Question about Frigidaire Refrigerators
Frigidaire FRT1s6ESB9 not getting cool
My Frigidair FRT1S6ESB9 Model JD-21 is not getting cool. The freezer is working good.
HVACRH20
  • 237 Answers
SOURCE: Frigidaire FRT18HB5DW2 fridge not cooling
Sounds like an air flow problem to the lower unit. Take the sheetmetal or plastic rear cover off the freezer back wall and make sure the coils are frosted up good and even but NOT a block of ice inches thick (air needs to circulate and a blocked coil won't let air move over it efficiently). Make sure the fan is running to move the air around. In the fridge area make sure the air dampers are letting the cold air from the freezer down to the fridge compartment. Depending on what you find will determine the next steps so let us know.
Posted on Dec 27, 2006
tech master
  • 120 Answers
SOURCE: frigidaire frs26zrf
IS THE EVAPORATOR FAN INSIDE FREZZER WORKING AT ALL IF IS NOT WORKING THEN THERE IS NO AIR FLOW TO THE BOTTOM PART
Posted on Nov 10, 2008
BNewberry
  • 93 Answers
SOURCE: Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Posted on Nov 25, 2008
SOURCE: Fridgerator not cooling
I have the same problem. Freezer is okay, but refrigerator is not cooling.
Posted on May 17, 2009
Maytag317
  • 1136 Answers
SOURCE: Frigidaire AS-17 does not cool, freezer works fine
Hi, Check the freezer and see if the fan motor is running. Remove the rear panel and check for a frost or ice build up inside the rear freezer panel. Please let me know what you find so I can assist you further.
Vic
Posted on Jun 28, 2009
Frigidaire Freezer acting goofy
Make sure everything is clean of debris and I would personally see if you could cool the area around the unit. Maybe use a fan or turn the air down in that room. Humidity and hot temps kill a unit's sealed system.
Jul 24, 2012 | Frigidaire 21 cu. ft. / 595 liter Upright...
Frigidair FFU21C3AW1 cooling slowly
When it comes to freezer units, there is not much one can do on their own. You can try to move it around and clean any debris from underneath and behind it. You can see if the internal temperature matches what you have it set on, and then you'll need to contact a professional to diagnose the actual sealed system of the unit.
Jul 17, 2012 | Frigidaire 21 cu. ft. / 595 liter Upright...
Frigidair Gallery fridge/freezer... Freezer is
change the control board in the rear lower left corner of unit part# 4334000 2 appliance parts pros
Oct 31, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire FRS6HR4HW: Refrigerator Design Flaw? It's too warm!
Your refrigerator has 2 thermostats and an electrically controlled air damper. If a technician removed the air damper and someone has not replaced the thermostat for the refrigerator side I believe you have a poor quality service tech and if your refrigerator was worked on with someone with an ounce of a brain they surely would not leave the electrically controlled damper out and would not overlook the possibility that the thermostat probe is defective. Your refrigerator would be an easy fix if the people that were working on it knew what they are doing. You have a minor problem with your refrigerator and a major problem with the technician. Sea Breeze
Sep 11, 2009 | Frigidaire FRS26H5AS Side by Side...
Frigidair HVAC not cooling; Believe its a emergency heat problem
the switch is on your thermostat - look for something that says "system" or "Em heat, heat, off, cool" switch it to "cool" and enjoy. If that doesn't work, call a HVAC service tech. You could have bigger problems than just the system switch. Good luck
Sep 05, 2009 | Frigidaire FAS185N2 Air Conditioner
Freezer works great, but refrigeration section stopped working
Check the door seals on fridge and freezer to make sure there are NO leaks.
Try manually adjusting air flap that controls air from freezer to fridge, the flap may be frozen or the actuator that controls the flap may be faulty.
Aug 25, 2009 | Whirlpool GD5SHAX Side by Side...
Refrigerator side will not cool on Frigidair Model FRS26ZGEW3
2 things could be the problem.. 1 check to see if the fan located on the temp. setting control assembly is working. If this fan is not on the fridge will not cool. if the fan isn't working replace it and problem should be taken care of. If fan is working then your defroster is out.. You can tell if defroster is out due to the big chunk of ice in space between the fridge and freezer where the fan is also located. Parts can be purchased at an appliance parts houseand aren't that hard to install. Good Luck
Dave
Jul 16, 2009 | Refrigerators
Ice maker & top fan motor is not running
If the fan is not running the freezer will not be cold enough for the ice maker to run. The fan may be stuck. Or it may need to be replaced. If you can remove the ice maker and take off the back panel of the freezer. Try to spin the fan to get it going. If not you may have to replace the fan.
Apr 20, 2008 | Frigidaire FEX831CS Top Load Stacked...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
