Question about Gateway Nv57h44u Laptop Pc. Core I5 -2430m, 4gb, 500gb, Hdmi & Intel Widi Blue
Computer beeps when scrolling on mouse pad
When using my scroll bar on the side of the mouse panel on lap top, my computer beeps while scrolling, I would like to turn that function off.
5 Suggested Answers
matchbox2022
  • 46 Answers
SOURCE: Autoscroll
Try simply using a system restore to before the problem started acting up. Also, you can try going into the mouse properties (Start Menu, Control Panel for Xp) and look for scrollsettings there, which may allow you to turn off certain mouse features (aka. if gestures are enabled it might be conflicting with scrolling).
Hope this helps.
Posted on Dec 16, 2008
  • 11 Answers
SOURCE: scroll bar on the right side of my touch pad scrolls too fast how do i slow it down
It depends, do you know if there is an icon down in the taskbar near the clock that has options for your mouse, if there is then you would double click that and there should be options in there.
Posted on May 26, 2009
  • 5 Answers
SOURCE: When i use my touch pad on my brand new Gateway
There are some things you should do on your own:
1) Gather information. You need to know your Gateway model and S/N, Windows version (XP, Vista, 7, 32bit or 64bit)
To check windows version: Right-click My Computer or Computer from Start menu, choose properties. You should be able to see the Windows version here
2) Go to Gateway website:
http://support.gateway.com/support/default.aspx?cmpid=topnav_support
Click on the "Notebooks" tab and input your S/N.
3) Scroll down to "Touchpad Drivers" section and download the latest driver for your model. Be sure to save the file where you can find it.
4) Install the new driver. It may be helpful to uninstall the old driver first: Start>>Right-click (My)Computer >> Manage >> In left pane, Device Manager >> In Right Pane, click plus sign next to, Mice and Other pointing devices >> Right -click the touchpad and click Uninstall, be sure to check the box, "Remove Software".
See if this gets better. If not, the touchpad/Palm rest needs to be replaced, but getting Gateway to do it (sounds like they tried) may be tough.
At least if you install the new driver, you may be able to disable it permanently, and then use a wireless mouse (which usually is much nicer anyway).
Happy computing!
Posted on Jul 24, 2010
davidgreene
  • 663 Answers
SOURCE: my mouse pad wont scroll or move through apps like it used to
There are two things that you can do.
1. System Restore
2. Update the driver
To do the system restore, do the following:
Click on Start > Programs > Accessories > System tools > System Restore
Select a restoration point.Make sure that it's before the time when the problem occurred. Launch it. If it doesn't work, try a different restoration point.
To update the driver, you can use RadarSync. It will scan and install the updates to your computer. All drivers will be covered so you're sure that all possible problems (driver related) will be fixed.
I hope this helps!
David
Posted on Mar 19, 2013
Mousepad scroll unlock button
restart your computer
or go into control panel the find mouse and settings,your pad might need replacement
May 08, 2015 | Gateway NE56R41u Dual Core B960 4GB 500GB...
Is there a way to disable jus the side scroll bar on my gateway laptop touchpad without disabling the mouse itself? on my touchpad if my hand jus gets in front of the touchpad it scrolls and makes my...
yes. its in the control panel under mouse properties. Look for the advanced properties, theres alot of settings you can change there for the touch pad. There might be a link to the program in the start menu too.
May 15, 2011 | Gateway Keyboard/Mouse
I can't use for scrolling up and down from the right side of mouse pad, how to setting it? thx
Sometimes there is a setting, under mouse, in the control panel. But also there is a time based issue, you need to stop while pressing in the scroll area, and the mouse shifts from mousing to scrolling. Duration of time, and first touch to the pad in the scroll area are keys.
Oct 27, 2010 | Compaq (153515-001) Touch Pad
Have a Satellite P 305D-S9800; scoll bar will not pull down by mouse or touch pad; as soon as I let go it jumps back to the top please help
The "Touchpad is very sensitive; if you look while scrolling, the "scroll-bar" will turn (Blue), click on the ("scroll-bar"), until it turn "Gray." Note: "You ca use the Pointer Device / Touchpad without using the Scroll-bar, basically anywhere on the screen; ("bottom scroll-pad" = left to right"), and ("right -side edge scroll-pad = up & down").
Jan 24, 2010 | Toshiba Computers & Internet
Can not scroll on lap top pad
Is your pad scroll capable? Not all are. If it is, have you enabled it in the mouse settings via control panel? The default mode for some pads is non-scrolling and you have to manually enable this function. Also, some pads have small areas where the scroll works. Usually along the right and bottom edges of the pad. Anywhere else = no scroll.
Sep 15, 2009 | Computers & Internet
Mouse Pad not scrolling
you may be able to fix this by going to control panel and then mouse settings
you also may want to check your driver by right clicking my computer properties hardware then device scroll down till you find your mouse thrn right click and update driver
Jan 16, 2009 | Toshiba Satellite A135-S4527 Notebook
Autoscroll
Hope this helps.
Dec 16, 2008 | Gateway MX6920 Notebook
Mousepad on the laptop--
Go into your control panel (if your on windows). Load the mouse settings control. You can customize the features of your touchpad.
Dec 13, 2008 | Dell Inspiron 1420 Laptop
Mouse on lap top dosent work
Can you tell me the model of laptop you have? Have you checked the settings in the control panel?
Nov 30, 2007 | KEIO PS2 Optical Scroll Mouse
Gateway Nv57h44u Laptop Pc. Core I5 -2430m, 4gb, 500gb, Hdmi & Intel Widi Blue Logo
313 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
