Help me please, i have new HP j3508, but when i install new cartridge into my HP 3508, the message on the screen says :"Cartridge Error" cartridge on right is not intended for this printer... help me
  • 320 Answers
You need to remove the cartridges, see to it that the colored cartridge are olaced in its right location the same as with the black cartridge to avoid an error.
Posted on Jan 09, 2013
SOURCE: Right cartridge incorrect" and "Left cartridge incorrect
Many newer HP Printers internally keep track of your cartridges by a serial number embedded into the cartridge. When it's low, the printer remembers. This is entirely done within the printer itself, and not the printer software. Some printers EXPIRE the cartridges after 18 months according to the installation date even it is not empty.
Outrageous, but true.
A fix? Most HP printers will only keep 2 cartridges in memory, so if you have 2 extra cartridges, (even empty ones) you could cycle them through to reset the printers memory, and reset the ink level to full. Basically, even though you've refilled your cartridge, the printers has the cartridge's serial number stored in memory. This will reset it.
Posted on Jul 06, 2008
Joed911
  • 4338 Answers
SOURCE: I have a HP 7410, every time I print I get three error messages.
Perform a semi-full reset on the all-in-one by following the steps below
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find the hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy .
8 Allow the all-in-one to re-initialize. This may take a minute or two.
9 If prompts appear in the all-in-one display to set the front panel language and country settings, perform the steps to set this information.
Let me know if this helps.
If it doesn't, I will research it further. If it does please rate it.
Joe
Posted on Nov 21, 2008
jmassengill
  • 345 Answers
SOURCE: The printer doesn't recognize the new original HP color cartridge
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
Posted on Jan 08, 2009
SOURCE: Cartridge Error: Cartridge on the left is not intended for this
I had this problem. Just called HP support and the solution is so simple: * Take both cartridges out. * Check if they are not empty by taking a tissue cloth and rube the cartridges gently on the tissue where the ink comes out. If ink shows on the tissue, then the cartridges are not empty. * If they are not empty, clean the connectors behind the cartridges with a simple pencil eraser and put them back it place.
THATS IT! :-)
HTH..
Isaac.
Posted on Sep 22, 2010
  • 78 Answers
SOURCE: I installed a refilled HP 94 cartridge in my HP
This is a firmware issue with this printer model, and is fairly common. Try the following: remove both of the print cartridges, close the lid, wait for any noises to stop, and pull the power plug out of the back of the printer while it is still on. Wait at least 10 minutes with the cord disconnected. Plug the power back into the printer, wait for the noises to stop, and then reinstall the cartridges, black first (very important), and then the color. This will force the printer to reload its ram memory and should take care of the glitch. Let me know if you need further assistance, as I would like to be sure your problem is fixed.
Posted on Sep 30, 2010
Printer officejet pro 8600 cartrige 951 is full but printer thinks its empty. how to reset printer
use only new cartidge. Its the best thing you can do if you want your printer work fine with no trouble.
Mar 31, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
Windows 7 and HP 2500C
my hp j3508 shows cartridge error and needs troubleshooting.
Jun 21, 2013 | Office Equipment & Supplies
My printer lights ( all three) are blinking with error message of "cartridge problem" I have tried to replace the cartridge with no success and cleaning the cartridge but no luck. Please help.
In this case you will need two new cartridges to identify the problem.
Take one new color cartridge and one black. Now, remove both the old cartridges and install the new ones and restart the printer.
Most probably your issue should be resolved.
Please ensure that you are using the following cartridges only.
Print cartridge information Part name Part description Product number Print cartridge Black HP No. 15 (equivalent to HP C6615 series) Print cartridge Tri-color HP No. 78 (equivalent to C6578 series)
Apr 08, 2011 | HP DeskJet 920c InkJet Printer
Error message says "Remove and check cartridge on right" Its a new cartridge I've been using for a few weeks and it has been working fine. I have removed cartridge several times and even cleaned contacts....
The electronics on the cartridge have gone bad. Sometimes cartridges short. Take the cartridge back to where you bought it (they should give you credit for any remaining ink) and buy a new cartridge.
Aug 10, 2010 | HP Photosmart C4180 All-In-One InkJet...
Run out ink error warning message
are using a refilled cartridge?
if yes, install an actual brand new one.
are you using an official cartridge that you've had laying around for a while?
the cartridges expire so check if your cartridge has expired and replaced accordingly.
Mar 29, 2010 | HP Photosmart C7280 Laser Printer
Error message HP Officejet 7310 "remove and check cartridge on right. Removed cartridge, checked it (nothing), installed it back - still same message. Installed new original HP cartridge - still same...
Can you find a friend with a similar HP printer, i.e., one that accepts the same model-number of ink-cartridge? If the cartridge gives the same error-message in the other printer, it's time to responsibly recycle your "dead" cartridge, and give the brand-new cartridge to your friend, for his/her usage.
Nov 25, 2009 | HP OfficeJet 7310 All-In-One InkJet...
New cartridge, says cartridge error
1. Try removing the cartridge and unplug units a/c power.
2. Find a damp cloth and wipe the output ports on the bottom on cartridge. .
3. With a Q-tip, go over the round copper pumps on the cartridge tray. ( Where the cartridge makes contacts. )
4. Close door and power up unit.
Unit will give you a error message cartridge not installed.
5. Install the new cartridge.
Close door and fallow any additional instructions given.
( A ) If this does not resolve your problem, re-install old cartridge and see if you get the same error message. If you do not, replace the new cartridge.
Hope this has resolved your problems.
Please rate your techs.
Oct 06, 2009 | HP Officejet J3680 Multifunction Printer...
Cartridge error
remove the cartridge & install the new one cartridge other wise
May 10, 2008 | HP Photosmart C5180 All-In-One InkJet...
Error message Alignment
There is no doubt in my mind it Will be the cartridges you are using, alignment will continue to be requested if print out is missing bits do yourself a favour and use HP gen., not trying to plug HP just telling you the facts
Dec 06, 2007 | HP PSC 750 All-In-One InkJet Printer
142 people viewed this question
jasbo
jasbo
