Question about Friedrich WallMaster WS07A10D Air Conditioner
Does not heat what is wrong ?
Fan works but does not heat
2000 acura tl coolant fan after fluid change
New thermostat, installed, saw, new coolant made a little mess filling reservoir, (normal) checked fan fuse for some reason, and condenser fan fuse (xxx ?:), and temp guage, is slightly lower on gauge (than normal?) (disconnected xxxx? quit? a bit? to get to thermosta?.t no dash warning lights have a feeling I popped a relay.
Answer:
ok, you did a coolant service with STAT,
and it failed.
tell us what works right and wrong, symptoms only.
over heating? parked, (fan never comes on)? as it hits 225F?
under heating? ( fan stuck on , up North can cause huge cold engine)
dash gauge stuck low. (thermostat wrong heat range 180f is best. see FSM for spec. on this temp. spec..
Dash guage varies.? oddly (air in system)?
Dash gauge too high.? (Stat put in upside-down or bleed hole (jiggle) not UP side. higher side of mount , trapping air.)
Does something wrong happen only driving?
leaks?
does cap on rad hold 12-14psi pressure, hot.?
if car has fan belts, are they tight? (for sure water pump does)
Nov 19, 2013 | 1994 Honda Civic
Home AC only blows cool air when set to fan. When placed on Auto/fan it doesn't blow and no heat.
At your thermostat ,
Set switch to heat, turn up temp switch.
Fan should be set to auto. Wait up to 5 mins to be surethat somthing is wrong. If your fan comes on without heat. Check gas valve or if heat pump check main a/c breaker. If elect heat or any of above dosn't work.
Call a service company. If your in Pensacola. Look up Absolute Heating and Air Conditioning.
Oct 30, 2012 | Heating & Cooling
My fan don't come on .
thers afew thing you can check (fan no good at all,wireing problem or faulty,fan fuse,not comunication between heat sensor and fan.i mean if the heat sensor is not working properly tthe electronic system wont let fan know when to start. so you can start checking those essues 1 by1 and may sure each 1 of them are working properly .that will be the easy way to start looking for this problem.if you find any of this working wrong , then you just found the problem resolved.good luck
May 20, 2011 | 2000 Volvo S80
My whitewestinghouse dryer trumble but no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 27, 2011 | Westinghouse Industrial Plus White-...
Microwave doesnt heat, power is on fan is working
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
klgjlgk
Jul 06, 2010 | GE JVM1540SMSS Microwave Oven
Over heating. four machanics checked ( dealer said nothing wrong, not over heating for them ) they changed temp. sensors they say. They check hoses and said all good. the radiator fine too. radiator does...
You have two fans, one should cycle if the engine gets up to temp. say 190degs. The other should come on if you turn on the A/C. So start the engine check the fans, then turn on the A/C recheck the fans. One should be running with the A/C on. If not, this is the cause of your overheating problem. Check all your fuses, go to a local parts store and have a clerk check the fan relays.
Jun 06, 2010 | 1998 Dodge Caravan
My oven will noit heat up. All the displays still
If it is an electrically heated fan oven, and the fan is working o/k, then chances are it is the oven element that is faulty.
This is usually located at the rear of the oven compartment behind a removeable cover.
Feb 03, 2010 | Ovens
Fan stopped working
If it is heating without the fan working, then there is probably something wrong with the fan.
If there is no heat as well as the fan not working, then check that the timer is set to manual and not on auto.
To access the fan and heater, remove the rear panel inside the oven, spin the fan by hand,it should be completely free,
If it is not, then it needs replacing.
Plz rate my solution.
Thanks
Jan 02, 2009 | Belling XOU252 Electric Single Oven
Friedrich WallMaster WS07A10D Air Conditioner Logo
19 people viewed this question
Top Friedrich Heating & Cooling Experts
Bill Long
Michael Vincent Cruz
Tim Whalen
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
