Question about Proform 395 E Elliptical
My right pedal makes a popping sound - Proform 395 E Elliptical
I'll bet the bolt (one of three) have come off of the threaded plate taking the threads with it. Check the bolts and if one is turning without tightening, that is probably the case. All 3 bolts went on my 395e at once.
Posted on Jan 20, 2013
Recently replaced clutch kit flywheel hydraulic slave cylinder on a 97 Chevy s10 4.3. Once the clutch system has been bled the clutch pedal pops off clutch master cylinder when pedal is hard. Any...
Not sure if I understand your question. Sounds like the push rod from the clutch master cylinder is pushing the cylinder off the firewall. If that is the case it could be that your rod wasnt fully engage into your cylinder make the rod to long and with enough pressure is popping the clip off the fire wall
Jan 12, 2015 | Cars & Trucks
My engine is making a loud clicking sound and popping sound when hitting the gas pedal
Its either very low on oil, or you have a rod knocking. You should not drive it until you fix the problem.
Aug 13, 2014 | 1994 Saturn Sl
When pedaling starts off making squeaking sound but now it is very loud with cracking and popping.
Pedal or bottom bracket bearings need a look. The web has many resources for identifying noises on a bike. Just search for a few key words. For example "bicycle pedal loud cracking and popping"
One resource...
http://www.parktool.com/blog/repair-help/trouble-shooting-a-creaky-or-noisy-drive-train
Happy hunting.
Aug 18, 2011 | Cycling
My pedal is brand new and cuts out after about ten minutes. I also bought the delay pedal and it cuts out around the same time while making a rapid pulsing sound.
This sounds like you MIGHT be running on batteries and they are near depleted... Pedals go through batteries pretty fast. Use power adapters and make SURE to use the right ones as some pedals require different voltages and types of current.
Jul 28, 2011 | Behringer Rv600 Reverb Machine Effects...
2001 silverado hd. i pushed hard on brakes there was a pop like i blew a line but no leaks, pedal went to floor like line blew also. brakes still work but pedal is pushed to the floor to stop. I bled...
Hi oakleafwoodw, sounds as if the brake master cylinder has busted a seal allowing the brake fluid to leak by cylinder when you push the brake pedal giving you no or very little pedal pressure....it is located under the hood on the drivers side firewall, you will see all the brake lines attached to it , remove those and the two bolts holding it on,take it with you to auto parts store for a rebuilt one , they will keep your core for rebuilding, other wise you pay a core charge., verify that they have the one you need before hand, get a quart of dot 4 brake fluid, hook it up, and bleed air from the brake lines starting with wheel cylinders in this order Right rear......left rear.....right front.....left front...making sure to keep fluid level topped off in the master cylinder during the whole bleeding process or you will pump air into lines....OK!! caution: you should not drive it until you have good brakes!! you said they still work but if you had to stop suddenly ,it won't do it.
May 23, 2011 | Chevrolet Silverado 2500HD Cars & Trucks
How do you bleed the breaks pumping them dont work
Bleeding brake lines requires 2 people. If you are sure your problem is air in the brake lines then you need to bleed the air out. First step is to be sure the brake fluid reservoir is full of fluid. Then crawl under the car starting at the right rear tire. There is a small fitting that is near where the brake line enters the back of the wheel assembly. You will need a wrench to fit this fitting. Have someone in the car to pump the brake pedal three times and the last time hold the pedal down firmly. At that point you will loosen the fitting at the wheel and brake fluid will spray from the fitting. If there is air in the lines, it will make a popping sound when it escapes with the brake fluid. The person in the car should hold the brake pedal down until you tighten the fitting back. If they let up on the pedal before you tighten the fitting it will draw air back into the lines. If no air pops out, you may have to repeat the process several times per wheel. Move to the other rear wheel, repeat then to the right wheel, then the left front wheel. During the bleeding process, be sure to keep the brake fluid reservoir full of brake fluid. Obviously, don't get the fluid into your eyes, mouth or nose. Also it can cause rashes and reddening of the skin so you may want to wear rubber gloves. It will leave an oily stain if you let it flow onto your driveway or garage floor, so keep them covered during bleeding.
Sep 20, 2010 | 2003 Volkswagen Passat
Proform 395 E Elliptical Logo
93 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
