Telus router password login for 192.168.1.254
Forgot wi fi password
kakee
  • 1268 Answers
SOURCE: asking me for wi-fi password
The wifi password is the same as wireless network key (either WPA or WEP key). That's the same password that you used when you tried to connect to the wireless network using your laptop.
Posted on Apr 27, 2009
anandg27
  • 1272 Answers
SOURCE: connecting my ipod touch to my wireless router through wi fi
Check for the password on the router configuration page to make sure tat you are using the correct one:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router (User Name = admin Password = password unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the Key that has a black dot before it.
This is the code required for connecting the wireless computer to the routers' wireless network.
Enter the same password on IPOD to connect to the wireless network.
Rate it,if it helps.
Posted on Jun 26, 2009
  • 8404 Answers
SOURCE: lost password for router and can't accsess wi-fi
do a hard reset - press the little button inside the device, while unplugged and disconnected. hold with a paperclip for at least 30 seconds.
This will reestablish factory default settings
Posted on Dec 26, 2009
govinda123
  • 2260 Answers
SOURCE: how do i unlock my wi fi
Is there any computer online using the router.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
Posted on Jan 26, 2010
ricbellen
  • 53 Answers
SOURCE: can you help me setting up a password for my wi-fi
How do I secure my network?
Log into your router using the "How do I log into my router?" instructions earlier in this article.
  1. From the left-hand menu, select Wireless Settings from the Set Up section.
  2. In the Name (SSID) field, enter the network name you want to use.
  3. Under Security Options, select a security encryption level. NETGEAR recommends WPA-PSK + WPA2-PSK for the best protection.
  4. In the Passphrase field, enter your chosen network password.
  5. Click the Apply button to save your changes.
For more details, see Securing Your Network: WPA+WPA2 (Recommended).
How do I change or reset my wireless network password?
Log into your router using the "How do I log into my router?" instructions earlier in this article. From the left-hand menu, select Wireless Settings from the Set Up section. Enter a new wireless network password into the Passphrase field under your security selection and click the Apply button to save your changes.
Posted on Jun 05, 2011
Testimonial: "good job!"
I cannot connect. I keep getting a message "authentication Failed"
Do you connect your PC to router in an administrator role using web browser? Or do you connect some device to Wi-Fi network?
  1. Administrator role: You need to have correct login name and password for admin access. Search in manual or ask Google for default login name and password of your router type. If non-default password is set in the router then you must reset router setting and erase its settings to default (factory) status. You will lose all router configuration but default password is back.
  2. Wi-Fi client role: There are more possibilities why authentication fails in wireless communication. Mentioned error message describes what kind of problem occurred.
    (a) A password you put to client device does not match the wireless network password which is set in router. Your computer, tablet or smartphone WI-Fi interface must have exactly same password as WI-Fi network which is transmitted from router. Check and compare passwords on both sides, in client device and in router.
    (b) Client Wi-Fi interface security (encryption) mode differs from Wi-Fi network encryption used in router. But the same mode must be set on both sides (client and router) for successful connection.
Encryption modes are
  • WPA2 Enterpise
  • WPA2 PSK ("home")
  • WPA Enterprise
  • WPA PSK
  • WEP
  • No encryption (open)
Higher position - better security. Enterprise Wi-Fi modes require security devices like authentication servers, certification authorities etc. They are not used in home networks usually.
Jan 21, 2016 | Computers & Internet
He code to the wi fi
The default password and login to the router are 'admin' and 'admin'. For instructions to log in to the router, see Linksys E3000 Login Instructions
Through these instructions, you can change the Wifi password.
Feb 11, 2015 | Cisco linksys E3000 Wireless-n Router
Password recovery for ZyXEL3480wfy
ZyXEL Router Passwords
Finding your ZyXEL router's user name and password is as easy as 1,2,3.
  1. Find Your ZyXEL Router Model Number
    Look in the left column of the ZyXEL router password list below to find your ZyXEL router model number.
  2. Find Your ZyXEL Router Username
    Look one column to the right of your router model number to see your ZyXEL router's user name.
  3. Find Your ZyXEL Router Password
    You know the drill. Look another column to the right to find your ZyXEL router's password.
Great! You've found the password and username for your ZyXEL router! What next?
Login to Your ZyXEL Router Using the Router Password
Try logging into your ZyXEL router using the username and password.
Don't Know How to Login to Your ZyXEL Router?
You can login to a ZyXEL router in three easy steps:
  1. Find Your ZyXEL Router IP Address
  2. Enter Your ZyXEL Router IP Address Into an Internet Browser's Address Bar
  3. Submit Your ZyXEL Router Username and Password When Prompted By Your Router
=============== OR: ===============
Forgot Router Password?
