Question about SanDisk Sansa e260 MP3 Player
My sansa has a broken display and it is blaring the radio.
The Screen is completly black.
The device doesn't respond to the buttons.
It is blaring bad Spainish radio.
It was in the cold for several hours
I just let the battery drain, and then i hooked it up to the pc to let it charge.
Posted on Jan 21, 2009
I have a blaring noise when I turn one of them on? It wont respond to sound nor channels, just a noise.
Your squelch is stuck open. Check the switches for debris that could be holding the squelch button down. Clean it. If that does not solve the problem, they are not Dealer serviceable. Take the one apart and clean it, you may have debris or water damage. Still noisy? Clean the circuit board where the switch buttons touch it. I still suspect water damage. Next step? New radio.
Aug 31, 2012 | Motorola Talkabout T5620 (7 Channels)...
How do you reset a kindle fire
Your first step is to press and hold the power button for about 5 seconds and then tap the "Shut Down" icon when it appears on the screen. If this does not work (or the device doesn't respond), you must perform a hard reset.
To perform a hard reset, press and hold the power button for 20 seconds and then release it. This should turn off your device. After it has completely shut down, hit the power button again and you should be good to go.
As a side note, please ensure that your device is charged when you perform these functions. I can't tell you how many people have thought their device was broken when it was just a power issue that was keeping them from turning on their device.
Hope that helps!
Jan 30, 2012 | Amazon Kindle Fire
My player got hanged.and its not functioning? what probably the cause and how can i deal with it? it cannot be turned off..the menus are not functioning
Hi,you need to rest your mp3 player...
How to Reset a Sansa Clip
The Sansa Clip is a high-quality MP3 player. It holds hundreds of songs and is built for portability. The "clip" allows you to attach it to your clothing or belt while you are working out or on the go. Even the best MP3 players can encounter some problems, and the Sansa Clip is no exception. If your Sansa Clip freezes up and does not respond, you may have to try resetting or reformatting it.
Instructions
Complete Reset
Turn Sansa Clip on. Press the "Menu" (home) button.
Press the bottom of the scroll wheel until you reach the "Settings" screen. Push the center button to choose "Settings."
Scroll down to "Reset All" and select. You'll be asked to confirm the reset. Select "Yes." This option will simply allow you to reset the language and location settings on your Sansa Clip. It will not erase data from the clip. To do a complete factory restore, follow Steps 4 and 5.
In the "Settings" menu, scroll down until you reach "Format" and then select. You will be asked to confirm that you wish to format. Select "Yes."
Wait for the screen to say "Formatting Complete." You have now cleared all the files from your Sansa Clip and reset it to factory settings.
Resetting a Frozen Sansa Clip
Push the power button up and hold it for 20 seconds. Release it, then turn it on again.
Go to the Sansa website and download the "Sansa Firmware Updater."
Select "Run" when the updater installs. (Installation will take less than two minutes.)
Wait for the Sansa Firmware Updater to run through its system test. It will ask you to connect the Sansa Clip to the computer to update your Sansa's software.
Connect the Sansa Clip. Remove it from the computer when instructed. If this process does not unfreeze your Sansa Clip, contact Sansa support at the Sansa Firmware Updater website.
Tips & Warnings
Instructions
Complete Reset
Tips & Warnings
You should download the Sansa Firmware Updater to your computer even if you aren't having a problem with your Sansa. This will ensure that your device software remains up-to-date and free of technical glitches.
Reformatting the Sansa Clip will erase all songs and data on the device. Resetting will simply change your player's settings.
Feb 19, 2011 | SanDisk Sansa Clip MP3 Player
Sansa express player does not respond, looks like it's off (screen is black) but when connecting headphones it makes the sound as if a song is paused, computer can't see it so its impossible to format. ...
Try and do what is called a Power Reset. To power reset the device, simultaneously press and hold the center and volume up button, while connecting it to the PC.
If this fails, charge the device for at least two and a half hours. The computer should not go into sleep or hibernation state while charging.
Then you may want to update the players firmware by downloading and installing the Sansa Firmware Updater.
Jan 30, 2010 | SanDisk Sansa MP3 Player
My view wont do anything, when i turn it on the only thing it does is turn the dial light blue, nohing else, when i plu it in, nothing. the blue light will stay on for however long the battery lasts, is...
Solutions are in order of increasing probability of data loss AND device recovery.
Screen messages are loose approximations
A Soft Reset
1. Hold Power switch up for 5 seconds.
2. Screen displays "Goodbye".
3. Restart
B. Hard Reset
1. Hold Power Switch for 30 seconds
2. Restart
C. Recovery Mode
1. Hold Power Switch for 5 seconds to switch device Off
2. Move switch to Hold
3. Press and hold Home button
4. Connect USB cable to device
5. Screen displays "USB" in small type and "16 MB Format" shows up in My Computer
6. Copy firmware files to "16 MB Format" drive letter
7. Disconnect USB cable
8. Screen displays "Firmware update"
9. Restart device
C. Force Format (This one wipes the data partition. Make sure all needed music/pictures/video exist elsewhere)
3. Press and hold top/North/up of Scroll Wheel
5. Screen displays "Format and lose data"
6. Press right/East on Scroll Wheel to confirm
7. Screen displays "Formatting"
8. Restart device
D. Manufacturing Mode (included for completeness only)
3. Press and hold centre of Scroll Wheel button
5. Windows detects a new hardware device
6. ???
7. ???
8. ???
Dec 27, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Verizon -LG VX5500- screen display problem
If the phone will do other things like ring when called, or seem to respond when you press buttons, then the lcd is either bad or the connector is loose. But if the phone will not ring when called and doesn't seem to respond to pressing buttons, then there is something wrong with the phone itself. Always try taking out the battery if you haven't already.
Sep 13, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Sansa view is no longer recognized when plugged into USB port
A Soft Reset
3. Restart
B. Hard Reset
2. Restart
C. Recovery Mode
9. Restart device
8. Restart device
6. ???
7. ???
8. ???
Sep 07, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
I turn my sansa 280 on, it displays "key locked, system shutdown
there is a hold button on the top of your device. move it to the left and then turn it on.
Mar 22, 2009 | SanDisk Sansa E280 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
23 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
