Question about Craftsman 10" Table Saw
When i turn off my table 10'' 315.218060 saw makes alot grinding noise
Also wobbles when ripping boards
  • 843 Answers
You probably need to replace the bearings on the arbor shaft. If you have the means to disassemble and press the bearings off, and you can precisely measure the ID, OD and Width of them (there will be two of them and they are probably both the same) you can buy replacement bearings on-line pretty cheap. Make sure you buy sealed bearings. These will be standard bearings, which you don't have to buy as replacements from Sears.
Posted on Jan 10, 2013
  • jim bislow Jan 12, 2013
    very helpfull
2 Suggested Answers
al_kupchella
  • 843 Answers
SOURCE: I have a crftsman table
There's an exploded parts drawing and parts list at the link below. This may be useful to see what the fence is supposed to look like. It's not listed as an assembly, just a surprisingly long list of parts that would cost a fortune - if they were all available. Maybe you can find one on ebay. Barring that, you can always just clamp a board to the table to rip with - the hard part is getting the makeshift fence to be parallel to the blade. To do that you can use an adjustable square and measure from a miter slot in the table to get a quick and straight setup. Good luck.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-137228210/0247/0744600/P0104056/00001?blt=06&prst=0&shdMod=137228210#Partslist
Posted on Feb 09, 2011
Craftsman miter saw
Hi Ralph:
Sounds similar to a dry bearing problem that I experienced.
I'd try oiling the bearings.
With the saw unplugged you could try turning the blade to determine if you can feel any "grinding" that would confirm the bearing problem.
Hope this helps.
Oct 13, 2015 | Craftsman Saws
New to table saw use, have my husbands old 10 craftsman, was learning to rip with it doing fine, then it started to bog down during cut until the blades stops, moving. put on a new blade and noticed...
If I understood correctly, you started using your husband's table saw and while ripping boards, you managed to stall out the blade AND motor?! If that's the case, you probably have a very dull blade and are binding your board on the blade. Neither is safe and it sounds like trouble is brewing.
First and foremost, get someone to show you how to safely and properly use and adjust the saw if you are new to wood working and power tools. That saw is capable of turning your lumber into a high speed missal if you do things improperly.
It also sounds like you tried installing a new 10" saw blade. Changing the blade requires 2 wrenches. One to hold the arbor and one to tighten the nut. The blade itself should rest on the arbor between two large washers. Also make sure you install the blade so the front face of the cutter teeth face you and rotate toward you. Make sure the saw is unplugged when changing the blade and never turn on your saw with a loose blade.
Oct 20, 2013 | Craftsman 10" Table Saw
Grizly table saw 53 inches, making a grinding noise.
That would have to be the motor bearings or the shaft bearings for the saw blade.
I would take off the belt and spin each one separately to try to find out which one it is a replace the bearigs.
heatman101
Aug 21, 2010 | Heavy Duty Saws
Failed electric motor on 10" Craftsman Table Saw
by seized is it burnt up or are the bearings just bad, the bearings are minimal but the field/armature would be more. Give me the model number and I will try and find a breakdown and let me know what we are looking for and I will try and help.
Sep 28, 2009 | Craftsman 10" Table Saw
I'm feeding 8/4 alder through the powermatic strait line saw
Sounds like the power feeder is not holding it secure at the end of the pass. Is the outfeed table running level to the saw table?
Just a wild guess, I'm afraid. I haven't used one myself.
The only time I've seen blades wobble like that was when they were light plates, undersized for heavy duty ripping operations. It's truly frightening to watch them overheat and turn to butter like that. I'd recommend getting a heavier plated saw blade if there's any question about yours.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 26, 2009 | Saws
Sounds like I need to lubricate something.
flip over the saw you will see a motor
take it out the bearings need changing.
Aug 06, 2009 | Bosch 4100 10" Worksite Table Saw
Table saw blade wabbles alot when cutting?
This could be caused by several problems. First unplug the saw. Put a known straight edge against the blade (making sure not to contact the teeth) turn the blade slowly and watch for runout. Second make sure the spacers and blade flanges are on correctly. I would just about think it would be the blade. If you provide the model and brand I can do some more research. Good Luck
Jan 03, 2009 | Black & Decker DEWALT 12 In. 80 Tooth Thin...
Craftsman 10" Table Saw Logo
395 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
