Question about Microsoft Xbox 360 Console
A messed up Screen
Well it works most of the time but when I play a game it starts making these weird patterns of red blue and green. I'm guessing its something with my cord since it happens on my other games. I turn my xobox off then on and its fix only for like 3 minutes. Any help?
  • Anonymous Mar 30, 2009
    the thing that im gettin pissed about is..ill be playin and all of a sudden the screen just goes basically black/brown and looks like everything is chrome..then it will start flickering and ill shut it off then turn it on..work about 5 mintues then just now i turned it off and now the screen wont even turn on..like its just says no signal..im gettin furious
    Scholar:
  • 65 Answers
Yes, your cord sounds like it has become damaged, replacing it is not too costly in most cases, unless you have to have it mailed to you. If the cable was kinked or pinched at anytime, you can damage the wiring on the inside of the cable, making the picture either not come at all, or badly distorted because the signals are not coming through properly.
To give you an idea of cost to replace,
http://www.newegg.com/Product/Product.aspx?Item=N82E16874103024&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-Xbox+360+-+Accessories-_-Microsoft-_-74103024
Posted on Jan 20, 2009
How do I change my W2613 TV resolution to 1080i? I just bought this TV a few weeks ago and I want to be able to play my XBox360 in HD and when I connect all 6 wires (Red, White, Yellow & Green, Red,...
use just the red green and blue wires for the picture and NOT the yellow wire. That is why it is messed up.
XBOX games only play in 720, but it will still look great.
Aug 09, 2010 | Televison & Video
When i turn my xbox 360 on it will play the sounds but no video
If your using the hi-def cable(red blue green) check that its switched to either standard of hi-def. Also if your using the hi-def cable it wont work if u have the white head in the same time as red blue green! Hope it works for you!
Mar 14, 2010 | Microsoft Xbox 360 Console
My hdtv turns green when i try to play my xbox 360 why?
Are you using component video?
If the Green (Y) provides Luminance, Red (Pr) and Blue (Pb) are the colour bands. If only the Blus is pluged in then you will have a blue-green screen. If you have the Blue and Red switched then you will have weird colour aswell.
If you are using HDMI then unplug and re-plug the connectors.
Jan 02, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
I inserted a new movie and I have no sound nor video with a green and blue lights on.
I had this weird problem yesterday knowing I have not done any video setting changes, nor recall a pending software installation. When I start the PS3, green light comes up and then nothing happens. Insert the Game into the slot, blue light blinks and again nothing happens. No video, no sound, and no, it’s not output setting problem as many others have guessed in forums. Try to assign your wireless controller and you’ll know. It doesn’t. If it was on, output and controller assigning I assume should be two separate things.
Solution:
  1. With the PS3 in Standby mode (Red light on), press and hold the Start button until you hear a single beep, followed by double beeps.
  2. Connect the controller using USB cable and press the PS button on the controller.
  3. Now, the system restore screen (or whatever they call it) will come up like this
  4. You have several options here for restoring the system, some will unfortunately wipe up all your data, others will make you lose the file naming. For me, I tried the option top-bottom and eventually had to do the Restore PS3 System. Luckily, all I had were demos, trailers, and game saves. only game I was really playing now was Prince of Persia. I felt terrible still though, but much better than if I was playing Ninja Gaiden or MGS right? Or let’s say a game Fallout!
Sharing it for others with same misfortune. Guess we’ll need the PS3 included in the backup plan then.
Nov 14, 2009 | Sony Playstation 3 (PS3) Console
I think the video cable for my xbox is messed up. Why does it keep showing up these little circle things? Whenever I turn on my xbox it doesn't come up anything but a black screen with little circles...
NOT HD: Make sure red goes to red, white on white, and yellow on yellow, also make sure the switch that is on the xbox wire plug says TV not HD.
HD TV: Make sure red on red, white on white, yellow on yellow, blue on blue, green on green, etc. Also make sure the switch that is on the xbox wire plug says HD not TC
Oct 18, 2009 | Microsoft Xbox 360 Console
3 screen colors have separated and screen is bowed in the middle.
I take it this is a projection TV. so they use three lensed CRTs red green and blue. you should have a setup screen that projects a grid pattern. red green and blue. there is SOMEWHERE a adjustment that overlaps the three projected grid patterns. Making a WHITE single grid pattern. red green and blue make white light. Pin cushioning is the bowing. you may find a POT to adjust on the back of the set. I have no idea what set you have.
