Question about Belkin (F5D7230-4) Router (587009)
I need to open some ports to the internet
I have program that requires ports 5198 and 5199 open to allow
communication. I've went into virtual servers inside the Belkin router and tried to config. and entered the ports
I clicked on enable but when I go to the program it want connect.
If I take the modem out of line and use the DSL modem alone
I can connect with no problems. How do I set to allow these ports.
    Problem Solver:
  • 8 Answers
You need to open ports on the modem and forward to router ip adress ... then from the router open and forward to your computer ip adress
Posted on Jan 21, 2009
How to open NAT
With Belkin you have the option of disabling Firewall, or setting up a Virtual Server. You must provide the port based on program / game requirements.
Almost forgot, it does allow for 1 IP in the DMZ. This is you best bet. Easy peesy, nice and easy. gl
Nov 24, 2012 | Belkin Surf N300 Wireless Router...
How can i configure aip w505 for att elevate internet, in order to view my qc dvr
You need to enable the virtual server settings on the AIPW505
You also need to allocate a static address to the DVR within the range of the DHCP address range.
Virtual Server Settings - Selects between enabling or disabling port
forwarding the virtual server. (Default: Disable)
? IP Address - Specifies the IP address on the local network to allow external access.
? Port Range - Specifies the port range through which traffic is
? Protocol - Specifies a protocol to use for port forwarding, either TCP,UDP or TCP&UDP.
? Comment - Enter a useful comment to help identify the forwarded
port service on the network..
The manual can be obtained from here
Oct 21, 2012 | ADVANCE Alfa AIP-W505 802.11n/b/g Wireless...
Need 2 open NAT
If you have a firewall or network hardware, such as a router, you might need to make a configuration change in order for your Xbox 360 console to communicate with Xbox LIVE. This configuration change is sometimes called "opening ports" or "port forwarding."
Xbox LIVE requires the following ports to be open:
  • Port 88 (UDP)
  • Port 3074 (UDP and TCP)
  • Port 53 (UDP and TCP)
  • Port 80 (TCP)
For Belkin router follow this steps
Configuring port forwarding
In order to configure this, you need to know:
- The IP address of the computer or device to have the port forwarded to.
- The port numbers to be used and whether these are TCP or UDP ports
(Note: We recommend you use a computer that has a wired connection to the router.)
Setup steps:
  1. Open a Web Browser on the computer. Type in
  2. In the address bar of the Web Browser type Click Login in the upper right hand corner of the page. The router does not ship with a password, so just click submit.
  1. Click on Virtual Servers under Firewall in the menu on the left
  1. Enter the following information
    • Disable Firwall
    • Type the port(s) specified by the program manufacture for both of the Inbound port fields
    • Select TCP, UDP, or BOTH for the Type.
    • Private IP address: Enter the IP address of the computer you want grant access too.
    • Type the port(s) specified by the program manufacture for both of the Private port fields.
  1. Click the Apply Changes button
Jan 10, 2011 | Belkin (F5D8231-4) Wireless Router...
Windows XP, Vista, & 7, installed citrix client 12.0.3 on each of them. When using direct connect through cable modem, access is allowed and all apps work. When connected to my local router(trendnet...
Because you can connect outside of your trendnet, its definitely the problem. please allow and direct traffic on port 3389 in your trendnet firewall.
Aug 27, 2010 | Citrix SonicWALL Internet and...
Printer offline. How do I fix
The issue is with the printer ports, we need to configure the ports for the network from the printer icon.
Please perform the following troubleshooting steps to fix the issue.
1.Start, Control Panel, and then select Printer and Faxes.
2.Click File and then click Server Properties.
3.Select the Ports tab, and then click Add Port.
4.Select TCP/IP Port and create a new port.
5.Type the IP address of the Printer(which is printed in the network configuration page) and proceed with the onscreen instructions.
Follow these steps to unblock the HP programs and the required Internet ports.
