Question about Dell XPS 400 PC Desktop
Dell XPS 400 monitor dont show
As you turn it on there nothing in the monitor and also makes a loud fan sound noise when its on.
  • Dell Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Test all power and data leads that attach to your hard drive IDE,SATA the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty if its a 40 pin flat ribbon type it will be the first to fail make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even something as small as a faulty electrical fan and its lead can cause you problems computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error Make sure your graphics card is securely seated with no dust built up or in the socket if you remove your graphics check the socket to make sure its dust free Restart your computer then reinstall it this should activate found new hardware wizard Check the vga lead for secure dust free connection or try another vga lead. Hope this helps.
Posted on Jan 09, 2013
3 Suggested Answers
  • 998 Answers
SOURCE: Dell XPS 400 tower does not power up monitor?
The “self test” on the monitor displays when not plugged into a computer. This means that it’s working. The LED error code 2 and 4 means the video subsystem has a problem. Either your video card is bad or bad memory module. Try reseating video card and/or memory.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Oct 27, 2008
venexcsd
  • 1185 Answers
SOURCE: Fan makes a lound noise and power button is orange
It sounds as if your power supply is cooked because the cooling fan has been running slow
Only way you can check is to take a panel off and hook a voltmeter into the 12v & 5V supplies on the Hard Drive and the Floppy Drive.
Posted on Jun 25, 2009
Dell XPS PC Desktops Beep 2 short beeps then turns off
Here is a link to your computer's service manual:
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_xps_desktop/xps-400_Service%20Manual_en-us.pdf
There is a section on Advanced trouble shooting which details Beep codes and LED diagnostic codes.
Feb 13, 2013 | Dell XPS Computers & Internet
Dell xps 420 noisy fan black screen
more than likely bios isn't letting it boot, i'd make sure the fan bearing hasn't gone out, if it has you can order a new one
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Jul 03, 2012 | Dell XPS 420 PC Desktop
My Dell XPS 210 makes a loud whining noise when powered up and lasts for minutes until turned off. Can you identify what the issue is and how to fix?
It sounds like a fan problem, it could be one on the case, the motherboard or in the powersupply. fans are generally inexpensive, but if it is the power supply it will be a couple more bucks to fix. There could even just be a buildup of dust on them. Compressed air can usually clean them out. HDD can also cause noises in some cases but hopefully thats not your problem.
Aug 26, 2011 | Dell XPS 210 PC Desktop
My dell dimention 9200 makes a buzzing noise and no show on monit
Sounds like its just 1 of the fans inside the case needs replacing or possibly the fan inside the power supply. These dont cost much and are easy to replace.
Jul 14, 2010 | Dell Dimension 9200 PC Desktop
Dell XPS 730 no video, not bios, fan running hard
Fist touching anything on the motherboard without a anti-static strap can kill the motherboard.
The fan running at full speed is no big deal. If you took out the video card
how do you expect to see anything on the monitor.
You need to plug the monitor you have into a working computer, this will rule out the monitor. If the monitor died, you did all this for nothing.
Now unless the motherboard has onboard video you have to put the card back in, if it does have onboard, even without the drivers installed you still see the post, because windows will let it run at post, and with the video card, it will still show post without drivers.
Do this,check monitor, try both ports and post back and tell us whats
going on.
Feb 10, 2010 | Dell XPS 730 Desktop Computer
My Dell xps 400 will not boot up completely, then won't power off
It sounds like the machine is experiencing hardware problems. You will either need to call Dell or take it into a local computer repair place.
Nov 16, 2009 | Dell Dimension XPS PC Desktop
Loud Noise on laptop when booting
Most likely it is the POST throttling up the fan to 100% during boot up. Then it switches over to ACPI(?) power manangement and Windows manages your fan speed to extend battery life.
Suggestions:
Go to Dell Support Site https://support.dell.com/support/supportrequests/create.aspx?c=us&cs=19&l=en&s=dhs
Download the latest BIOS updates and run it.
If it continues, try a can of compressed air, and breifly blow out any debris from the system fan. Bits of paper and critter-fur can get sucked up into the system.
Apr 18, 2009 | Dell XPS M1210 Notebook
Thank You.
Oct 26, 2008 | Dell XPS 200 PC Desktop
Dell XPS 400 Card Cage Fan Failure
dell xps 400 pentium d once i turn it on, it beeps and says "card cage fan failure" everytime i press f-1 to continue it shuts off and boot up again it does it everytime how can i fix this CARD CAGE FAN FAILURE??
Apr 22, 2008 | Dell XPS 200 PC Desktop
Computers & Internet Logo
Alun Cox
