Question about Amana PTC153B50AJ Electric Heat Air Conditioner
I need remplacet mother board - Amana PTC153B50AJ Electric Heat Air Conditioner
Need new mother board for flytech bladestar
it may be that your contoler got wet or spilled on or mother board had a short on it see woowee .corp
Feb 05, 2013 | Wowwee Flytech Bladestar Indoor Flying...
The van don't start even i changed a new battery. The eatx shutdown relay make a sound. But I don't if i must sumply remplacet. Thank you!
check to make sure the small black wire that runs to the negative battery terminal is connected properly and corrosion free it will cause this issue /hope this helped
Sep 20, 2010 | 1999 Plymouth Voyager
I need a new mother board my mother board was
The first thing when spilling drink on your electronics is to remove ALL power.
Then wash the circuits with DISTILLED, de-ioniozed water till all traces of the spillage is gone. Next driop dry with one corner down and finally let dry a few days.
The only damage the spillage usually can do is electrolysis from the power source. Circuit boards are washed with water during manufacturing. Use DE_IONIZED !!!
Oct 07, 2009 | Compaq Presario 700 470024-192 Notebook
I need driver mother board genx your help me
i will need the model number and the make of the mother board
Jul 03, 2009 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Computer will not start
first you connect your harddisk data cable to mother board
connect your hard disk powercode using smps
connect smps 24pine connector threw mother board
connect 12v connector threw mother board
connect cpu&external fan connections
also connect the front panel connections on mother board using mother board details
Jun 17, 2009 | ASUS A7N8X Motherboard
ASUS P5S800-VM mother board V Asus EN9500GT graphic card
you would need a new mother board or change the graphics card
Feb 11, 2009 | ASUS P5S800-VM Motherboard
KOB845Gx mother board driver
need KOB845Gx mother board drive please
Sep 06, 2008 | SIS741GX-MN Motherboard
Want to put an pentium 4 proceser into my i connect what one do i need
We need the Model of the Mother Board and Details of
Bus Speed ?
RAM ?
then only we can suggest the compatable processor for the
Mother Board
Aug 05, 2008 | Computers & Internet
Amana PTC153B50AJ Electric Heat Air Conditioner Logo
23 people viewed this question
Top Amana Heating & Cooling Experts
Bill Long
Pete Norton
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
