Question about Kenmore 62622 Microwave Oven
THE MICROWAVE TURNS ON BUT DONT GET HOT
IT TURNS ON WITH POWER BUT IT DONT COOK OR NOTHING GETS HOT
  • Kenmore Master
  • 17,130 Answers
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Check this link to know how a microwave works:
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced. See link:
http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on; use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Posted on Jan 11, 2013
Bought a new white ice whirlpool microwave and the auto vent won't turn on automatically no matter how hot or how long we cook food....we can turn it on manually. The authorized service man replaced...
This should be a warranty replacement if you can get Whirlpool to respond. Try returning the microwave to the point of purchase for replacement
Aug 04, 2013 | Microwave Ovens
Sharp R-1510 1000 watts microwave, not heating
Sounds like the inverter (power supply for cooking) or the magnatron which does the work----neither are cheap parts.
Oct 16, 2012 | Sharp R-1510 Microwave Oven
My new Haier microwave isn't working! I just plugged it in for the first time, and set the clock on it. Then I tried to turn it on. No matter what cook time I enter, and then press start/30 sec., nothing...
When it times down but doesnt heat it is typically a problem with the door switches, especially one you just bought, may have been from shipping . A switch or connection may have been disodged when being shipped to you. Most machines have something like 4-5 wswitches, If 1 doesnt report right it will stiop the unit from running. But since some of them are closed it will accept the programing and try to operate. So a lot of times you get fan running and tray turning but no power to the secondary circuits. You will need to find out who does warranty for them or return it where you bought it as a defective unit.
Aug 14, 2017 | Haier Microwave Microwave Oven
The lights are still on but the microwave will not warm nothing up. someone tried to warm up four big white potatoes and it stop cooking. the timer still count down but u dont hear nothing and it dont warm...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 15, 2011 | Emerson Microwave Ovens
My fan kicked on by itself and won't shut off
The over the range microwave hood has a heat sensor in it. If it senses hot temperatures from cooking below it will turn the fan on. The fan will turn off once it cools down, this is to protect the microwave controls from damage.
May 08, 2010 | Magic Chef CMV1100 Microwave Oven
R9H84B Sharp Microwave Convection from 6-6-1997, power stopped and turntable stopped. Light works and sounds like the power is working but nothing gets hot.
Is this the unit with the door that swings down like a conventional oven?? I think it is. This sounds like a door switch but could be a magnetron or cook relay on the control PCB.
Sep 11, 2009 | Sharp R-9H84B Microwave Oven
The oven will turn on and get warm (not up to set temp)not as hot as it should. I no longer hear the forced air noise from the fan/blower from the back of the oven? It will not cook food, in the time frame...
is your power setting up allthe way (10) is it a convection oven also? microwaves dont usualy have a temp. setting unless there is a probe pluged in inside oven to a jack on inside wall of microwave microwaves can also get old and lose power if so you can get cheep ones at wallmart
Jun 17, 2009 | Microwave Ovens
Microwave not cooking
I would say you have a bad door switch or door switch mount, or your door is loose or out of alignment.
But since it's new, and under warranty, I would contact Goldstar (LG) customer service to have them repair it free.
Contact LG at 1-800-243-0000 or http://us.lgservice.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 28, 2008 | Microwave Ovens
Kenmore 62622 Microwave Oven Logo
20 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
