Question about Furuno 000167175 LAN CABLE ASSEMBLy 2M RJ45RJ45 4P (000167175
I have a DFF1 network sounder,i want to connect to my GD1920C plotter.do i put it in data port 4.if so what cable is it[ or do i make it up myself]7pin with lan conectionor into the network port 6pin
Connecting A DFF! network sounder to C|GD1920 plotter
2 Suggested Answers
TechnoMarine
  • 132 Answers
SOURCE: How do I connect my Furuno RDP139 to my laptop via
you must use a serial to USB adaptor go in to data 1 or 4 network connector is ethernet protocol!
Posted on Jan 16, 2010
HP DeisgnJet T770 - 24 InchThe network link light is solid amber. There is not activity indicator illuminated. The device will print all internal demo prints but cannot access from the network. I have...
not sure this will help but heregoes,
If you can see that the plotter believes there is network communication when no network cables are connected then the fault must lie within the plotter. ( I've had Carriage PCA's give me a similar fault with network issues) and the only way forward is to replace 1 part at a time using logical faullt deduction to identify the next part.
If you see an orange com light only after you connect the lead the network card is telling you there is a com fault in the line to the router/switch ( make sure your NOT using a crossover cable if connected to a router/switch as this is often the case for this fault) replace the cable then switch/router
if the plotter has been defaulted then it should be set to DHCP and should automatically find a working IP address and subnet,
another way of checking the plotters external comms device is to connect via USB, which may help decide if the replacement Main PCA was functional to begin with,
My experience would suggest in order the fault will lie:
external Net cables
external router/switch comms
Formatter
Main Pca
Power supply ( comes with Main PCA)
Display panel
and finally the Carriage Pca,
thankfully the ISS Pwb has never given me any issues.
Good luck
Mar 09, 2014 | HP Office Equipment & Supplies
Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set BEARING to “MAG” (magnetic). This will cause the unit to display course / bearing information in relation to the Magnetic North and match magnetic compass readings. It is not the same as True North! One has to be careful with this setting. There are a number of areas where the earth's magnetic field is locally disturbed, sometimes very significantly. Your GPS may not account for it. - again, under “UNITS” I set “METRIC”.
Sep 02, 2008 | Furuno NavNet vx2 1920C GPS Receiver
GP Furuno 7000 sounder not powering up
Be sure to check your input DC voltage all the way to the unit itself. The intermittent condition you described sounds like a bad connection outside of the unit itself. Once you confirm that you have good 12 or 24vdc input to the plotter and it still won't power on, there is an internal 4amp fuse you can check. Proceed with caution if you decide to open the unit yourself.
Nov 12, 2013 | Boating
How can i install hp designjet 5500 PS on my com puter using network cable? My plotter (hp designjet 5500) do not have USB port instead it has netwok port from which one can install via the local network...
You are doing some mistake.
All peripherals will attach directly to the main server or main system.
Then from the main system you attach the network switch and share the peripherals with other
system.
you connect the printer, plotter, scanner etc to your computer directly through the aproprite cable /
port.
Apr 15, 2011 | HP DesignJet 5500PS InkJet Printer
Good day, I just bought a transducer (R209) for my 1920 C furuno display but seem to have a probleem with the setup on the display. I have no radar connected to the system and to do the installation...
If you just have the transducer and no network sounder youre pretty much dead in the water. along with your transducer, you will need either a BBFF1 or DFF1 sounder. Since they operate on a network they will have to be configured depending on your setup.
Oct 07, 2010 | Furuno NavNet vx2 1920C GPS Receiver
When I turn on the unit it will not read the depth only a blue screen and it will not let me switch out of auto mode or run the sounder test?
I know this is an old question but just ran across it. The 1833C/NT is a radar and chart plotter. It requires the external and optional black box sounder to have depth recorder functionality.
Oct 03, 2009 | Furuno 1833C/NT GPS Receiver
Sounder transducer?
I believe like my own Garmin I have a 178 which is the mono version, same transducer though, you alter the frequencey setting in your main reciever set up program.
Sep 11, 2008 | Garmin 200/50khz, 10/40deg, Plastic,...
IP Assignment....
No, a tranceiver cannot be assigned an IP address. It just converts the signal between two types of lines (fiber, copper, etc.). This is mainly used for connecting together networking equipments such as switches or routers.
Depending on the type of interface you plotter have, you may need a device called a Print Server. This device has an IP address and allows a conventional printer signal to travel through an IP network. If your plotter is designed to be connected using a LPT (Parallel) cable, like old printers, you may look for the D-Link DP-301P+ or DP-300U.
Feb 12, 2008 | D-Link DE 853 (DE-853) Transceiver
Furuno 000167175 LAN CABLE ASSEMBLy 2M RJ45RJ45 4P (000167175 Logo
32 people viewed this question
Top Furuno Computers & Internet Experts
David Payne
David Payne
Are you a Furuno Computer and Internet Expert? Answer questions, earn points and help others
