Question about Danby Refrigerators
Kegerator fan The fan is making a loud noise when it runs
4 Suggested Answers
tech master
  • 120 Answers
SOURCE: True TDD-1 beer kegerator condensor fan not running
cenck for volatge at wire harness and if you get the right volatge then repl condenser motor you can use a small portable fan just face it at compressor while you look for part and tha will kepp compressor from over heating and tripping the relay on it ok
Posted on Oct 15, 2008
sawdust46694
  • 398 Answers
SOURCE: Making a loud noise sounds like Fan
ok first i want you to pull your Refrigerator and look for a part of a loaf of bread or something else that has got inyour fan. hope this helps. if you don't find anything you may have a bad bearing on one of your fans. there are to fans one under the rear, and one inside the Refrigerator that you here when the door opens and closes pay close attn: to both!
good luck sawdust46
Posted on Aug 03, 2009
localwonder
  • 6784 Answers
SOURCE: loud fan noise
HI. Just so you know, Hissing and popping is normal on frost free refrigerators, it is the defrost heater, in this case. I would check these following areas to address any other abnormal noises.
If the level of the unit is not adjusted to proper specs, this will create an unstable operating condition, causing many noises to emit from the units structure. inspect the unit for proper level. adjust if needed. Next will be the drain pan. Once removed for cleaning, the pan must be replaced in position correctly. If not, the pan will rattle against the compressor, causing a ping or rattle.Simply reposition the tray if this is the case. The third possible issue will be the condenser fan. The condenser fan is located behind the refrigerator. It may be necessary to remove an access panel to reach it. This fan has a shroud, and if the fan blade becomes warped, it will rub against the shroud, causing noise. This fan blade is whole,and it can be removed and replaced if this is the case. Ok, the fourth problem spot will be the evaporator fan.
The evaporator fan is located at the back of the freezer. It may be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice maker and the rear inside panel of the freezer. The rear panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. Check the fan for warped blades. if the blades are warped or mis-aligned, replace it. This fan also is protected by a shroud as well, and it will make noise if the fan blade is damaged.
Last, i would move on to the compressor mounts. This is the most common spot for noise overtime. The compressor sits on rubber mountings. Those rubber mountings are designed to absorb vibration from the compressor. As the mountings age, they can become hard or disintegrate. When this happens, the compressor vibration is transmitted to the refrigerator structure and it can cause noise.
The compressor is located in the rear. It may be necessary to remove an access panel to get to the compressor.
Locate the compressor and remove the screw or retaining clip of just one of the compressor mounts.Using a pry bar, lift up the compressor enough to slip out the rubber mount. Inspect the mount for deterioration. The rubber should be firm but not rigid. If the mount is crumbling or hard, it should be replaced.
This concludes the inspection procedure. Follow carefully, and replace any failed or damaged device.
Posted on Jun 02, 2010
GE dehumidifer fan making loud knocking noise
possibly have to take motor and fan out as a unit to get fan off .
Sep 19, 2015 | General Electric AHH40LH Dehumidifier
Why is it making a loud clicking noise?
If it makes a loud clicking noise on startup or shutdown, it could be caused by a weakness in the springs that hold the compressor in place in the hermetically sealed shell.
If it is a constant noise while compressor is running it could be a slightly bent fan blade hitting its surroundings. Check the condenser and evaporator fans.
Aug 31, 2015 | Refrigerators
My kegerator out of the blue starts making noises?
Good chance the compressor is going bad. It will likely die shortly.
May 03, 2014 | Danby DKC645BLS Compact Beverage Cooler
Kegerator not cooling
which fan , inside or out.. if outside condensor fan is running then it has a bad 175 capacitor or if the compressor is running then it is low on refrigerant. if the cond fan is not running then check thermostat.. you can do this by connecting the two wires together.. another way to check the compressor, cond fan is to reach under and unplug the wires going to comptessor and plug into a 12ga extention cord.
Nov 17, 2013 | True Direct Draw Systems: Kegerator...
I have dell 3300mp,when I turn the power on it makes a very loud noise. It does not make the sound in standby or cool down. It does work and display a signal okay, but it is very loud. Sound like a fan?,...
The main fan that cools the lamp is mostly high speed when the unit is running. when it shuts down it slows the fan down, until it stops in standby. So the noise is only really loud when it is showing a picture.
try setting the fan to eco mode (slower running) and see if the noise is acceptable. If it is still too loud then you will have to replace it. Have a look at the fan and see if any of the plastic blades are missing.
Mar 26, 2011 | Dell 3300MP Multimedia Projector
Ps3 loud fan noise
Don't do anything your fan is just fine it's just running faster to keep it cool when you hear a clicking sound at high speed then you should be worried about it cause your fan is failing and should be replaced
May 31, 2010 | Sony Playstation 3 (PS3) Console
I have a beverage air kegerator that seems to work fine, but the evaporator fan runs constantly. Is it supposed to run constantly, or is it supposed to cycle on and off with the compressor, etc.?
Most evaporator fans run all the time. This is mainly to use the air flow to assist in melting off any frost build up during the compressor off cycle. If that fan shut off with the compressor the coil will have a tendency to freeze up. :)
Aug 13, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Outdoor unit fan making noise when running sounds
Bearing in fan going out. Let it run till it quits or call service tech to change motor. Fix cost about 250 to 300 dollars. russ
Jul 22, 2009 | Carrier Heating & Cooling
Oct 15, 2008 | Refrigerators
Refrigerators Logo
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
