SOURCE: GE spacemaker Profile XL1800 vent fan will not shut off
It may be a bad door switch, a loose door switch mount, or a problem on the control panel, such as a sticky relay.
I would suspect a sticky relay first, but the door switches should be checked.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
If you need your control panel assembly (smart board) repaired, we do that for $39.95 nationwide.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
SOURCE: My ge profile spacemaker xl1800 turntable stopped .
It's probably a bad turntable motor or coupler.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Outside venting GE Profile Spacemaker XL1800
Your vent flap could be taped or it could be faulty installation not allowing the vent to open. If you take the front vent cover off, you should be able to reach in above the fan unit and gently push the vent flap up, it should move freely with no binding. If it doesn't it is taped or blocked. If it is taped, gently putting upward pressure on the flap might release the tape. If that doesn't work the vent installation is blocking the flap. You might have to remove the unit from the wall (two people to do this) or disassemble the vent duct above the microwave and rework the interface for clearance.
hope this helps,
SOURCE: GE Spacemaker XL1800 microwave suddenly
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ==-
