Question about Apple iMac 24" Desktop
Remove the screen from iMac aluminum 20"
I need to change the hard drive in my iMac aluminum 20", how do I remove the front screen? There are no screws holding it in place
  • Anonymous Mar 22, 2014
    Remove hard drive
AMFITEATAR - Naucni portal - Upgrade your iMac 20" or iMac 24 ... This link will have what you need to remove the front cover off the LCD screen. It then goes on to show you how to get to the hard drive.
Posted on Feb 28, 2009
    New Friend:
    Problem Solver:
  • 8 Answers
See here for remove the screen from imac aluminum20
Posted on Mar 12, 2013
  • 115 Answers
The screen is permed, you will have to put your computer horizontal, screen up, and then you can use two suction cups in the diagonale of the screen. Then simply pull, but carefully of course..
Posted on Feb 04, 2009
How to change hard disc on an imac
This is not something that can be done unless confident in your abilities and have the necessary tools as you will need to remove the screen to gain access.
Mar 02, 2014 | Apple 24" iMac Desktop
I would like to know if an older hard drive from imac model A1076 could be installed in a slightly newer imac, model A1145 and have it be compatible and working with no problems?
Hard drives are universal, and based on physical connection / type. So your older HD should work even if you have newer SATA connection. The connection is backwards compatible.
Dec 08, 2012 | Apple Imac G5 20" Als G5 2.0ghz 2gb-ram...
How do I replace the hard drive in a 2005 iMac?
Remove the glass and all will be revealed.
Aug 02, 2012 | Apple 20" iMac Desktop
I need to know how to replace the iMac hard drive by restoring the data I got from my MacBook. The data is currently stored in a Maxtor external drive
Welcome to Fixya. If you want to change the hard drive of your iMac just follow the instructions on the manuals below. I provide 2 manual for a iMac 17" and 20" system.
iMac 17" Manual
iMac 20" Manual
If you have questions please let me know. Thanks for using Fixya.
Apr 11, 2011 | Computers & Internet
Replace hard drive
1: Remove the RAM access door on the bottom of the unit.
2: The Glass Panel needs to be removed from the front of the unit. To do so you will need 2 heavy duty suction cups. The style that you would use to remove a dent from a car. You will need to put one on opposite corners of the glass panel
not gently pull the glass off, trying not to flex it.
3: Now remove the 12 T8 screws from around the LCD, be gentle not to slip off the screw head and scratch the LCD.
4: Now Gently life the Aluminum Bezel from the top side. The Bezel will still be attached by a cable on the top. There will be a connector that is attached to the camera. Disconnect this cable and remove the Bezel.
5: On the Logic board, to the Left of the RAM there is a connector labeled "LCD Temp" remove this cable from the Logic Board.
6: In the middle rightish area, directly below the LCD there is a connector
Remove the 2 T4 screws from it and remove the connector from the Logic Board. There is a black ribbon on the top for you to pull. Pull it straight up from the board.
7: Around the LCD there are 8 T8 Screws, remove these and slowly life the LCD from the bottom, tilting it.
8: Two cables will be holding the LCD in. disconnect these and remove the LCD from the rest of the unit. Don't worry about mixing these up, they are interchangeable.
9: On the Hard Drive there will be a piece of tape holding down 2 sets of grey and black cables.remove the tape.
10: On the Logic Board, below the Hard Drive, there is a connector labeled "HDD Temp" Remove it.
11: Press the hard drive bracket down toward the bottom edge of your iMac to free it from the rear case, then rotate the top of the drive toward yourself. This will take a Considerable amount of force, be careful to to knock the iMac over.
12: Tilt the Hard Drive away from the unit, and remove the SATA and Power connectors. now lift the Hard Drive out of the iMac.
13:Now remove the Foam tape from the Hard Drive. Under it you will find the HDD thermal Sensor. You will need this when you install your new drive.
14: Now transfer the Hardware from the edges of the old drive (making sure to replace them in the EXACT same place on the new drive.
15 Don't forget to re-install the Thermal Sensor. THIS IS IMPORTANT. if the sensor is not installed, or not flush with the hard drive, the computer will think that the Hard Drive is over heating, and it will turn all the fans in the unit to max to compensate.
16: Now re-assemble and enjoy. Don't forget to format your new drive to Macintosh OS (Journaled)
Oct 09, 2010 | Apple iMac 24" Desktop
Wont boot on its own, wont boot with install disc,
As the hard disk appears to be showing up when you boot up using the install disc, I would suspect that the system is somewhat corrupted. You could reinstall the system again and if you are happy starting from scratch and wiping the hard drive select this option failing that and there is some data on the imac you could install using the preserve user data. A fresh install should sort out any problems. Hope this helps.
May 18, 2010 | Apple 20" iMac Desktop
How do I open a iMac a1207
place the screen face down on a cloth Go to where the speaker is located and you will see 3 ot 4 screws depending on the model remove those screws and lift the case by the stand and then you can see where the hard drive is located.
Mar 07, 2010 | Apple iMac Z0CY Desktop
I want to make an internal western digital 160GB drive from my imac g5 20" into an external drive and need to figure out what enclosure and cables i will need
You need the following
Please note the links are an example only.
Sep 02, 2009 | Western Digital Caviar WD1600 (1600YD) 160...
Changing a hard drive on third generation imac
After a bit of confussion by what you mean by 3rd Gen and Aluminum and glass I've decided to give you two guides and you can choose which one you actually mean.
One of those should help you out.
All the best
Dec 18, 2008 | Apple iMac G5 Desktop
Apple iMac 24" Desktop Logo
1,873 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
