Question about Kenwood KDC-BT652U
My Kenwood KDC-BT652U won't show all the music on the USB drive that I have attached.
I have a PNY Micro Metal Attache 32gb USB drive attached to my product, but it does not show all the music that is stored on it, only some of it. The rest of the folders say 'No Music' when there really is music on the device.
SOURCE: kenwood dnx7100 pictures
for the pics, make sure the usb is not selected as the source, in other word when you hook up the usb, go and the press the radio butten, the go back to the background options and the "change" icon should be highlighted
Posted on Jan 27, 2008
SOURCE: usb kdc-x890 IPOD
The 890 doesn't support iPod control via USB. You can only read plain data storage devices on the USB port, such as a flash drive or portable hard drive. When you plug the iPod in (to a PC or the 890), it doesn't show up as a plain file storage device. Some of the newer Kenwoods do offer direct iPod control via USB. These ones have more "smarts" and are able to properly talk to the iPod and access its music. For the older models, you'll need to buy the special iPod interface, which accesses the iPod like a CD changer.
Posted on Jun 12, 2008
  • 3 Answers
SOURCE: Kenwood KDC-MP438U "USB ERROR"
IF YOU DID NOT PRESS THE RESET BUTTON NEX TO THE USB PLUG, DO IT. IT WILL REINITIATE THE DEVICE TO THE FACTORY; YOU WILL HAVE TO ADJUST THE CLOCK.
I DID BECAUSE IT WAS WORKING AT FIRST.( PAGE 3 OF THE MANUAL)
CLAUDE
Posted on Jan 19, 2009
  • 18 Answers
SOURCE: I can't play my iphone on my kenwood KDC-MP435U
Jennifer, I have the same issue. the problem is that the 2007+ generations of Kenwood receivers are not compatible with the iPhone. You will need to get a 2009+ series in order to use your iPhone with the head unit. I had the same issue with the Kenwood KDC-MP435U in my mustang. I am going to get a newer head unit that supports the iPhone. You cannot do it with the MP435U.
Posted on May 30, 2010
  • 35 Answers
SOURCE: I have a kenwood KDC-MP438U stereo. Ipod error.
Hi If anything the stereo was probably designed and tested using a certain version of the Iphones software, now that version 4 has been released the way the IPhone communicates may have changed.
As a result the stereo is no longer able to talk to the phone and vice versa. your probably best off contacting Kenwood direct to see if they are aware of this problem and if there is anything that can be done about it.
Posted on Jul 28, 2010
How to remove write protection
How to tke write protection off a pny attahe? - Hard Drives ...
www.tomshardware.com > Forum > Storage
Tom's Hardware Guide
Sep 22, 2012 - 6 posts - ‎3 authors
Hello, I have a 64 gig attache 2.0 flashdrive. ... I could not see a write protect switch in the PNY product guide, but just ... I've been trying to do this for nearly a year and today found the tool to format my 64GB PNY flash drive. ... the Link you provided and downloaded the recovery tool for my PNY USB 64 Gb ... USB Flash Drive is write protected and shows up as ...
Nov 11, 2012
Remove write protect flash memory USB - Flash Media ...
Nov 30, 2009
More results from www.tomshardware.com
how do i take off my write protection off
Jan 16, 2016 | PNY Attache 64GB USB Flash Drive
I plugged an iPhone USB cable into my Kenwood KDC-BT652U head unit and heard a pop through the speakers in my truck. I lost all power to the head unit and now it won't turn on at all. Any ideas????
Check the fuses on the head unit. There should be one that you can check, it might be that the cable pulled too much current. USB is not a high current provider.
Jan 30, 2014 | Kenwood Kdc-bt652u Cd/mp3 Receiver...
PNY Attache flash drive not being recognized
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
Sep 15, 2011 | PNY 4GB Micro Attache USB 2.0 Flash Drive
Cannot delete pictures from my PNY card
Check to see if you have the lock switch on, this is a small slider on the side of the card. If it's enabled you will need to slide it to unlock and place it back into the computer/camera. You will then be able to delete the contents of the card.
Aug 01, 2011 | PNY 4GB Micro Attache USB 2.0 Flash Drive
Windows XP home edition not regonising PNY pendrive micro attache 2G
control panel admistrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
Dec 27, 2010 | PNY 4GB Micro Attache USB 2.0 Flash Drive
Need driver for pny mini attache 2.0
Here are a few possible sources for your driver software :
http://en.kioskea.net/guide/905619-pny-pny-mini-attache-4gb-usb-2-0
www.paretologic.com/lp/drivercure
http://www.helpdrivers.com/ingles/listado/panel.asp?marca=PNY&perif=otros
http://driverscollection.com/?V=PNY&S=48
try these sites they should provide you with success
Jan 04, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Will it work on windows ME?
It works fine with my new Dell which is running windows.
Dec 13, 2008 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Optima attache
You may need to uninstall your USB port drivers thru the Windows Device Manager and reboot . Windows will see your USB ports when it restarts and reinstall the drivers which will include support for flash drives including Pny flash drives.
Jun 20, 2008 | PNY Technologies GeForce 6200 128MB AGP...
Kenwood KDC-BT652U Logo
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
