Question about Gateway Computers & Internet
My touch scroll stopped working for my Gateway NV53A. Can I fix it?
The touch scroll bar next to the touch pad will move the mouse pointer up and down but won't scroll the screen for me any more
    New Friend:
    Problem Solver:
  • 12 Answers
My touch scroll stopped working for my Gateway NV5 - 1_9_2013_6_10_09_am.jpeg check it first , by , connect a mouse , go control panel disable it , and use mouse ,turn the notebook , turn on & enable it , may be works , other wise hardware problem.
Posted on Jan 09, 2013
5 Suggested Answers
SOURCE: Gateway notebook touchpad
Thank you mewms_14904. The problem was the F key. In my case it was F7 that enables and disables the glide pad of my notebook.By pressing fn key and then F7 solved my case.
Posted on Oct 11, 2010
benwabnick
  • 2404 Answers
SOURCE: touch pad scroll problem
Go to this page:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INSPIRONI6400/E1505&os=WW1&osl=en&catid=&impid=
On this page, choose your operating system and then choose input device drivers.
Then go ahead and download the synaptics driver for your laptop. This software is for your touchpad and should enable the scrolls to work again.
Posted on Aug 05, 2009
KenjiFox
  • 142 Answers
SOURCE: My touch pad for Lenovo
It most likely has something conductive around the edges. Clean the pad with a cloth or paper towel that has 99% isopropyl alcohol on it. Use something like a toothpick to push the cloth or paper right into the edges. Once it is clean, and completely dry, try again. If it still doesn't work you may need to check the connection inside the laptop.
~KenjiFox
Posted on Jan 07, 2011
durtopian
  • 408 Answers
SOURCE: my acer aspire one d255
Sounds like the touch pad may be bad or isn't installed.If you look under hardware and it installed then most likely the touch pad may be bad.
Posted on Jan 11, 2011
Gateway HDMI laptop T series charger output 19 vgets v.hotbut works . burser pointer starts jumping frm place to place on screen dificult to control ?
run it in battery to see if fixes cursor problem
also try a different mouse see if that makes the cursor move correctly
this way you see if its the mouse or power supply
might also a touch pad problem anything that controls the cursor
May 07, 2015 | Gateway Computers & Internet
HP 2530p EliteBook - touchpad stopped working. Scrolling works except touch scrolling on right side of pad) and right button, but that's all. Wireless mouse works fine.
To access Mouse Properties, select Start - Control Panel - Hardware and Sound -Mouse.
Use Mouse Properties in Windows to customize settings for pointing devices, such as button configuration, click speed, and pointer options.
Jan 18, 2013 | HP EliteBook 2530p Notebook
How to used the touch pad
Use the touch pad to move the pointer around the screen.
Run your finger over the touch pad in the direction you want the pointer to move and then click the left touch bar (this works as the left button on a mouse).
Apr 16, 2012 | Computers & Internet
The scroll down touch pad wont work
Hi, to Enable the Pointer Device; go to, Control Panel, click (Mouse) in the Hardware and Sound category. Go to; Device Settings, in the (Devices) block, click on, and Highlight; the item you want to (enable) this being the Pointer Device. Click the Enable button, just below. Be sure to (Click) on the Apply button, click OK. You may need to Update Drivers. Click on Hardware, click Properties, click, on Driver. If the, Update Driver (block) is not Grayed-out click Update Driver, click (OK), this will ensure that the application take effect. Note: Restarting the computer will configure system changes in the computer applications to prevent errors, and to finalize the (Installing / Uninstalling) of programs, and or (Enabling / Disabling) of Hardware. "I hope this will fix it, rating it is appreciated, thanks"
Mar 13, 2010 | Acer Computers & Internet
Have a Satellite P 305D-S9800; scoll bar will not pull down by mouse or touch pad; as soon as I let go it jumps back to the top please help
The "Touchpad is very sensitive; if you look while scrolling, the "scroll-bar" will turn (Blue), click on the ("scroll-bar"), until it turn "Gray." Note: "You ca use the Pointer Device / Touchpad without using the Scroll-bar, basically anywhere on the screen; ("bottom scroll-pad" = left to right"), and ("right -side edge scroll-pad = up & down").
Jan 24, 2010 | Toshiba Computers & Internet
Compaq notebook laptop: my mouse pointer or arrow is
If you have a manual for the notebook, check to see if you can use the function key and the similarly coloured key on the keyboard which enables/disables the touch pad. Usually you can disable the mouse pointer touch pad with this FUNCTION key + MOUSE key when pressed together. Often these keys have the same colour (usually blue). The purpose is to disable the touch pad when you are using an external USB or wireless mouse, then you press the 2 keys again together to enable the touch pad once you have removed the USB/wireless mouse.
If that doesn't work, borrow a USB mouse and attach it to your notebook to use temporarily while you diagnose the problem.
Dec 19, 2009 | Acer Aspire 5100 Notebook
Scroll bar on the right side of my touch pad scrolls too fast how do i slow it down
It depends, do you know if there is an icon down in the taskbar near the clock that has options for your mouse, if there is then you would double click that and there should be options in there.
May 26, 2009 | Gateway MX8711 Notebook
Laptop t-series
Use external (USB) mouse; check/adjust mouse properties double-click speed. Open/clean or replace touchpad.
May 25, 2008 | Gateway Computers & Internet
Apr 16, 2008 | Gateway MT3705 Notebook
Computers & Internet Logo
297 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