Lastly.. Pin cushioning can also be caused by faulty flyback transformers.
Hope I could help.. new here LOL
Happy Fixing =)
Jul 12, 2009 | Televison & Video
My xbox colors are messed up
How is the 360 connected to the TV? This sounds like your component cables are attached wrong. make sure red, green, and blue are connected to the corresponding jacks.
May 03, 2009 | Microsoft Xbox 360 Elite Console
I want cheat codes of sims 2 pets
  • Cheat Gnome While at home or on a lot, press L1(2), R1, X(2), Up. Then, enter one of the following codes to activate the corresponding cheat function:
      10,000 additional Simoleons Enable the "Cheat Gnome" code, then press Up, Left, Down, Right, R1 while playing the game. An option to advance time by six hours will now appear on the Cheat Gnome. Select the Cheat Gnome, then cancel the selection. Press Up, Left, Down, Right, R1 again. A "Give Sim Simoleons" option should now appear.
      Pet Points Enable the "Cheat Gnome" code, then press Triangle, Circle, X, Square, L1, R1 while playing the game. A "Pet Points" option will now appear on the Cheat Gnome.
      Pet Emporium fully upgraded Enable the "Cheat Gnome" code, then press Right, Down, Right, Up, Right, Down, Right, Up while playing the game.
      Advance time by 6 hours Enable the "Cheat Gnome" code, then press Up, Left, Down, Right, R1 while playing the game. An option to advance time by six hours will now appear on the Cheat Gnome.
  • Alternate opening sequence At the EA logo, press X, Circle, Triangle.
  • View developers At the credits screen, press Right, Left, Up, Right, Down, Right, Down, Right.
  • Bonuses At the codes screen under the "Game Options" menu, enter one of the following codes to activate the corresponding cheat function:
    Result Code
    Collars
    Black Dot Cats ZZZ11ZZZ9Q11Q91ZB1A or EEGJ2YRZQQ1IQ9QHA64 Black Dot Dogs ZZZ11ZZQHZ11Q91ZB1A or EEGJ2YRQZZ1IQ9QHA64 Black Smiley Cats ZZZ11ZZQ9Z1AQ91ZB1A or EEGJ2YRQQZ1RQ9QHA64 Black Smiley Dogs ZZZ11ZZZ9QAAQ91ZB1A or EEGJ2YRZQQARQ9QHA64 Blue Bones Cats ZZZ11ZZQHZAAQ91ZB1A or EEGJ2YRQZZARQ9QHA64 Blue Bones Dogs ZZZ11ZZZHZ11Z91ZB1A or EEGJ2YRZZZ1IZ9QHA64 Blue Camouflage Cats ZZZ11ZZZHQ11Q91ZB1A or EEGJ2YRZZQ1IQ9QHA64 Blue Camouflage Dogs ZZZ11ZZZHZ1AQ91ZB1A or EEGJ2YRZZZ1RQ9QHA64 Blue Star Cats ZZZ11ZZQ9Z11Z91ZB1A or EEGJ2YRQQZ1IZ9QHA64 Blue Star Dogs ZZZ11ZZQHQ11Q91ZB1A or EEGJ2YRQZQ1IQ9QHA64 Green Flower Cats ZZZ11ZZZ9ZA1Q91ZB1A or EEGJ2YRZQZAIQ9QHA64 Green Flower Dogs ZZZ11ZZQHZ1AQ91ZB1A or EEGJ2YRQZZ1RQ9QHA64 Navy Hearts Cats ZZZ11ZZZ9Z11Q91ZB1A or EEGJ2YRZQZ1IQ9QHA64 Navy Hearts Dogs ZZZ11ZZQ9Z11Q91ZB1A or EEGJ2YRQQZ1IQ9QHA64 Orange