I bought my OMRON comp air in the US and i want to plug it in Europe. I tried it once with an adaptator and it lighted on and off imediately. Do i need a special electric plug? What to do?
    Problem Solver:
  • 12 Answers
Special converter , with stronger voltage.
Posted on Jan 09, 2013
Toshiba Satellite X200-LC3 no power. i bought new AC adapter but the laptop is not taking juice. no flashing lights. is battery fried that it wont take juice? motherboard issue? please help. This comp
It's either the adapter connection or the MOBO itself.
Anyhow try removing the battery and adapter press and hold the power button for 10 to 20 sec plug the adapter with out the battery and restart. Hope this works if not check the MOBO for jack problem
if battery is already charged try with battery alone. Also be sure adapter is compatible the right voltage IE 19.00, 18.00
Mar 11, 2014 | Toshiba Satellite X200-AA3 Notebook
6 Volt dc 4w charger for Omron blood pressure unit
You can use a multi voltage mains adapter for your Omron. These are available at electronic stores ot on the Internet. Make sure it is a DC adapter and switch to 6 volts also make sure the power connector is set correctly to the polarity of the Omron power socket.
Nov 30, 2012 | Omron Health & Beauty
My comp air elite compressor nebulizer system NE-C21 works fine when plugged in.........I have had the battery charging since this morning and put on the unit and there is no sound...the babbery is NE-C21...
I think it is a factory defect. I have the same unit bought the battery from a reputable distributor (same one I bought the machine from ) machine worked fine using the home and car charger ( which is how I usually used it). I only used the battery for about 5 -7 hours total . By the time I realized the battery was of no use, it was pass the date of return. $125.00 wasted ( the cost of the battery )
Sep 09, 2010 | Omron Compair Elite Battery and Charging...
Omron nebulizer will not mist. All tubing is intact. What to do?
You'll read a lot about making sure that the filter is clean and that the medicine cup is cleaned and that hard water can effect the operation of the nebulizer. However, the problem is most likely in the pump. Even though the pump is running, it is not pushing enough air into the medicine cup. You may even feel air coming out of the tube. When unrestricted, the air will come out, but, once restricted by the medicine cup, the air may not be fast enough to nebulize the liquid. If you want to confirm this, take the tube and hold it to the end of a bike pump, if, while pumpung, you successfully see mist, then you know for sure.
Fixing the pump is not too difficult. Over time, the chamber where the air is compressed becomes dry and, just like a dry bike pump, the air escapes from the chamber due to poor seals. The pump is pretty simple. Make sure it is unplugged from power and remove the screws holding the housing together. Inside you will see the motor, a fan, a power switch and the intake and outtake tubes. Follow the outtake tube to the pump. The junction where the tubes meet the pump is the location of the air chamber. You may need to remove the screws that secure the tubes to the chamber. Once apart, take some grease and lightly coat all of the interior surfaces of the chamber. When finished, reassemble and you're good to go!
Mar 23, 2009 | Omron Healthcare Omron NE-C25 COMP-Air...
Lost installation software for my 350d and I now have a new pc and i am unable to upload my pictures, as the computer will not recognise the camera. camera was bought in us but i am currently in europe if...
most ALL cameras(photo)do not need software to load to a pc(exept maybe vist)
in any case,go to the makers website and brows to support or downloads,they will have software and drivers.
your other option,which in my opinion works the best on any computer or camera,is simply to buy a usb cardreader for your memory stick.
insert the cam memory into usb adapter,and plug into ANY comp.
it's that simple!!
Dec 22, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Acer Aspire 3690-2970
I have traveled to Europe. Australia and China. As this is a laptop I believe your power supply is that often black box in the middle of the electric wire you plug into your laptop. I we operate on 110 volt 60 cycle electricity. The bulk of the rest of the world operates as 240 volts and mostly 50 cycles. The power supplies for laptop I used overseas indicated they operated from 110 - 240 volts and 50 to 60 cycles approximately (small print on the adapter). If your adapter does not handle 240 volt and 50 - 60 cycle requirement you may need to secure another before leaving. The real challenge is to have the right plug adapter for the country you are in. Our two and three prong plugs do not work anywhere else I've been without adapters excluding soem bathrooms for electric shavers only and some universal plugs I have seen installed in China on my last trip (but even in China they were rare). My friend bought two different versions of adapters I believe at Radio Shack - one was a small bag of adapters that covered all of Europe and more recently a single adapter with sliders that could adjust to all the separate adapters he purchased before. I had the experience of buying an adapter in China where I do not speak Mandarin -- pointing at a British adapter and drawing the US plug got me what I wanted however you may wish to solve this problem before you arrive in Europe. Assuming you purchase adapters before leaving the clerk at the store may be able to confirm the suitability of your power supply for general european operation, I tended to double check with the local hotel staff or friends keeping in mind that all counties and some areas can be different.
Dec 15, 2007 | Computers & Internet
I was installing a program, and the screen went black adn the system shut down.
remove battery and try ac-power if laptop boots up then battery need replacing but if no laptop bootup then take it to be repaired and tell the tecnition what happened and he or she will try other options to get you going again. good luck on problem.
Aug 14, 2007 | Acer Aspire 3680 Laptop
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