Open the C:\program files\HP\digital imaging\bin directory and then locate the following files:
  1. hpoews01.exe
  • hpofxm08.exe
  • hposid01.exe
  • hpqkygrp.exe
  • hpqste08.exe
  • hpqtra08.exe
  • hposfx08.exe
  • If the HP software installed on the computer is version 10.0 or newer, find the hpiscnapp.exe file.
  • If the HP software installed on the computer is version 9.0 or older, find the hpqscnvw.exe file.
Open the C:\windows\system32 directory and then locate the following files:
  • hpzwiz01.exe
  • hpznui01.exe
Make a note of or copy the file path for each file listed. The file paths should resemble the example: C:\windows\system32\hpzipm12.exe .
In the firewall software, make sure that each of these programs displays in the list of trusted or allowed programs. If any of the programs do not appear in the list of trusted or allowed programs, add the missing programs to the list manually
NOTE: The name of the list might vary, depending on the firewall program
If the firewall software has different trust levels or requires specific permission for a program to access the Internet, make sure you allow each of the HP programs to access the Internet freely.
Click OK or Save to save the changes to the trusted or allowed program list.
Jan 26, 2010 | HP Photosmart C6180 All-In-One InkJet...
How to create a port on my router
please follow the steps are given below,
1.Type on your browser's address bar. You will see a login dialog box .
2.Type your username & password and login to device.
3.A web page will appear , you can go to security section & select virtual servers.
4.From virtual servers section you can create port you want either TCP or UDP.
best regards,
May 09, 2009 | U.S. Robotics (USR5450) 802.11g/b Wireless...
Having a problem getting DynDNS to pass through router and connect to my web server. Web Server can communicate with DynDNS, but an http or https request (ports 80 and 443) do not get to the server. I...
I did this with a cctv and another dns server and does not really work. So i just change my ip to static and open ports 80 and 443 and 8000 (server) and worked fine without using ddns or free dns. Oh and i use this to check my ports if they are working
Jun 13, 2017 | Encore ENHWI-N Router
I have a Belkin Wireless N Router and the virtual ports is.....
I fixed all i had to do is just find out my IPv4 Address
Which i found by searching CMD and then typing in IPCONFIG and press enter.
Then look for your IPv4 address and put that in the private ip address part in Virtual Servers.
Jan 06, 2009 | Belkin Wireless-N Wireless Router with...
I'm assuming by the list you mean within antispyware antivirus, trojan, firewall, and Windows defender programmes; check them all. You may have to allow it also if you are using a router in the virtual server section and open the required port.
Mar 03, 2007 | Logitech QuickCam Communicate STX Personal...
Configure the firewall
You can use the Virtual Server to forward an individual port to one of your computers. You cannot forward the same port to multiple computers. In order to configure the Virtual Server you need to know the IP address of the computer that needs the port opened and the service port number. The links below will help you find the IP address of your machine. If you don?t know which port needs to be opened, try checking the software manufacture?s support website for information on use behind firewall. Configuring the Virtual Server: Step 1 Access the device configuration by entering in your web browser. Login with your username and password. The default username is admin and the password is blank. Step 2a If the port you need to forward is a common port, it will be under the predefined virtual server list at the bottom of the page. Click the pad and paper icon next to the virtual server entry you want to use. The Protocol Type and Service Port fields are preconfigured. Click the Enable radio button to use the virtual server. Enter the private IP address of the computer that will use the service port. Configure the Schedule as needed, then Apply your settings. Step 2b If the port you need to forward is not listed under the predefined virtual server list at the bottom of the page, you can create a new entry for your application. Click the Enable radio button to use the virtual server. Give your virtual server a name. Next, enter the private IP address of the computer that will use the service port. Then, select the Protocol Type and enter the Service Port. If you don?t know how to use Private and Public port assignment, then just enter the same port number in both fields. Configure the Schedule as needed and Apply your settings.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Belkin (F5D7230-4) Router (587009) Logo
128 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
