries for sale.
Note: I have found that some replacement rechargeable batteries for some items cost more than the price of purchasing a replacement appliance.
Best wishes.
Jan 20, 2018 | Vacuums
WILL NO CHARGE
The battery is probably no longer rechargeable due to age or to the number of times it has been recharged. If the battery can not be replaced, then the entire vacuum needs to be replaced with a new one.
Aug 02, 2015 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
I need a user's manual for Voltcraft Fast Charge Delta Peak model MW3610HC. I believe it is a battery pack charger. It is a Europian product that requires a U.S. AC adapter. I want to know what size...
SPECYFIKACJA :
  • V detection
  • Cigarette lighter plug
  • Double output
  • Discharge function
  • Dla Ni-Cd/ Ni-MH battery
  • Input voltage: 230V AC, 50Hz, 13.8V do 24V DC
  • Output :
  • Dla 230V AC or 24V DC input: 5.6V DC (4 celle) do 11.2V DC (8 cell)
    • Dla 24V AC input: 5.6V DC (4 celle) do 8.4V DC (6 cell)
  • Output regulowany : 1,000/2,000/3,000mA
Sep 04, 2011 | Vacuums
Batteries are not recharging. Where can I get replacements for Model EL1000 Pronto Vac?
Let me say this; The battery replacement for the Electrolux is not a owner level replacement procedure. However, you can replace the 4 original EMX1600sS batteries . The battery model is Tenergy 2/3A Size Rechargeable Battery 1.2V 1600mAh NiMH W/ Tabs Those are a little smaller than the originals but with the same capacity of 1600mAh and can be easily found in the web. Anything under those specs should work. These types of battery's will cost about $15.00 on the web. The battery's are in the hand held unit bottom or back side area, you access them by taking out all the screws in the back side of the hand unit.
Jan 15, 2011 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Battery will not charge
Rechargeable batteries (usually Ni-Cd) have a finite life and after a certain number of recharge cycles (usually 500 times under optimum conditions) will loose their capacity to retain a charge as one or more cells will become 'worn'. Unless your appliance has a 'smart' charger circuit, leaving the appliance always plug-in will greatly reduced the batteries pack life due to overheating/overcgarging.
Unless you can test and replace as required the individual batteries, it may not be a cost effective solution to replace the batteries.
Hope it helps.
Jul 27, 2010 | Black & Decker SPV1800 Handheld Vacuum
Recently I purchased Sanyo Eneloop NC-MQN04ES Charger. I need the user manual for this charger. How many hours does it takes to charge 4 aa and aaa Batteries. I charged it for more than 6 hrs. But the led...
This is from the user 's manual i just copy paste it
Specification: Voltage : AC 220V - AC 240V,
Input : 50/60 Hz 6W,
Output : DC 2.4V 220-280mA x2 (AA),
100-140mA x2 (AAA),
LED indicator : ON - charging OFF - Timer off (approx 16hours) Battrey/Charge Time Approximate Hours :
-Eneloop Ni-MH AA (typ 2000mAh) 10(h),
-Eneloop Ni-MH AAA (typ 800mAh) 8(h),
-Ni-MH AA (typ 2700mAh) 13(h),
-Ni-MH AA (typ 2500mAh) 12(h),
-Ni-MH AA (typ 2100mAh) 10(h),
-Ni-MH AA (typ 1700mAh) 8(h),
-Ni-MH AAA (typ 1000mAh) 10(h),
-Ni-MH AAA (typ 900mAh) 9(h),
-Dimension : 118 x 75 x 40 mm
Jul 03, 2010 | Vacuums
Can you take the Swivel Sweeper battery pack apart to replace the batteries with new rechargeable batteries? Batteries look like AA or AAA, but it appears that the battery pack is sealed. Is there any way...
Yes you can if you have a way to cut through the plastic outer case,(I used a Dremel rotary tool). Inside you will find six double A Ni-mh batteries. I found eight of these for sale on ebay for around ten bucks,then all you do is solder some wire to the batteries like the original battery pack and tape up the case and charge.
Nov 20, 2009 | Hoover H3030 FloorMate SpinScrub 500...
My Dirt Devil kurv no longer recharges. I think I need to replace the battery. Called the manufacturer and they can't help me.
Obtaining a battery will be difficult; I had a similar problem with my Kone model. Check that the plug you have has a fresh new fuse though as it may be the connection lead.
Sadly because the batteries are built into the machine its difficult to find a replacement - ALL cordless hand dust busters suffer from difficult to find batteries because at cost they are reasonably cheap and not really designed to have batteries that can be found easily.
Well not until someone brings out a model that has batteries that are available...
Jul 23, 2009 | Dirt Devil Kurv Bagless Cordless Hand Vac...
After charging overnight, Roomba only runs about 25 minutes before shutting down with a red light.At this point the battery measures 15.13 volts ( about 1.26 volts per cell ) My hobby experience is that a...
Jun 07, 2009 | iRobot Roomba 560 Robotic Vacuum
Roller/sweeper on my Electrolux Pronto
After 3 years my Pronto slowed down and needed new batteries. I just replaced all 8 internal batteries. It cost just under $30 with shipping and took 1 hour of soldering. If you're not handy with a soldering iron, don't attempt it. All of the batteries are soldered together in series. You need to order the 8 (4/5 Sc size, 2000 mAh) Nickel metal hydride (Ni-MH) batteries with tabs. The source I used was www.BatteryJunction.com. Here's a link to the battery page: http://www.batteryjunction.com/tenergy-45th-sc-1-2-2000-tabs.html
PS The vac now runs GREAT!
Russ
Feb 28, 2008 | Electrolux EL1000A2 Pronto Bagless Stick...
Vacuums Logo
289 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
