SOURCE: Replacing Toner
How to tell on brother mfc-8440 or mfc-9440cn , the total copies printed so far
SOURCE: Brother printer HL-2070N
go to the start of your computer and find the control panel and when you see the ad and remove program click it and and you see the currently install files find words brother printer HL. click it and remove after that please restart your computer din insert your brother printer installer cd into cdrm and install again maybe your current printer driver some files is missing, or reformat your pc using os/operating system and install the printer again make sure your printer have a load tuner or ink. thank you
SOURCE: My Brother MFC 7840W prints but has a faint copy
Yes. The drum is most likely your problem. It is possible that it is a one time problem, which can occur if you print a very dark black page or image followed by a light gray page or image. If it has only happened once or twice try printing a different document to check it. If it is happening repeatedly, then you should replace the drum and instantly see it fixed. You can get a drum anywhere that supplies toner.
I hope this helps! Good luck!
Testimonial: "Thank you. This issue was driving my boss and me NUTS!"
SOURCE: I have a Brother MFC-8890
open the front cover and press option
press start and 00
then your printer will be reset and ready to go
SOURCE: brother MFC 7362N slow to print
Update the driver. Go to "Start", "Devices and Printers". Right click, choose "Properties". Click the hardware tab. Click the "Properties" button at the bottom. Click the Driver tab at the top. You should be able to update the driver from there.
