Question about KitchenAid KWCU265HSS Kitchen Hood
My KitchenAid KWCU265HSS Hood Lite and Fan switches suddenly stopped working, Breaker is intact. Help...How do I fix?
Light was working. Fan was not being used. Suddenly light went off and now nothing in the switch panel will work.
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: hood fan not working, but lights do.
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
walesarumi
  • 6993 Answers
SOURCE: I have a 7 year-old
There is actually a fuse on the power panel of this unit. The KitchenAid warming drawer is having a power problem since its not having any power. Now, you need to check the area/part of the unit which has to do with power and that would be the power board.
Get a screw driver and find away to disassemble the unit. Check the power board for any blown fuse and make necessary replacement.
You should find what's wrong the moment you disassemble the unit and check then power board.
Good luck.
Posted on Dec 16, 2010
Casablanca Trident ceiling fan issue - light suddenly stopped working - replaced bulb to no avail - fan works fine otherwise...ideas?
Is it powered from the same breaker as the fan, check the breaker, if so check the connections. Most likely if its a pull chain switch the switch is bad,,,,, it's common..
May 29, 2014 | Dryers
Whirlpool accubake
follow this steps with VOM and fix it. God bless you
1. No power to the range hood
Make sure there's power getting to the range hood. Check for a tripped circuit breaker or a blown fuse. Check the wall socket (unless the hood is hard wired) for power with a voltmeter or by plugging something else in.
2. Fan switch
If your range hood only has a fan and no light or any other features, it won't start with a broken fan switch. Replace the switch if found defective.
3. Fan motor
If your range hood only has a fan and no light or any other features, it won't start with a broken fan motor. Replace the motor if found defective.
Read more: http://www.appliancepartspros.com/repair-help/rangehood-repair-help.html#ixzz2aSy5FKwN
Jul 29, 2013 | Kitchen Ranges
The fan in my has not stopped working in a few weeks now.what can I do to make it stop blowing air
test this steps and fix it. God bless you
2. Fan switch
3. Fan motor
Dww061350b
if both fan and light have quit working then you have an electrical supply problem. start with checking for thrown breakers in the breaker panel. if none are tripped then you have a broken wire or a wire no longer making a good connection. try twisting the wire nuts tighter were it wires in above it
Jun 02, 2012 | Kuppersbusch Kitchen Ranges
For the last few months my vent hood's motor has been making a lot of noise whenever it was in operation (making a squeeking sound like it needed to be oiled). Then it simply stopped working. Do I need a...
It is possible that if you can get the motor out of there and get some WD-40 worked into the bearings you can get it running again...
turn it so the shaft is pointing up and then spray the WD-40 right on the shaft and let it run down and into the bearing...
once you get the shaft spinning more freely then place a few drops of light motor oil or sewing machine oil on the shaft and let it run into the bearing before turning the motor from the shaft up position and reinstalling...
heatman101
Sep 29, 2010 | KitchenAid KWCU265HSS Kitchen Hood
How do I install this? There's no install hardware.
To install you need to read the manual on link below. On page 2 shows the parts needed.
http://kitchenaid.com/assets/pdfs/product/ZINSTALL/9763386.pdf
If you need replacement parts go to this link below.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5152461
Good Luck and please rate 4 thumbs up for the free answer
Jun 14, 2010 | KitchenAid KWCU265HSS Kitchen Hood
Suddenly the light and the fan quit . Is there a reset
the only "reset" is the circuit breaker.... if they both suddenly quit working, there is no power to the hood at all.... if the breaker/fuse at the box is good, then the hot wire has slipped out of the connection.... not an easy way to trace it. all you can do is work backwards, starting at the power box up inside the hood. if all those connections are tight (power supply to unit's wires) then it's in the wall, attic, or under the floor.... no fun.
Nov 26, 2009 | Broan-NuTone Allure II QS230SS Kitchen...
The blower motor hums but does not move/work. When I give the motor/fan a little push with hand it starts working. A day or two later it is back to the same situation where it hums and needs a push.
The little fan is going out.you can disconnect the power to it,and remove it,to see if you can clean it,then it might start working,do not oil it,it will catch fire,but I suggest to replace it.I hope this is helpful,if so,please let us know,thank you.
Oct 25, 2009 | KitchenAid KWCU265HSS Kitchen Hood
Fan and light not working where is fuse box?
Hi - I have a neff extractor fan and have the same problem. The light and fan have both stopped working. Does anybody know where I can find the fuse as I suspect that this may be the problem too?
Dec 07, 2007 | Whirlpool GZ7730XGS Stainless Steel...
Open Questions:
Fan not working The fan on the hood stopped working (i.e., nothing happens when I turn it on). From this wiring diagram: http://www.fixya.com/support/p106093-kitchenaid_kwcu265hss_kitchen_hood/manual-13670/page-9, you can see that the hood has two circuit boards. One for slided switches and speed control (Part Number: AP3133509 made by WHIRLPOOL), and one for motor control (Part Number: AP3105889 made by WHIRLPOOL ). My best guess was that the motor control board went bad, so I ordered a new motor control board to replace it. You will see five wires coming out of the speed control portion of the first board. The white wire goes directly to the fan motor, but the other four (blue, orange, black, and black), go to the motor-control board which also has four wires of the same colors. OK. Blue to blue, orange to orange. No problem. But what about the two black wires coming from the speed controller and going to the two black wires on the motor-control board? Does it matter how these are connected? I figured if it mattered, they would also be color coded, so I just connected black to black, black to black (random order). When I turned on the fan, it blew out my new motor-control board. I have a new motor-control board. I was going to try reversing the two black wire connections, but don't want to blow out another board. So, my question is, do you think it is important to match a specific black wire on the motor-control board to a specific black wire coming from the speed controller? It seems strange to me that it would work this way, as these wires snake around through the hood, and it virtually impossible to tell which is which when when they reach the motor-control board. I don't know how they would be been matched during original assembly. But I can't think of any other problem. By the way, I was able to by-pass the motor-control board and run the fan directly, so I don't think the problem is with the fan motor. I have also replaced the control board used for the slider switches and speed control, so the problem is not there either. Thought welcome. Thanks. jp
Oct 17, 2008 | KitchenAid KWCU265HSS Kitchen Hood
KitchenAid KWCU265HSS Kitchen Hood Logo
42 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
