With my HP pavilion dv6 1355dx laptop when I hit the power button the processor light and other 2 flash 3 times then stops. my laptop will not turn on at all.
Step 1:
Remove the Battery, Press the Power Button to Discharge any remaining power. Connect Power Adaptor to the Laptop. Attempt to Turn on the Laptop.
Step 2:
If you have any experience with pulling apart computers / laptops, you can very carefully remove the back plate covering the RAM &/or Hard Drive. Sometimes having a faulty hard drive / ram prevents the laptop from being able turn on correctly. In process of elimination try removing idividually the hard drive then followed by each stick of ram.
Posted on Jan 09, 2013
  • Robert Wagner Jan 10, 2013
    As soon as I removed the battery and hit the power button and plugged in my charger it started working again! Thank you. I see it is time for a new battery.
  • Ianb Jan 16, 2013
    it may just have been that it suffered from a surge. sometimes what happens is that the capacitors suffer from a bad batch of power. Taking the battery out and pressing the power button disperses the left over power fixing the issue. 9 times out of 10 there isnt a fault with the battery
3 Suggested Answers
  • 5 Answers
SOURCE: my hp laptop wont start power light flashes on
try powering up the laptop with the battery pulled. In my case, the battery was the culprit. Probably shorted.
Posted on Apr 21, 2009
contratek
  • 83 Answers
SOURCE: screen wont turn on
remove the battery and the power from the laptop.....then press and hold down the power button for 20 seconds ...... attach the AC power only and turn on the laptop this should turn on the system.
This drains the capacitors on the system (safety feature of laptops ... quite common)
If this does not work remove the Ram and reseat it ... something has either come loose or the backlight on the LCD has gone bad.
Posted on Oct 06, 2009
Green power supply light is flashing so power is getting to the computer, however the computer will not start from start button. Have removed case and tried ***** start button. Didn't work. Comput
Power getting to the computer/Power Supply?
Yeah.
Power Supply good? -> NO
A) IF ALL of the LED lights were on at once, they would use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
C) A typical Processor can use from 51 to 125 Watts of power.
Just depends on what Processor it is.
HP Pavilion a810n Desktop PC?
Uses an AMD Athlon 64 3300+ processor,
(Operates Up To a frequency rate of 2.4GHz)
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00280647
http://en.wikipedia.org/wiki/List_of_amd_athlon_64_microprocessors#.22Newcastle.22_.28CG.2C_130_nm.29
Can use up to 89 Watts of power.
Your Power Supply doesn't even have enough power to spin fans, much less start the Processor.
Want to test the Power Supply? Have a multimeter?
No? Have a power supply you can borrow for a test unit?
KNOWN to be good, and Compatible?
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 05, 2012 | HP Computers & Internet
I have an HP Pavilion dv7-1130 Entertainment Laptop, and as of recently, when I try to turn it on, the lights around the keyboard power on and the fan runs, then the fan stops and the lights stay on. No...
With an extensive use of the notebook,
some times notebook would store some static charges which
indeed will stop the notebook from powering up or charging
the battery. The procedure to remove this static charges from
the notebook is known as power drain. Performing a power
drain procedure will not effect any personal data or delete
any pictures from the hard drive on your notebook.
I recommend you use Power Drain procedure by following these
steps:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter.
5. Turn on the Notebook power.
Dec 12, 2010 | HP Pavilion dv7-1130us laptop
My HP 6720 won't switch on. When connected to the power source, a steady blue light comes on (normal) then goes to a light blue then goes blank. If I press the 'on' button, a flashing orange light appears...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The power button could be bad.
5. The motherboard could be defective & needs to be replaced.
Sep 19, 2010 | HP Computers & Internet
My computer, when the adaptor is connected to it, it flashes buttons on and power indicator when and goes off. and when the power botton is pressed it won't come on.
Sep 17, 2010 | HP Pavilion dv4000 Notebook
My HP Pavilion 2500 will not start up, the blue light on the computers powerport blinks instead of staying on. I have tried a new power supply and removed the battery several times and replced it.
Sep 10, 2010 | HP Pavilion dv2500t Notebook
I have light where power cord plugs in but nothing else. I do not have a screen or any kind of power unless i hold the on button down and the lights will flash just under the screen, but nothing else
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Sep 08, 2010 | HP Pavilion dv5-1000us Notebook PC
Hp pavilion dv6000 turns onn and off
I had a similar problem with my pavilion. They have a cooling fan design that allows for lint buildup and subsequent overheating. You could try using a compressed air and blowing out the exhaust vent area for the fans.
May 27, 2010 | HP Pavilion dv6000t Notebook
Laptop wont boot and the battery and power lights flash
a simple power cycle might work. Take out the battery but keep the ac power connected. hold the poewr button down for 1 minute. then hit the power button again and it should poewr back up. If this doesn' t work. iyou said hte battery light flashes so the problem isnt the battery..the problem might be hte ac power adapter..if you have a warranty this would be a good time to call them. Try the power cycle first though this fixes the problems lots of the time
Apr 15, 2009 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
98 people viewed this question
David Payne
David Payne
