Question about Car Audio & Video
I have a 2011 jeep patriot with the premium sound system in it i hooked up my 2 10 inch subs with my amp and installed my aftermarket pioneer and the system works fine but the factory speakers clip i bought 3 diff wiring harnesses to make sure it wasnt that and i bought the expensive one to work for my vehicle so i dont know why my factory speakers are cutting out (clipping) can someone help me please
    Top Expert:
  • Car Audio & ... Master
  • 40,417 Answers
The factory speakers are being overdriven.
Posted on Aug 04, 2017
4 Suggested Answers
SOURCE: Chrysler Pacifica Aftermarket Radio Problems
Here is the solution:
Their is a chrysler amplifier some where in your pacifica.In order for your signal to reach the speakers you need to buy a box (from bestbuy install ,or any car stereo install place)that allows the signal to "pass thru"to the speakers.
Posted on Jul 27, 2008
SOURCE: Wiring Harness Woes
Try that i think i found it.
Posted on Aug 25, 2008
  • 15935 Answers
SOURCE: pioneer dehp3100ub.stock speakers wont work with unit?
If the vehicle has a premium sound package - you need to use the remote wire to turn on the factiry amplifier.
If you want to use the power from the radio for the speakers, you must buy and install a factory amplifier bypass harness.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Posted on Jul 19, 2009
Can i hook up a parakeet model number PWM 16 to my factory stereo in a 98 Ford Expedition
About 3,970 results (0.89 seconds) Search Results
    Ford Bluetooth® Wiring Harness - Crutchfield
    Crutchfield Corporation
    Rating: 4.5 - ‎16 reviews - ‎$19.99 - ‎In stock
    Reinstall the factory radio and mount the Bluetooth kit, and you're ready to go. ... 16Reviews ... harness so that I could hook up an aftermarket amp to my factory radio.... works like it's suppose to. says it doesn't work on an 09 Escape but had no .... I purchased this harness to install a parrot ck3100 in my 07 Ford Edge.Missing: pwm
    70-5521 wiring harness for ford with 6 CD premium sub amp ...
    ? 4:30
    Aug 9, 2013 - Uploaded by codieraji
    Metra 70-5521 Radio Wiring Harness for Ford 03-Up Amp FordPremium stereo radio 6 CD changer with sub amp inputs. ...16:47. How to wire an aftermarket radio / I Demo install with metra harness and antenna ... How to hook up stock amp/sub to aftermarket head unit "ford sport trac" - Duration: 3:01. Pat.Missing: parakeet ‎pwm ‎98
    Car Stereo Wire Harnesses - Radio Wires for all Car Audio ...
    Car Stereo Wire Harnesses - Car Stereo Installation Wiring - Stereo Harness ... If you
Feb 09, 2016 | Ford Cars & Trucks
Aftermarket stereo turns on but can't hear anything 1997 explorer
Did the truck have the premium sound system? If so, you will need to connect the blue remote wire to the blue remote wire on the harness. You may also need a special harness to bypass the factory amplifier.
Jan 10, 2014 | Car Audio & Video
Have a 1996 soundstream reference 1000s amp 2 chan. Want to hook up 2 2011 12 inch kicker cvt woofers 4ohm. What is the best way to run this set up?
I have Ref-1000s with two Pioneer TS-W1200C 4-ohm subs bridged in series. So it is 8-ohm mono load, easy for an amplifier, long durability, less heating, low current consumption. I have heard that this amp might break if used with low impedance loads.
Mar 18, 2011 | Soundstream Car Audio & Video
Can't get my amplifier to work.
My homie had the same problem with his escalade they adapted an rca line adapter from the factory wiring to geta signal to his amplifier and it just wasnt hitting like it should so we installed a new deck and plugged the rca cords right into it and boomboom pow it was hittin like a champ-we figured that the stock premium system that was incoprporated into the truck had some sort of an onboard amp that was filtering the bass from the door speakers and which was limiting the bass output to the rca adapter and thus on down the line to the amplifier- so maybe ya might want to look into getting an aftermarket deck and see if that helps your cause-good luck
May 21, 2009 | Alpine MRP-M450 Car Audio Amplifier
Alpine subs not hitting hard
could it be as simple as bass boost??? maybe you have the subs hooked up wrong... have to have the ohms right.....hopefully this helped
Jan 26, 2009 | Pioneer GM-X962 Car Audio Amplifier
Sub not working after installing the jensen vm9022 deck
reinstall the factory radio use a digital volt meter to see witch wire supplies voltage when radio is turned on and off, note placement on harness then verify this wire is hooked up on the output side aftermarket harness you may have to jump it to get the maps to turn on. tip you can carefully pull unused wire from harness example (dimmer wire orange white) and move it to the position needed to keep it a clean install .
Nov 19, 2008 | Car Audio & Video
System not playing
Sounds like the output transistors on the amp are blown. Were you slammin when it stopped or how did you find out it stopped working. It could be the sub failed then caused the ap to go which is why you get a little something from the JL.
Feb 11, 2008 | Car Audio & Video
Need help
u should connect at least six 12" subwoofers (preferably 1000W each) to that pioneer amp of yours. Crank it up and enjoy. Your amp shouldn't cut off now. If it does cut off, you should change the fuse on your amp to a higher ampere.
Oct 30, 2007 | Pioneer GM-7200M Car Audio Amplifier
No sound comming from car speakers
What kind of car? What kind of system? More details will help me assist you better. If it is an aftermarket in-dash stereo, it sounds like the blue/white wire is not hooked up correctly. This powers up the car's amplifier and lets the sound through.
Sep 20, 2007 | Car Audio & Video
Amp is on, Subwoofer works, but no sound.
here is a short test you can try, remove the rca audio cable from the amp & connect a diskman or toher audio o/p device that you can hook up with the same rca wires, turn on the amp & see if you have sound. you can also remove the speaker wires from the sub & using multi meter read the ohm's of the sub, most subs are 4 ohm. Hope this help locate your problem
Oct 24, 2006 | Pioneer GM-7200M Car Audio Amplifier
Car Audio & Video Logo
27 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
