Question about Horizon Exercise & Fitness
My horizon ct5.1 turns displays select workout, buttons all beep but do not respond
Turns on buttons beep but do not respond 5201 displays when turned on then goes to select workout
    Top Expert:
  • Horizon Master
  • 12,223 Answers
Replace the old batteries with a new ones, type hybrid rayovac, with the same polarity. clean the contacts batteries with c. cleaner
2) Tight the ribbon cable inside the display board.
3) Adjust the REED swithc, see the diagram attached. Test for open or faulty. Clean it, tight the connector very well.
God bless you
My horizon ct5.1 turns displays select workout, bu - 1_9_2013_6_29_58_pm.gif
Posted on Jan 09, 2013
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: Horizon digital DT850 treadmill turns on can select workout hit start button belt does not turn on/rotate
Step 1:
seee the video attached and lube the rollers bearing too. Happy NEW yEAR .God bless you
Step 2:
Test the input voltage motor, if there are the motor need repair see my personal TIPS for motor help. see the diagram attached.
Step 3:
test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
Posted on Dec 31, 2012
Horizon Treadmill Ct5.1 turns on, displays nothing and beeps nonstop
If you wish to get some details about treadmill repair ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Nov 26, 2016 | Horizon Exercise & Fitness
Why does my proform xp 400r keep beeping even when it is not being used?
Did you ever find a resolution for this issue? I know it was posted over a year ago, but now mine is doing the same thing, randomly beeps 3-4 times rapidly whether or not is in use and never shuts off. Also none of the buttons work, just makes it beep as well. However, it still responds when pedaling and adjusts the resistance, just can't select a workout mode. Can only power off by unplugging otherwise the display stays on and keeps beeping every ten seconds or so
Dec 10, 2015 | ProForm XP 440 Recumbent Cycle
Horizon T91 Treadmill - Key Pad Troubleshooting
correct. If the console is not responding or some buttons do but others don't the membrane needs replacement.
Apr 02, 2017 | Horizon T92 - Treadmill
I have two horizon duo radios and both have problems now with the on off center button. It dosesn't work. Can't turn radio off
Control micro is damaged due to leaky memory cap, .33F/5.5v on display board. Yellow glue used on these units turns brown and becomes both conductive and corrosive to the circuit board traces. built in obsolescence in my opinion to get you to buy new.
Feb 25, 2014 | Boston Acoustics Duo-i Horizon Clock Radio
Step 1:
Step 2:
Step 3:
Dec 31, 2012 | Exercise & Fitness
Lubed belt but display still says lube belt and I cant do anything how do i clear the display I have the horizon gs950t
After lubrication you have to reset your treadmill settings. Then only the message will go off. To reset the tread mill do the following.
1. Hold the "Stop" button for three seconds to reset the treadmill and clear the current workout selection or screen. The console will reset but will save any accumulated data
2. Press and hold the "eTRAK" button for 10 seconds to reset the console date. This permanently deletes any previously accumulated data
3. Press and hold the "Stop" button while pressing the Speed "+" button. Hold for five seconds to reset the console after applying lubricant to the machine. Lubricant application is usually only necessary when you receive the "LUBE" error
ok
May 04, 2011 | Horizon Fitness Horizon T90 Treadmill -...
Hard drive not responding, comes up with message restore hard drive. when you do this the message just comes back.
Wendy.
Breathe. :)
Now, hold the power button down until the system turns on and turns back off.
Now, then let the button go. Then hold the button down again it will beep once then beep twice quickly. Then let it go. It will tell you to plug in the usb cord and connect the controller then press the ps button.
A menu will apear - select option #5 (System Restore).
Simply AGREE with everything it tells you until completed. You will need to reset the time and date on the unit, but this should correct the issue.
Nov 03, 2010 | Sony Playstation 3 (PS3) Console
All over sudden my boston horizon doesnt allowe increase the vol.
To fix: turn on unit, turn volume all the way down to 00, push and hold volume button for 10 seconds until beep then release, then turn volume all the way up to 50 (max) and push and release volume button.
May 17, 2009 | Boston Acoustics Duo-i Horizon Clock Radio
Exercise & Fitness Logo
259 people viewed this question
Top Horizon Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
