Question about Dryers
Electrolux dryer makes this sound when I start. It stops after this. Drum does not rotate. Display says paused. When I hit start again; nothing happens.
    Problem Solver:
  • 13 Answers
CHECK THE BELT OR TRY TO ROTATE DRUM MANUALLY
Posted on Jan 09, 2013
SOURCE: dryer makes noise as drum rotates on ge profile gas dryer
Solution: the drum slides were worn out and needed replacement.
Posted on Jan 14, 2009
buffalonyman
  • 1865 Answers
SOURCE: Dryer drum stopped rotating, dryer blower continues to work.
The belt probably broke, and coincidentally happened while drying the shoes. The belt is easy to replace. Open the back and you'll probably see the belt laying on the bottom
Posted on Nov 10, 2009
  • 24 Answers
SOURCE: My GE Profile DPSE810 Electic Dryer has started
Depends on what kind of noise...
-Repetative muffled creaking: Probably the metal drum sliding against the plastic mount that holds the front of the drum. It can be TEMPORARILY eliminated by disassembling the dryer and tampering with the felt strip so that the drum has more play and turns more freely. It does not indicate a major problem.
-Metal against metal scraping: Maybe the metal cabinet got bashed in just enough that the drum rubs against it? This kind of sound should be investigated and fixed.
(For what it's worth, my DPSE810EG4 does has the repetative muffled creaking.)
Posted on Dec 26, 2009
  • 30 Answers
SOURCE: dryer modle Tc7102w/t5c7102s was working ok but drum won't rotate
Theres two things to look at, the brushes on the motor, replaceable and cheap, if they are are healthy then there is one or sometimes two large capacitors, these give the motor the ooomf to get it rotating, these fail which is a common problem with washing machines and dryers, again about £5= on ebay.
Posted on Mar 25, 2010
  • 3074 Answers
SOURCE: I have a Bosch series 500 dryer that has stopped
sounds as though the belt maybe off, you will have to disassemble the dryer and investigate. hope this helps tim
Posted on Aug 28, 2010
Maytag Neptune Dryer MDE3000AYW. Replaced pulley and arm (pulley was seized to it), rear drum wheels, front drum glides, belt. Cleaned throughly inside. Worked like a charm for about 6 loads. Went to hit...
I'm guessing that your belt my have been misaligned, which means, no problem!
But, I recently had a machine that had a motor that would not turn, only hummed. I vacuumed the lint, then blew the lint out of the motor with a compressor, and vacuumed again. It still needed a push start to get the motor turning, but it starts on its own, now. So, if you have a lot of lint buildup, it can eventually stop the motor
Mar 06, 2017 | Maytag Dryers
Dryer makes humming noise drum won't spin just goes back to pause
take out the plug and change the capistor ..make a note of the wires and take picture where they go
Aug 05, 2014 | Electrolux EIED55HIW Electric Front Load...
Eigd55hiwo dryer
Good Afternoon Friend,
I understand your Electrolux dryer, model# EIGD55HIW0, is snagging your clothes. This can be caused by scratching or chipping of the drum of your appliance. There is nothing to stop this from happening other than changing out the drum. For future reference, you can help avoid this by removing foreign objects such as coins, pins, clips, or buttons, from all pockets. You will also want to be careful with belt buckles, zippers, and fasteners that may be hitting the inside of the drum. Hope this is helpful.
-Best Regards-
WP
Jun 21, 2014 | Electrolux Dryers
Electrolux front load dryer does not start
if it makes a humming noise for a short peiod then stops and after a while it does it again the drum maybe stuck and making the motror go off on overload try turning the drum by hand and see how it spins
Jan 08, 2013 | Dryers
When the button is pressed to start the dryer it begins to hum as iff the drum is stuck. It does this for about 5 to 10 seconds then shuts off. If I attempt to start it again nothing happens. sound like...
If you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Apr 17, 2011 | Whirlpool LER7646E Dryer
The dryer rotates fine but it makes loud clunking sounds as it spins. Sometimes it pauses for a rotation and then starts in again. The belt was replaced recently and the back 2 rollers spin freely. The...
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Dec 04, 2010 | Maytag Dryers
I have an Electrolux IQ Touch dryer. Just now it stopped working. When I hit the start button, it makes a buzzing sound and then goes on Pause. I called Electrolux and they had no idea what was...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Aug 25, 2010 | Electrolux Dryers
When start button is pushed, hums but does not run. Drum does not turn. Belt is okay
It sounds like it is the motor or a stuck/obstructed blower wheel. You can start by opening the door, push the door switch in, hit the start button & see if you can turn the drum clockwise by hand. This might get it going. if the drum does not move by hand then the problem is probably within the blower. post your findings for a follow up
May 01, 2009 | Dryers
Dryers Logo
75 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
