SOURCE: Can I set up tv remote to also control cable box?
Just bought a Vizio 22" 1080 p TV and need to set up a Verizon Fios remote for it. The codes for Vizio for the remote do not work. Can anyone help me with this.
Steve
SOURCE: REMOTE CONTROL CODES FOR ASTAR TV
Have you tried a Code Search with your remotes. If that does not work try calling or emailing Astar they may be able to help.
Astar Electronics
Tech Support:: (626) 851-2528
[email protected]
www.astarelectronics.com
SOURCE: need code for remote control
To program a TV you can use the code search option. You do this by making sure the TV is turned on then point the remote at the TV then press the TV button once, then press and hold down the set button until you see the RED l.e.d light blink twice, then enter the code 991. Next press the power button then the TV button continue doing that until the TV turn off, when it does press the set button. Press the power button and the TV should turn on again.
SOURCE: Viera Link not work between two brand new Panasonic devices
You need to select setup from the TV menu then switch the Viera link on. I think retuning must have switched it off.
This worked for me
