Question about Garden
The bolt at the end of the line trimmer does not screw in all the way, and there is no washer for this part. Is this correct? When I assemble the full bottom section of the line trimmer, the section t
    Genius:
  • 1,669 Answers
Believe it or not, I have no idea who the Manufacturer is, the make or the model of your trimmer is! Without this information no one can help you!
Posted on Jan 10, 2013
3 Suggested Answers
guru_fixya
  • 944 Answers
SOURCE: need to remove the bottom
You have to hit hard from the back side of the bolt in such a way the locking nut will stand still.Mostly in your case it has been stuck and the rim rounding is damaged.Mount bolt put some WD-40 oil and screw it out.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 16, 2010
  • 403 Answers
SOURCE: how many turns do I
cant help unless I know what the carb is, sorry.
Posted on May 26, 2011
How to remove clutch assembly from crankshaft
the clutch screws onto the end of the crankshaft with left hand threads so turn it like you would tighten most other bolts
Aug 06, 2012 | Craftsman Garden
Replace trimmer line
The steps for replacing line in a single line trimmer head are virtually the same for many trimmer head types, like double line trimmer heads.
1. Remove the Trimmer Head Spool
Removing the spool is the first step in replacing trimmer line in any conventional trimmer head, but trimmer head spools can disassemble in different ways.
The trimmer head pictured above and below disassembles by simply unscrewing the knob around its arbor bolt. Other trimmer heads can use press tab and other twisting styles for disassembly.
2. Insert Trimmer Line and Wind the Line
Single line trimmer heads have just one channel in their spools for winding line. The channel will have a hole in it somewhere that keeps the line in place as it is wound around the spool. Insert one end of the trimmer line in the hole.
Depending on the trimmer head, it might be helpful to bend a small portion of the cutting line at an angle before inserting it in the starter hole. Also, cutting the line at an angle can help this first step on some trimmer heads.
Of course, it is also important to make sure that the replacement line matches the diameter specification of the trimmer head before beginning. Once the line is started correctly in the channel hole, you're ready to wind. Most trimmer heads will indicated the correct winding direction right on the spool somewhere.
It's also important to wind the line carefully, keeping it in neat rows as much as possible. The line will have a much higher chance to feed incorrectly during trimmer use if it suffers from sloppy winding.
3. Snap the Line into its Retaining Notch
A conventional trimmer head will have a retainer on its spool. Snap the end of the trimmer line into the retainer after it is wound around the spool. The retainer will hold the line in place as the spool is replaced in the trimmer head assembly.
4. Replace the Trimmer Head Spool
With the cutting line held in place, the spool is ready to be replaced in the trimmer head assembly.
First feed the extra trimmer line through the trimmer head eyelet. Make sure to release the line from the retainer before completely securing the spool into position.
Replace any knobs, bolts, or other trimmer head pieces removed during disassembly.
Your single line trimmer line is now reloaded, and your trimmer should be ready to get back to work.
Although there are many steps to reloading line the conventional way, a little practice and familiarity with your trimmer will speed the process up a great deal. Once you're up to speed, reloading trimmer line this way can take less than five minutes.
If you want to know about the double line replacement, please click this
Thanks.
Apr 01, 2012 | Garden
I need to feed the line back into the holes on the craftsman 17' 25cc weed trimmer. I dont know how to remove the line holder to replace
Although it is called dual line, only one line is used - except that you use both ends of the line. Cut off as much line as you think the spool will hold. Put the two ends together to find the center of the line. Some trimmers have holes to thread the lines through and others have a place to hook the bend at the middle of the line. if yours has threading holes, thread one end of the line through each hole and then pull on both ends until the bend of the center of the line won't allow any more slack. If your trimmer has the place to hook the bend, hook there and start winding the lines in the direction shown on the spool. Be sure one line is on one half of the spool and the other line on the other half. Wind both lines at the same time as smoothly as you can. When the spool is full, insert the loose ends through the trimmer head, insert the spool and pull on the strings. Hope this helps Tim
Here is a site that can help if I did not understand your question correctly:
http://www.ehow.com/how_7872475_replace-craftsman-25cc-line-trimmer.html
Apr 10, 2011 | Craftsman 25cc Gas Line Trimmer
I have a Ryobi 700R trimmer - I need to know how to replace the pull cord - Tom
If your pull cord is still attached to the grab handle, it's likely your spring is still wound. Follow this if this is the case:
1. Disconnect the shaft by removing the small set screw and the clamp - pull the shaft out of the engine body.
2. Remove the recoil assembly (About 5-5 torx bolts).
3. Pull the cord until the stops and use a small piece of wood acting as a wedge to jam between the recoil and the housing.
4. Cut the line and pull the knotted terminating end from the hosing.
5. Keep the wedge tight so it does not spin back. If this happens, you will simply need to rewind the spring back (about five turns) and re-wedge it.
Use proper line and reverse for new line. Good luck!
Aug 31, 2010 | Ryobi Garden
I received my LWG151P yesterdat and I am having problems with assembling the safety guard. It does not fit, it appears to be about 1/4" too short and the hole does not line for the screw to fit. Any...
If you can, just mark and drill out the guard with a powered drill and drill bit (not too big) in the correct location for the screw(s) to fit. When in doubt, just drill it out! Plastic or metal guard....doesn't matter....a steel cutting drill bit will go thru both. Sometimes drastic engineering flaws cause for drastic solutions.
Aug 27, 2010 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
How to install replacement line for a Ryobi 18v weedeater
The long bolt coming down at the end shaft like place reel over bolt then turn back and forth slowly while pushing upward and it should lock in and take knob or bolt at end and tighten to the right.
Jul 05, 2010 | Ryobi Garden
Trying to remove a clutch rotor assembly on a craftsman trimmer and not sure how to remove it. looks like it unscrews from the shaft
It does unscrew from the shaft. The Torx screw holding it is hidden and doesn't come out of the housing once it is loosened. It is screwed into the end of the shaft. You will have to keep the engine from turning to loosen it. Pull spark plug out and move piston to bottom of stroke. Put some nice, soft, clean rope in the cylinder and let the piston compress it when you turn the Torx screw in the clutch rotor housing.
Jun 30, 2010 | Craftsman 25cc Gas Line Trimmer
How do you remove the line feed to replace with new. Is is scred on or does it have a lock washer
It should be screwed on. There should be a half sphere-like object on the bottom of the spool where the line goes. Twist counter clock-wise to remove.
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer: Then just wind a single piece of string clockwise onto spool. This may need to be longer than 7ft.
Jim
Oct 17, 2009 | Craftsman Convertible 25cc. Gas Line...
Pull rope is striped
remove the starter housing, usually only 3 or 4 bolts or screws. on the inside should be a large white or black wheel, hold the outer case with one hand and rotate the wheel counter-clockwise with the other as many times as can without force. on the inside of the wheel should be a small hole, rotate the wheel to line it up with rope guide hole on the outer case/housing. use a nail or small screwdriver to help hold in place. feed the start rope through the 2 holes and tie a knot at the end, single or double depending on the size of the hole. if the end of the rope is frayed, use lighter to melt and twist to a point to make it easier to handle. when reassembling you may need to jiggle the handle for realignment. it works on an inner spring coil tensioner system, so if the cable has no tension when rotated or doesn't recoil back, the starter assembly will need to be replaced.
May 21, 2009 | Craftsman 25cc Gas Line Trimmer
How do I pull the clutch assembly to replace the pull rope?
Sep 13, 2008 | Craftsman 22" Gas Hedge Trimmer
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
