Question about Nautilus T914 Commercial Series Treadmill
System overload The treadmill shuts down and gives the error "system overload" when the customer is sprinting.
    Top Expert:
  • Nautilus Master
  • 12,223 Answers
Step 1:
see the video and lube the rollers bearings too
Step 2:
test the input voltage motor, if there are the motor need repair
see the diagram attached.
Step 3:
test the output voltage board, for input voltage motor, if there are NOT the board is faulty,replace
see the block diagram
Posted on Jan 09, 2013
Exp1000 runs for several minutes
The control circuit has an overload and will shut down to prevent a fire. It may not be the Motor at all, just the circuit board failing.
Feb 26, 2014 | Nordic Track Nordictrack Exp 1000xi...
Treadmill powers on but belt won't move - Landice Sprint 8700
see the video and procedd according. However you must LUBE the deck belt very well+rollers bearing front and back+test the drive belt motor, and replace if necessary. God bless you
Jun 18, 2013 | Exercise & Fitness
T916 treadmill gives me an system overload error
Dear Sir:
In all case this error indicate tha lack of maintenance, specially lubricanting in Deck vs Belt DECK, do oit. By that reason the machine will Shut down for to prevent the electronic system, in order to preserve the electronic component.
see my personal TIPS for diagnose and trouble.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Mar 06, 2012 | Nautilus Commercial Series T916 Treadmill
What should I do for a belt error?
Dear Sir:
Your problem is lack of maintenance specifically lack of lubricating between deck vs belt deck. see your owner manual.
The treadmill had been designe for to protect the electronic system( component) by that reason the equipmen shut down, and display error system.
Run the software calibration for easy diagnose and troubleshooting
additional.
sincerely . God bless you.
ernesto cuadra
Mar 06, 2012 | Exercise & Fitness
The treadmill shuts down and the screan says speed error 12
1) Error - "SI2 At Power Up"
Symptom:
Indicates the OVP (Over Voltage Protection) circuit on the controller is active and belt will not move.
2)
An SI-2 is basically a code that causes the treadmill to shut down. This is generally caused by a fluctuation in the treadmill
Oct 20, 2011 | Exercise & Fitness
Machine shuts off when i press incline up. Belt and board look ok
THis sounds like a controller board problem. In many of the treadmills I have seen the same board controls the drive motor and the incline motor. If this product is under warranty have the company covering the warranty check it out. Anytime you buy one of these machines buy the extenced warranty. I was a field service tech for a warranty company. When you call in with a problem make it sound severe.. I have replace almost everything in one except the frame just to make a customer happy. I am not sure of the error message but i seem to remember it being associated with the controller.
Jun 16, 2010 | Spirit Fitness Z500 Treadmill
Lift motor overload
" Turn the power switch off, wait 1 minute and turn the power switch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
The lower board software contains a protective current measurement, should the limit exceed, it will give the ’lift motor overload’ -error. Try calibrating the lift motor and if not successful. Unplug unit remove motor shroud locate the lift motor. The lift motor driven nut is never supposed to reach either of the ends of the lift motor screw. Should this happen, the nut is likely to get jammed. Check that the nut is not against the motor frame nor against the stopper in the end of the motor screw. In a case like this the lift motor needs to be removed and the nut released by hand.
May 15, 2010 | Tunturi T60F T60F Series Treadmill
Landice 8700 sprint starts at full speed and then shuts down with a 5 error code
This happened to mine and I figured out that the sensors were dirty. I got some canned air that you spray on computers and sprayed out the mother board. I also sprayed the electrical contacts with electrical contact cleaner and the treadmill is a good as new.
Nov 23, 2009 | Landice Exercise & Fitness
Panasonic SC-PM08 shuts down error F74
Very nice unit this one but Im not able to help you with the code but sounds like its shutting down because of an overload . Contact Panasonic but you may be surprised on how bad panasonic treats there customers as it say that Panasonic answers very few of there BBB complaints???good luck
Apr 07, 2006 | Panasonic SC-PM08 Shelf System
Nautilus T914 Commercial Series Treadmill Logo
472 people viewed this question
Top Nautilus Exercise & Fitness Experts
David Payne
David Payne
ray gallant
Techmotionusa.com
Techmotionusa.com
Are you a Nautilus Exercise and Fitnes Expert? Answer questions, earn points and help others