Diagonal Cats ZZZ11ZZQ9ZA1Q91ZB1A or EEGJ2YRQQZAIQ9QHA64 Orange Diagonal Dogs ZZZ11ZZZ9Z11Z91ZB1A or EEGJ2YRZQZ1IZ9QHA64 Pink Vertical Strip Cats ZZZ11ZZQ9QAAQ91ZB1A or EEGJ2YRQQQARQ9QHA6 Pink Vertical Strip Dogs ZZZ11ZZZHZA1Q91ZB1A or EEGJ2YRZZZAIQ9QHA64 White Paws Cats ZZZ11ZZQ9Q1AQ91ZB1A or EEGJ2YRQQQ1RQ9QHA64 White Paws Dogs ZZZ11ZZZ9Q11Z91ZB1A or EEGJ2YRZQQ1IZ9QHA64 White Zebra Stripe Cats ZZZ11ZZZHQ11Z91ZB1A or EEGJ2YRZZQ1IZ9QHA6 White Zebra Stripe Dogs ZZZ11ZZZHZ11Q91ZB1A or EEGJ2YRZZZ1IQ9QHA64
    Fur colors
    Blue Cats ZZZ11ZZQHZA1Q91ZB1A or EEGJ2YRQZZAIQ9QHA64 Blue Dogs ZZZ11ZZQ9Q11Z91ZB1A or EEGJ2YRQQQ1IZ9QHA64 Deep Red Cats ZZZ11ZZQ9QA1Q91ZB1A or EEGJ2YRQQQAIQ9QHA64 ° Deep Red Dogs ZZZ11ZZQHQ1AQ91ZB1A or EEGJ2YRQZQ1RQ9QHA64 Goofy Cats ZZZ11ZZQHQ11Z91ZB1A or EEGJ2YRQZQ1IZ9QHA64 Goofy Dogs ZZZ11ZZZHZAAQ91ZB1A or EEGJ2YRZZZARQ9QHA64 Green Cats ZZZ11ZZZ9QA1Z91ZB1A or EEGJ2YRZQQAIZ9QHA64 Green Dogs ZZZ11ZZQHQA1Q91ZB1A or EEGJ2YRQZQAIQ9QHA64 Light Green Cats ZZZ11ZZZHQ1AQ91ZB1A or EEGJ2YRZZQ1RQ9QHA64 Light Green Dogs ZZZ11ZZZ9Q1AQ91ZB1A or EEGJ2YRZQQ1RQ9QHA64 Neon Green Cats ZZZ11ZZZHQA1Q91ZB1A or EEGJ2YRZZQAIQ9QHA64 Neon Green Dogs ZZZ11ZZZ9QA1Q91ZB1A or EEGJ2YRZQQAIQ9QHA64 Neon Yellow Cats ZZZ11ZZZHQAAQ91ZB1A or EEGJ2YRZZQARQ9QHA64 Neon Yellow Dogs ZZZ11ZZQ9QA1Z91ZB1A or EEGJ2YRQQQAIZ9QHA64 Pink Cats ZZZ11ZZQHZ11Z91ZB1A or EEGJ2YRQZZ1IZ9QHA64 Pink Dogs ZZZ11ZZZ9Z1AQ91ZB1A or EEGJ2YRZQZ1RQ9QHA64 Purple Cats ZZZ11ZZQ9ZAAQ91ZB1A or EEGJ2YRQQZARQ9QHA64 Purple Dogs ZZZ11ZZQ9ZA1Z91ZB1A or EEGJ2YRQQZAIZ9QHA64
    Fur patterns
    Bandit Mask Cats ZZZ11ZZQHZA1Z91ZB1A, TB6IPB1IAFDMRIQT6DG, or EEGJ2YRQZZAIZ9QHA64 Bandit Mask Dogs ZZZ11ZZQHQAAQ91ZB1A or EEGJ2YRQZQARQ9QHA64 Panda Cats ZZZ11ZZQHQA1Z91ZB1A or EEGJ2YRQZQAIZ9QHA6 Star Cats ZZZ11ZZZ9ZAAQ91ZB1A or EEGJ2YRZQZARQ9QHA6 Star Dogs ZZZ11ZZZ9ZA1Z91ZB1A or EEGJ2YRZQZAIZ9QHA64 Zebra Stripes Dogs ZZZ11ZZZHQA1Z91ZB1A or EEGJ2YRZZQAIZ9QHA64
  • Dec 21, 2008 | Sony PlayStation 2 (PS2) Console
    Playing blue ray
    my solution would be to restore the playstion 3 to default settings unless you have files on your ps3 that you do not want to delete forever.
    Oct 01, 2008 | Sony Playstation 3 (PS3) Console
    The picture is only producing the basic colours red green and blue
    You can start with the make, model and age off the back of
    the TV..........................T.
    Dec 24, 2007 | Televison & Video
    Microsoft Xbox 360 Console Logo
    172 people viewed this question
    Top Microsoft Video Game Consoles & Games Experts
    marley mcelhinney
    Tre Elkins
    Mike Neath
    Mike Neath
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
