TV Shuts Off randomly
We have a 52" Samsung TV and recently it started to just randomly shut off. It is only 1.5 years old so it shouldn't be because of age. Can anyone help with this problem? Is there something that we should replace? Maybe it's overheating?
Our flat panel TV would shut off for 5 to 10 seconds and then come back on. We found out that our Comcast HD box was bad. After a tech replaced the bad box with a good box the problem went away.
Posted on Jan 21, 2009
TV just shuts off randomly. Any idea what the problem might be?
The door switch of some of these units caused that problem. see following web site: http://www.amazon.com/AA41-0756C-Switch-Sensor-SAMSUNG-HLP4663W/dp/B00NH49Y4E
May also be the lamp itself
Apr 09, 2015 | Samsung Televison & Video
1 year ol 52 inch flat screen with new power supply cycling.
Still sounds like a power supply issue would it still be under repairers warranty
Jan 07, 2010 | Samsung Televison & Video
At just over 1 year old and out of warranty, my Samsung 52'' LCD will not turn on. You can hear the relay click on/off/on/off, getting slower, until it will turn on after about 8 minutes. The firmware has...
Same problem on my friends Samsung LN52A650A. Never did the firmware update cause that refers to a random shut-off problem. I replaced (2) 1000 10 volt caps next to a heat sink with 1000s rated at 35 volts @105 degrees C. The tops on his were a little swollen and you had to really look close. The caps were 2 0f 4 inline caps. They were the smaller 2. TV works.
Jan 02, 2010 | Samsung LN52A650A LCD TV
The TV will shut off by itself randomly (anywhere
Sounds like the TV is going into the "protect mode", usually means there is a failure present and it's shutting down to ward off any serious damage to the electronics. The status light will usually blink a error code along with this symptom, call a service center and let them know how many times the light is blinking in a continious pattern and that will help them to diagnos your TV problem. Good luck and Merry Christmas!
Dec 25, 2009 | RCA D52W135D 52 in. TV/DVD Combo
Samsung hls5086wx/xaa turns off at random
Go to website Encompass Electronics.com type in your model number it will list part and part number ,you can also look for Lamp on E-Bay Encompass 1-800-638-3328 Also ck Color Wheel remove lamp take a flash light to watch when you turn TV on see if the color wheel is turning if it is defective set will shut OFF. But most likely its your Lamp.
Oct 05, 2009 | Televison & Video
52 INCH RCA REAR PROJECTION SHUTS OFF
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
Jun 19, 2009 | RCA HD52W56 52" Rear Projection HDTV
Shut off tv on its own
Look into getting a new Power Supply Board. There is a good chance that you have 1 or more faulty capacitors on the PSB.
Apr 03, 2009 | Samsung HLN5065W 50" Rear Projection...
Viore 52' TV randomly shuts off. front lights blink then stop.
I am having the same problem with my PRT50V24D shutting off and blinking lights. After going to viore.com and calling the number listed, I got recording to call another number. When got rep on line I was told it is made by Samsung, Called their tech support and was told that sounds like power problem or bulb getting ready to go. Also if outside of warranty will have to call repair man to see what's wrong. I will have a repair man out next week and will post his results here. Most likely it's the same issue. This is the tech support number for Samsung 1-888-697-2247. Good Luck man. Matt
Dec 05, 2008 | Televison & Video
Samsung pcj522r shuts off randomly
samsungs have convergence ic that heat up and cause tv to shut off but most of the time the colors will be off. Alsp solder connections could cause this on voltage regulators.my guess would be convergence ics cost for repair is 250.00
thanks doctor video
May 12, 2008 | Samsung PCJ522R 52" Rear Projection...
Televison & Video Logo
204 people viewed this question
Top Televison & Video Experts
Electro Med Services...
