Question about Dryers
Siemens tumble dryer makes squeaking sound - Dryers
  • 55 Answers
SOURCE: Squeak
It is proably the center bearing in the back of the drum, especially if it at least a few years old. It can be replaced by you if you are very handy.
Posted on Feb 11, 2008
  • 172 Answers
SOURCE: How do you replace the
Hello Jkahle9,
You are in for a big job there. I will try to give you the best step by step possible. First get you a rear bearing part number 131825900. This part retails for $5.96 but you may pay as much as $11.99 This is only for the bearing not the ball that goes on the back of the tub. You will also need some white lithium grease. You will put a small about inside the rear bearing.You may also want to have a second person to help screw the bearing in place.
Step one will be to unplug the machine and pull it out so you will have access to the back. Most of the repair will be done from the front of the machine.
step 2, You will need to pop up the top of the machine. You do this by inserting a flat blade screwdriver into the two clips holding the top down. They are located about two inches from the left and right side front under the top.
Then you will need to remove the front panel and door. You will do this by removing the two screws from the top left and right of the inside of the front panel. the front will then tilt forward from the top and lift off. Use caution because your door swith will still have two wires attached. You can leave these inplace.
next will be to remove the belt from around the tub. To do this reach underneath the tub and remove the belt from the idler pulley and the motor shaft. Remember how you take this off because you will be putting it back shortly. When the belt is loose you will use it to lift the tub upward with a sharp ****. The rear of the tub has a ball and socket joint and the ball must be pulled up and out of the bearing. When the rear of the tub lifts up you will then remove the tub out the front exposing the rear bearing and the heating element. Note, If you damage the heating element while doing this you will need to head back out to the appliance store and buy a new one. You can not take extra slack out of the heater if you have stretched it.
The final step will be replacing the bearing. Use caution so you do not loose the small ball bearing in the rear center of the bearing. You will have two screw to remove and a small metal bracket on the back of the machine. When reinstalling the screws you may need that second person to hold this bracket. Once installed and the small ball bearing is inplace add the grease. Look at the ball on the back of the tub to make sure it is not bad. If it looks ok then just reassemle and start drying. Good luck. MCA0824@aol.com
Posted on Apr 30, 2008
  • 221 Answers
SOURCE: Dryer making loud squeaking sound
Try checking the glide wheels under the barrel they may need to be cleaned and lubed.
Posted on Mar 11, 2009
dragonsthatk
  • 547 Answers
SOURCE: GE profile dryer is making squeaking noise.
please replace felt around drum thank you for useing fixya RATE ME
Posted on May 17, 2009
localwonder
  • 6784 Answers
SOURCE: It makes a constant squeaking noise
In most cases, this will be a worn idler pulley. I would inspect this pulley for excessive clearance.
Access to the idler pulley varies by model, if your dryer has a lower front panel (kick plate) start there. It should lift up and off or it may be held in place with a few screws or snaps; it may also have a catch at the edges or center gap between the kick panel and main panel. To release the catch, push a putty knife, wrapped with masking tape, into the gap and push back the catch. The next easiest access point is the rear panel. The rear access panel is held in place with several screws along the outer edges. The last resort method of access is the removal of the entire front panel. The front panel supports the front of the drum and so removal is more difficult. Front panel removal varies. In general, access is gained by lifting the top (remove the lint trap screws first), removing the screws that secure the front panel, and detaching the panel from the drum.
When reaching into the dryer be careful of sharp edges on the cabinet and interior supports. Reach in to the belt and give it tug. It should be taught and have only a little give. The belt should go under the idler pulley and over the motor pulley. Lift the idler pulley toward the motor to relieve tension on the belt and remove it from the motor pulley.
Turn the idler pulley wheel, it should turn smoothly, quietly and without any wobble. Inspect it for cracks or uneven wear. If the idler pulley does not maintain proper tension or is damaged it should be replaced. Depending upon your model, the entire assembly or just the wheel or bearing may be replaced.
Posted on Oct 04, 2009
Problem with tumble dryer that has started making loud noise.
Dryers are designed to operate in one direction. Some models turn clockwise and some turn counter-clockwise. Do not run it backwards. The direction of air flow will be impeded or reversed.
Mar 07, 2017 | Whirlpool Dryers
What does e24 error on my siemens tumble dryer mean ? After about 10 mins the machine make an alert warning noise and flashes the error sign and said turn off and start again .
Unfortunately, it means you have a computerized machine that can only be repaired by a technician with proper diagnosing equipment. Even if you can find out the meaning of the code... that may not tell you what to do about it. (It usually involves replacing circuit boards). Monetarily, with regard to cost of repairs, we were all far better off back in the days of ''switches'', ''knobs'' and ''mechanical timers''.
Sep 01, 2014 | Siemens WT46W568GB Condenser Tumble Dryer,...
Indesit idv65 tumble dryer squeaking really loud
hi check drum bearing to see if worn
Jan 21, 2014 | Dryers
And Admiral ser# 3281223 When dryer is turned on, it makes a loud grinding sound when it tumbles
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 29, 2011 | Dryers
My dryer is making a clicking sound like a coin is loose and tumbling but nothing is inside?
heatman101
Jul 02, 2011 | Frigidaire GLGR331A Gas Dryer
Have tumble dryer that makes high pitched squeak before it reverses direction sometimes. not all. took back and panels off to try and isolate where sound coming from but cant seem to locate.
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 25, 2010 | Dryers
My dryer squeaks while tumbling. Thank you fo...
your front drum glides are bad and need replacement
May 20, 2010 | Dryers
My dryer started making a squeaking sound. It's
Belt needs to be replaced,have you ever had a car drive by and heard a squealing noise? dryer belts "glaze" and squeal due to wear just like the ones in your engine
Apr 01, 2010 | Frigidaire Electric Dryer
GE Dryer makes deep sounds when hot and tumbling
heatman101
wrytrtrs
Jan 28, 2009 | General Electric GE 7 0 Cu Ft Super...
Squeaking noise from Dryer when tumbling
IT IS USUALLY THE "BELT TENSION ADJUSTABLE PULLEY". MOST ARE CHEAPLY MADE ... TRY A BIT OF AXLE GREESE ON IT ... IT IS SEALED FROM THE INNER DRUM AND IS MOUNTED USUALLY ON THE BOTTOM FRAME RAILING.
Jun 25, 2007 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
Top Dryers Experts
