Question about Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore dishwasher model 665.16032400 green blinking light
SOURCE: green light on kenmore dishwasher is flashing
I actually had to change the steps a little and this is what I did:
press heated dry
press normal wash
press heated dry again
press normal wash again
wait a few seconds
all the lights should come on
press cancel (should hear pump)
hit cancel again
Started a cycle and began washing.....Thx
Posted on Feb 05, 2009
jsrock516
  • 5911 Answers
SOURCE: dishwasher blinking light
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models. I believe the problem is attributed to water supply temperatures being too low when filling. Apparently, there are some sensitivity issues with the temperature sensing circuits in some dishwashers. There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation. To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen to heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that you will fill the dishwasher with hot water instead of the cool water that is normally in the lines before the hot water from the hot water tank heats the line. This should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on what the flashing light sequence is in determining WHAT component is bad. Let me know if this helps you. Post back with your comments or questions.
PS Your dishwasher is actually manufactured by Whirlpool.
Posted on Feb 11, 2008
SOURCE: "Clean light" keeps blinking; dishwasher won't start new cycle
It says in the manual to check the heating element.
Posted on Sep 10, 2008
aborcass
  • 2651 Answers
SOURCE: My kenmore elite ultrawash dishwasher,
youll need to enter a diagnistic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, htne press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Posted on Dec 24, 2008
  • 188 Answers
SOURCE: Kenmore dishwasher, model 665.170 344 01. "Clean" light keeps flashing and will not stop. Have tried everything in the manual and the light still will not stop flashing.
If the clean light flashes 7 times, pauses then repeats...
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive).
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Feb 20, 2009
Green light is blinking --says clean when you push
Hello & Welcome to FixYa
Flashing green light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jun 10, 2011 | Kenmore 16764 Dishwasher
The green light for "clean" is blinking green and
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
Kevin
Mar 07, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
The green clean light is flashing. It will not go off even when we press cancel. The wash cycle was not completed. The model # is 665.17283400.
The green clean light means that your dishwasher isn't heating the water. Go to the link below to see how to reset the error code and check for reasons that the error happened.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Good luck
Mar 05, 2011 | Kenmore Dishwashers
Normal wash light blinking, d/w wont start
Wish I could solve this, as I'm having the same problem too. Normal light blinks not matter which wash button is pressed. Cancel light will light, but still NOTHING happens. Same model as yours.
Jul 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Dishwasher won't start - green light just blinks
If it's a Kenmore/Whirlpool/KitchenAid and the blinking light is "Clean", check this and this post.
Good luck
Oct 19, 2009 | Kenmore Dishwashers
Green blinking light
If you don't have the manual for your dishwasher to find out why the green light blinks, try to get the model number off your dishwasher from the inside edge and go online to find a website that provides online manuals.
Feb 26, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
My kenmore dishwasher had green clean blinking light
push cancel or start resume the green clean light will blink after every wash cycle to tell you the dishes are clean on some you just open the door to clear it on some you push stop or cancel
Feb 13, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Green clean light keeps blinking
HI, Same thing happened to me today and Sears more than willing to charge me 200.00 for a 1 year service agreement. I found the answer on askmehelpdesk.com and the answer is: To reset a Kenmore Ultra Wash elite series dishwasher (stuck on clean) simply push heated/dry then normal wash and do the same thing again. Panel will reset itself and it hopefully will run normally again. Mine did and I am rejoicing! Julie
Aug 24, 2007 | Kenmore 24 in. 16302 Built-in Dishwasher
Kenmore 24 in. 16032 Built-in Dishwasher Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