If you are having trouble logging in to your router, there is a good chance that your router's user name and password are still set to the default settings.
What should you do?
Login to Your Router Using the Default Router Password
Try logging into your router using the default username and password for your router.
Don't Know How to Login to Your Router?
You can login to a router in three easy steps:
  1. Find Your Router IP Address
  2. Enter Your Router IP Address Into an Internet Browser's Address Bar
  3. Submit Your Router Username and Password When Prompted By Your Router
For more information on how to login to your router please see our Free Guides.
Still can't login to your router even when using the default username and password for your router?
Reset Router Password To Default Settings
(Use this as a last Resort!)
Find Your Default Router Password
Simply select your router manufacturer from the list below to display the default router passwords and usernames.
Nov 02, 2014 | Zyxel Computers & Internet
Forgot wi-fi password
if you have access to the wi-fi router, you can reset it to default password by pressing reset button on the router, this will revert it back to the factory settings, including router name and password, the password will be on the router itself.
Nov 07, 2013 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
Forgot password for router
The router should have a small hole in the back.Use a pen or something to push the button inside.This should reset the router to its factory settings.Keep in mind that this will wipe out anything you customized on the settings(wi-fi name and password,parental controls,etc.).You should be able to use the factory login(probably listed on the router llabel somewhere).
May 31, 2012 | Computers & Internet
Hoe can i connect my ipone to wiifi on my belkin router
Wi-Fi settings determine whether iPhone uses local Wi-Fi networks to connect to the Internet.
Turn Wi-Fi on: Choose Wi-Fi and turn Wi-Fi on.
Join a Wi-Fi network: Choose Wi-Fi, wait a moment as iPhone detects networks in range, then select a network. If necessary, enter a password and tap Join (networks that require a password appear with a lock icon).
Once you join a Wi-Fi network manually, iPhone automatically joins it whenever the network is in range. If more than one previously used network is in range, iPhone joins the one last used. When iPhone is joined to a Wi-Fi network, the Wi-Fi icon in the status bar at the top of the screen shows signal strength. The more bars you see, the stronger the signal. Set iPhone to ask if you want to join a new network: Choose Wi-Fi and turn "Ask to Join Networks" on or off. Join a closed Wi-Fi network: To join a Wi-Fi network that isn't shown in the list of scanned networks, choose Wi-Fi > Other, then enter the network name. If the network requires a password, tap Security, tap the type of security the network uses, and enter the password. You must already know the network name, password, and security type to connect to a closed network. Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. You can type it manually by login onto the Belkin's network page using the browser and by copying the static and dynamic IP address.
Feb 05, 2011 | Belkin (F5D7230-4) Router (587009)
Have a linksys router and adapter not sure how to install, my daughter wants to use her laptop but cant get the internet
Connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1 or
http://1921.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
Then configure your router as WEP.
Then go to wireless and check that wi fi is enabled.
Then go to wi fi security and add WEP key it is your password to connect your wi fi.
Also enable dhcp if you want get ip auto to computers.
configure your wan settings as your internet service provider like dns ip addrses.
Then save settings and restart the router.
Now go on your laptop first turn the wi fi switch on your laptop .
Then check that your wi fi network adapter driver is proeprly installed.Also check in my network places that your wi fi is enabled.
Then double click on wi fi icon and click on "View wi fi networks."
then connect then enter password which you set in router wep key.
Let me know if you need more assistanse.
Thanks.
Aug 29, 2009 | Linksys Wireless-G WRT54GS Router...
Changing Wireless network password without resetting the router
For that access your router with
http://192.168.1.1
or http://192.168.0.1
if you cant able access it then reset it
Press RESET button for 10 seconds it is in back sid of router.
then access above link.
type user name "admin' and password as "admin' or blank or "password'
then go to wi fi security first configure your router as WEP then go to wi fi security in advancwed then set WEP key it is your password to connect wi fi .
Aug 13, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Forgot my password and trying to connect my ipod is asking for password
access your router with flowing link
http://192.168.2.1
then type user name "admin" and password as "admin" or blank or "password"
then go to wi fi security then find wep or WAP key it is your password to connect your wi fi network.
Thanks for using fixya.
Please rate solution if it helps.
Jul 17, 2009 | Belkin (F5D9230-4) Wireless Router...
I forgot my password and don't have the manual on how to set up the router, or where to find my password.
accesss your router with following link
http://192.168..1.1 or http://192.168.0.1
Then login username as "admin" and password is "admin" or blank or "password"
then go to wi fi securtiy .
Then check encryptioon key it is your password.
Jun 25, 2009 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
281 people viewed this question
David Payne
David Payne
