Question about Kodak EasyShare C913 Digital Camera
My camera will not come on
It will not power.
    Genius:
  • Kodak Master
  • 1,019 Answers
Hello Pam, There are many reasons for this problem occurring, Low battery power, Faulty contacts, bad switch,etc. The camera will need to be looked at to determine the exact problem that you are having.
Best Regards, Russell
Posted on Jan 24, 2013
Turn power off and on again appears on the screen
Turn the Power Off and On again error message is displayed when the Lens in the Camera is stuck is affected by a malfunction. Try turning off the power and on again. If the issue persists, try performing a power reset.
To power reset the Camera; turn off the Camera and remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the Camera to remain without power for 60 seconds.
Then, reinsert the battery and check if it helps.
You may also try INITIALIZING the Camera.
To Initialize the Camera, press the On-Screen key.
Touch MENU-->SETUP-->SETUP 2-->INITIALIZE-->OK. Initializing the Camera will change all the settings back to factory reset.
If the issue persists, service may be required.
Thanks for using FixYa
KenSolutions
Dec 06, 2010 | Sony Cyber-shot DSC-N2 Digital Camera
Tip
Low Power Warning For Full Charged Camera Battieres
<span> <p>I have noticed that, some users asked that, there old cameras always display low power warning for full charged new batteries, or there will be a low power warning after only taking 5-6 pictures.<br /> <p>If you have met this question (I wish not), I'd like to share the solutions.<br /> <p><span> <p>The this problem are so common for <a href="http://www.digital-camera-batteries.net/canon.htm">Canon PowerShot</a> A series cameras when you try to powered your camera by Ni-MH batteries. This is because that, the camera judge the battery is power off by voltage of the battery. And if you use Ni-MH batteries for your camera, the Ni-MH batteries' voltage is lower than the Li-ion ones and close to the camera's judge voltage of low power, so the camera will warn you to change a new battery.<br /> <p>So if you use <a href="http://www.digital-camera-batteries.net">Li-ion camera batteries</a> this questions will be solved simply.<br /> <p>From <a href="http://www.pda-battery.ca/camera-tips/digital-cameras-low-power-warning-for-full-charged-new-batteries/">http://www.pda-battery.ca/camera-tips/digital-cameras-low-power-warning-for-full-charged-new-batteries/</a><br /></span><br /></span>
on Apr 26, 2011 | Cameras
Camera says turn the power off and on
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Thanks,
KenSolutions
FixYa
May 14, 2010 | Sony Cyber-Shot DSC-W7 Digital Camera
The on off button is stuck in. is there anything you can do or do i just buy a new one.
Reset the camera
  1. Turn off the camera, if possible.
  2. If an SD memory card is installed, remove the card.
  3. Remove power from the camera as described below:
    • If you are using only batteries for power, open the battery/memory card door and remove both batteries.
    • If you are using only the HP AC power adapter, disconnect it from the camera.
    • If you are using both batteries and the HP AC power adapter, remove both batteries and the power adapter.
  4. Wait for 15 seconds. Then reinsert the batteries and close the battery/memory card door or reconnect the HP AC power adapter to the camera. If you are using both batteries and AC power, try each method separately.
Turn the camera on and off. If the issues is not resolved do the following
Connect the camera to the optional AC power supply
  1. Connect the camera to the optional AC power supply. Ensure that the AC power supply is connected to a working power outlet.
  2. Try turning the camera on.
  • If the issue is resolved , you do not need to continue with the rest of the instructions in this document.
If the is not resolved ,then repeat setps 1 to 4 abiove but remove the batteries and keep the AC power adapter connected.
Oct 14, 2009 | HP Photosmart M425 Digital Camera
On the Sony DSC-H7 camera can you disable the auto power off? If not does the use of an external power supply disable it? Thanks
The auto power off function that operates if the camera is not used for about 3 minutes, when operating on battery power, cannot be deactivated.
When using the camera the camera powered from the Sony AC-LS5 AC mains adapter, or with the Sony DCC-L1, DC power adapter, the camera auto power function is deactivated whilst the camera is connected to the power supply.
Jun 17, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
Black screen
Turn the power off and on again message is displayed when the Lens mechanism is stuck or when there is an internal malfunction. To resolve the issue, try turning off and on the power for few times. If the issue persists, try power resetting the Camera.
To power reset the Camera, remove the battery from the Camera. Press and hold the power button of the Camera for 30 seconds. Remain the Camera without power for 60 seconds and reinsert the battery to check the operation.
You can also try Initializing the Camera by selecting the INITIALIZE option from the SETUP1 Menu of the Camera.
Nov 24, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony cyber camera
The Camera is displaying the Turn the power Off and On again message when the Lens in the Camera is stuck or when any internal malfunction happened.
To resolve the issue turn the power off and on several times. If the issue persists, try power resetting the Camera. To power reset the Camera, remove the battery from the Camera.
Press and hold the power button on the Camera for 30 seconds.
Remain the camera without power for 60 seconds and re-insert the battery.
Also try resetting the Camera back to factory default. Press the RESET button located at the lower right corner of the control buttons using a sharp pointed object.
Good Luck
Nov 19, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Powering off
Lens mechanism isn't good to work properly so camera shut down the power. Try to tap the lens/ camera while power up.
Jun 24, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Error message saying video lost and not recording
There are several possible issues at play whenever the lost video message appears.
First, have cameras lost power? If you powered cameras through a central power source, inspect it and verify it is working
If you powered cameras through a plug in transformer, touch it, if warm it is working
Next touch the cameras, are they warm? If so, they have power.
Once you have determined cameras have power, disconnect power for several minutes. Turn power back on, if cameras respond and send video, your cameras have likely suffered damage from a power surge and are near failure.
If you have access to a small tv with an RCA video in jack, you
can test this by leaving the camera powered, run a short length of cable from the tv to the camera. We use hand held mini monitors to test this, but they are pricey,
It is most likely that have power surge damage and the cameras need to be replaced
Oct 25, 2007 | Geovision GV-650 BNC (GV6504) Video...
Camera not powering on
Hello... 1)camera is not turning on . Is the battery inserted correctly? Check the direction of the battery. Is the battery sufficiently charged? Use a battery that has been sufficiently charged. 2)camera switches off after powered on * Is the battery charge insufficient to operate the camera? Use a battery that has been sufficiently charged. * If you leave the camera on, the battery will be exhausted. Turn the camera off frequently by using power save mode or economy mode etc.
Jul 20, 2007 | Pentax Optio S5z Digital Camera
Kodak EasyShare C913 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
