Question about Seaga Manufacturing SM-10 Commercial Refrigerator
I have a SEAGA glass front cooler. Model SM10, 3.5 AMPS, 60 Hz, 1/5 horsepower. The fan runs, but it has stopped cooling. Any ideas or suggestions on how to fix it or where to buy another motor? I cal
Uses R134A charge at 5.30 oz. Highside 315, lowside 145.
    New Friend:
Where do I find the part # M1F1 for common run start
Posted on Oct 12, 2014
How many Horse power Dei-815/E freezer
Freezers are not measured in horsepower, only mechanical engines. This is the specs, and it is basically a 25 amp freezer, with an additional 7 amps or fans lighting and door heater, both at 250 volts AC. However, running an Amps to HP converter gives 6.971 horsepower.
DEI-815 dual controller with external probe box d
  • DEI-815 dual controller boxed With external probe
    Set Temperature range: -40 to +40
    Tolerance of 1 ° C
    Contact compressor outlet 25 Amp. 250 VAC
    25 Amp Output contact resistances. 250 VAC
    Contact Fans, lighting and perimeter heater 7 Amp. 250 VAC.
    Connection 110- 220 V 50/60 Hz.
    NTC sensors 02 1.5 mt.
Mar 16, 2016 | Cars & Trucks
I need to know what the voltage for this unit
Model: REG-123H
  • UPC: 855326002968
  • Product Type: 12,000 BTU Window Air Conditioner & Heater
  • Product Dimensions: L: 24.00" x W: 24.00" x H: 16.00"
  • Product Weight: 88.00 lbs.
  • Product Color: White
  • Application: Used to cool individual rooms
  • Type: Window Air Conditioner
  • Warranty: 1 year; 5 years sealed system
  • Coverage Area: 550 square feet
  • Voltage: 230 volts
  • Heater: Yes
  • Air Flow: 266 CFM
  • Amps: 5.5 amps
  • Heating Capacity: 11000 BTUs
  • Frequency: 60 Hz
  • Cooling Capacity: 12000 BTUs
  • Dehumidifying Capacity: 3.6 pints
  • EER: 9.8
  • Heat Pump: No
  • Number of Fan Speeds: 3
  • Programmable Timer: Yes
  • Timer Length: 24 hour
  • Refrigerant Type: R-410A
  • Air Conditioner Type: Cool/Heat
  • Energy Star Rated: No
  • Air Filter: Yes
  • Built-In Air Purification System: No
  • Display Type: Digital
  • Remote Control: Yes
  • Adjustable Louvers: Yes
  • Adjustable Side Panels: Yes
  • Compatible Window Size: Min. Window
  • May 31, 2014 | Comfort-Aire RED-123 Air Conditioner
    Need wireing diagram for AO Smith 1HP motor S#C56A97B08 Ser32409J2
    less hassle replace whole pump if motor over heated possible bad seals and distortion to pump housing will leak
    Dec 04, 2017 | Pool & Spa
    TDD 2 Kegerator clicking and not cooling?
    It's extremely rare that the compressor will be any good. Usually replacing the start relay does nothing on these small units. If you know how to use a multi-meter and are any good at wiring the cheapest way to go is to get what is called a 3-in-1 start kit at a HVAC wholesaler. You need to know the model of the compressor and/or the horsepower to get the right one. I would recommend getting a service tech to look it over though. Most likely the compressor is locked up.
    Nov 16, 2012 | True Direct Draw Systems: Kegerator TDD-2
    I would like to know how many square feet a Model # BRCQ0421BD Serial # 990905429 Coleman Central Air Conditioning Unit will cover. The unit supply is 208-230V 1 PH 60 Hz 10.8 RLA 97 LRA.
    The Old Rule of Thumb is 400 square feet per ton, but you really need to do a heat load calculation to be safe. A lot of windows on the west or south side of the house will really increase your load and you may need a lot larger unit. Insulation also changes your load so you may be able to cool a larger area. You may be able to get the Heat Load Calculation Form either online or from Johnstone supply. They are on the internet.
    Aug 07, 2012 | Coleman Heating & Cooling
    We have a fan 60 minute push button timer we purchased and installed with a 3-wire system. WE need to purchase another one but they all have 4 wires now. Where can we purchase a 3-wire one.
    It sounds like you have mechanical push-button type timer.
    I need more information to avoid guessing which timer is best for your situation.
    I'm not sure what a 3-wire system is?
    Add a comment
    1) How many switches control same fan
    2) What color wires inside box.
    Is this
    3) low-horsepower bathroom fan?
    4) other fan, for example: higher horsepower attic fan, 3/4 horsepower industrial kitchen fan, or 1-horsepower whole house fan?
    5) Is this your home or is fan for continual commercial use?
    6) Is this a countdown timer that turns fan OFF automatically after 60 minutes?
    7) Or what kind of timer are you looking for.
    Open following link for list of home-use countdown timers and horsepower ratings of countdown timers.
    http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
    Spring-wound timers do not require extra Neutral wire, and can control 1 HP whole-house fan.
    The push-button timers each require Neutral wire to run electronics inside timer, and they range from 1/6 HP to 3/4 HP which will work for any bathroom fan.
    If you cannot give required information for more free help, then request fixya interactive answer and pay fixya expert to ask same questions while expert supplies you with immediate information.
    Apr 06, 2011 | Woods 60 Minute Decorator Wall Timer...
    Wine cooler not cooling below 65 lights works but not fan any ideas
    Brand and model number will help someone answer your question easier. But to guess the problem I would think the fan is the answer. Both interior and exterior fans must run while any cooler or refrigerator or it will cause the compressor to over heat and stop cooling. Running with a bad fan can also damage the compressor internal overload. f you unplug the fan wires and test for voltage you should get your local voltage unless the fans are DC. Thanks, Lit me know the model and make and I will help you further, Sea Breeze
    Feb 11, 2010 | Refrigerators
    Seaga Manufacturing SM-10 Commercial Refrigerator Logo
    157 people viewed this question
    Top Seaga Manufacturing Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    ray gallant
    Are you a Seaga Manufacturing Refrigerator Expert? Answer questions, earn points and help others
